Question about Intertherm Heating & Cooling
Compressor not working
When the points ingage the compresser just clunks and humms. The the points get hot and disengages.
I think the compressor is locked up.
Is it still under warrenity? I believe it has ten yr. Bought new in June 1999.
What is the cost of a replacement.
Need help asap.
thanks,
Joe Mumford
    Scholar:
  • 144 Answers
It does sound like the compressor is locked up or one lead (wire) to the compressor is broken or burned in two or the run capacitor is bad. A service tech. could determine if the capacitor is ok and/or check the compressor by installing a hard start kit. If that works ok. If not then you need to replace the compressor. Either way I'd advise calling a certified Technician. This isn't someting you can do yourself.
Posted on Mar 03, 2009
A/c cluch not incaging
Hi, the most likely problem is the system is low on gas. There is a pressure switch that will disengage the compress clutch if the system is empty or very low on gas. This unfortunately means you have a leak you'll have to get checked out. Less likely is compressor clutch wire has become disconnected. Aalso
Jun 20, 2014 | Honda CRV Cars & Trucks
I think I have a water problem? I hear a clunking noise at various times from I think the right bottom of the unit. Water and Ice seem to be working fine.
Hi.
The clunking noise is the compressor. It usually means that one of the internal mounts that secure the compressor motor is gone. The whole compressor needs replacement.
First ensure that the fridge is at level. A not well leveled unit's compressor can make noise.
If fridge level is OK, call the Whirlpool customer service number listed on manual. The compressor has a long warranty. If the fridge is the one in question you may still be covered for the part.
Regards.
Ginko.
Mar 23, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
2002northland 36" refridgerator and freezer not
The compressor should turn on after it cools. It shuts down if it overheats to prevent damage/fire. The compressor itself could be bad but more than likely the fan is dead.
Jan 11, 2011 | Northland 36SSS Side by Side Refrigerator
I have a 1995 24.5 cu. ft. GE Profile refrigerator. When it shuts off there is a loud clunk. I think it could be the compressor turning off. Other than that it seems to be working fine. Is this a serious...
The compressor is sitting on springs inside a metal case. When it stops, the centrifical force is absorbed by these springs. If one or more springs become weak or break, the compressor hits against the outer case a time or two. (CLUNK CLUNK clunk) There is really nothing you can do about it, short of replacing the compressor. (read big bucks) NOTE: If you take a new compressor and give it a shake, you will hear the same clunk. If the noise is really bothering you, I'd say after 15 years, it's time to move that refrig to the basement and get a new energy star model for your kitchen. (the old one most likely has several more years worth of clunking before it truely dies)
Sep 25, 2010 | GE Refrigerators
My compressor is running hot on my fridge i have cleaned the coils , what else do i need to do? I have even pulled the fridge away from the wall.
Why do you think the compressor is running too hot? It is normal for them to have some temperature, as they are compressing a gas, which increases the gas's temperature (and consequently the compressor's). As long as the compressor gets adequate air circulation and the coils are clean, there's nothing else you can do.
Feb 06, 2010 | Kenmore Refrigerators
Ac compressor disengages 98 honda crv
Most compressor has a speed sensor to compare with the cranshaft sensor to prevent the compressor locked up.When you raised the RPM, after 15 sec, if the 2 sensors are not in synch then the computer thinks that the compressor is locked up so it disable the cluctch that was why your AC stops working. Check out your Compressor speed sensor. Good luck.
Jul 15, 2009 | Hitachi Heating & Cooling
AIR CONDITIONING
Well my a/c spopped working to,was told it was themegentic clutch switch that work the compressor,might have to replace a/c compressor
Aug 19, 2008 | 2003 Kia Sedona
NO COOLING
Hmm.this will require a few questions for you to answer. first does all the fans run, condenser fan??? indoor blower? and does the compressor humms, when you turn it on?
May 08, 2008 | Carrier 38BRC048 Air Conditioner
Heating & Cooling Logo
50 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
