Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
How do I reset breakers on whirlpool duet dryer?
Dryer keeps tripping the breaker in house.
  • 686 Answers
What size breaker is the dryer on it's should be at least a bouble 30 Amp breaker
Posted on Mar 06, 2009
WHIRLPOOL DUET GAS DRYER WGD87HEDW1
Unplug for 1 minute. Plug back in. Check status
Apr 17, 2016 | Whirlpool WGD87HEDW Duet WGD87HEDW 7.4 cu....
I have a whirlpool electric dryer.. when I turn it on its been having a problem with staying on or not heating at all. It will spin and stay on but no heat.we have changed the element and it seemed fi
Sounds like a tripped circuit breaker in the power panel for the house. The breaker for the dryer is actually 2 breakers connected together so if one trips so will the other. Sometimes this does not happen and only one breaker trips. This condition removes power to the heating element but still supplies power to the rest of the dryer. Check to see if the breaker will reset by turning off and back on several times. Then check the power receptacle that the dryer plugs into with a voltmeter set to read 240 volts AC. If no 240 but 115 is present then replace the circuit breaker.
Nov 19, 2014 | Whirlpool Dryers
Whirlpool Duet Dryer Tripping Breaker on Heat Cycle
It caused the problem. Appliance repair person
May 13, 2017 | Whirlpool Dryers
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
Barrel of dryer turns but no heat
Your heating element needs to be replaced, or the 240 breaker in your breaker box has tripped. I was a maytag technician for several years...So, check your breaker box for any tripped breakers or the heating element in the dryer needs to be replaced, or the t.stat for the element has blown.
Apr 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
GE Profile Model#DPSB513EBOWW Breaker kicked to
Have you reset the dryer breaker also. Even if doesn't look tripped turn off then back on again.
Feb 01, 2010 | Whirlpool ET8CHEXSQ Dryer
Trips breaker: Whirlpool Duet Sport front load dryer
could be a faulty stat or element,get an engineer to test the dyer, he will check insulation on the element, could try replacing the element that just might sort it
Sep 21, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryer keeps tripping breaker. slight burning
The heating element is shorted. This is an electric dryer, right? replace the heating element. Make damn sure it's un-plugged when you work on it!
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirl pool elect dryer keeps tripping breaker
Ok, this is the result of a failed High limit thermostat. you should replace this failed device asap.
Check for continuity in the thermal fuse as well. replace if no continuity is found.
May 31, 2009 | Whirlpool LEB6300 Electric Dryer
Whirlpool Duet Dryer getting very hot, tripping breaker
what size is your breaker how many amps it should say on breaker are you cleaning the lint screen with it on top if the drier is getting too hot there is a device in it that's called a thermal limiter that would blow before the breaker would trip what kind or you in a house or apt. now on high heat can you hold your hand on the side of the drier.or cant touch it look at the vent under your house and tell me 1is it hanging down under the house then coming up to the hood 2whats its diameter3whats it made of we will go from there ok.there are three thermostats in that drier the first one runs at about 150 160 max second is a safety in case the first one fails it cycles at about 250 third is a safety if the drier exceeds 300 it will shut the heater down and wont rest it has to be replaced
Jan 10, 2008 | Dryers
Open Questions:
See all Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Questions
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
590 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
