Question about Whirlpool LSR6232J Top Load Washer
Whirlpool LSQ85443J will not finish a complete cyle unless something is holding down the lid mechanism (such as a stick) or coat hanger to finish the drain and spin cycle.
  • 57 Answers
You need to replace the lid switch common problem if the lid has been slamed its just plastic
Posted on Mar 05, 2009
I have a 1988 cadillac elderado and my keys are in the trunk... My car doors are locked as well. How can I get them out without calling a lock Smith?
Does your car door locks have small lift up knobs on interior doors? You would push down to our ck car. If you do then get a metal coat hanger and small wood wedge.
then untwist coat hanger end create a loop on end so you think it would slide around door lock.
gently pull top of door away from body and of car see if you can put wedge in to hold door slightly. The goal is to insert coat hanger down so you can maneuver over lock, once you do pull up.
you should bend coat hanger thinking of how you will slide into car and long enough to turn and twist until you unlock.
metal coat hangers can be obtained at a dry cleaners.
Sep 30, 2016 | 1988 Cadillac Eldorado
CLip of motherboard felt off.
http://www.heatsinkfactory.com/cpu-retainer-clips-intel-pentium-4-478.html
That would be for an AOpen AX4SPE-UN motherboard, because it has a Socket 478 processor socket.
I had it happen to an old mobo in the past, with a Socket 478 processor socket; and no clips.
I used a straight piece of coat hanger, and went from hole to hole, on one side.
http://www.ebay.com/itm/P4-Socket-478-Intel-CPU-Retention-Retainer-Bracket-/140647148266?pt=US_Fan_Heatsin_Brackets_Accs&hash=item20bf392aea
Had a slight bend in the middle, and this bend went partially across one side of the finned Heatsink.
Small piece of coat hanger again, on the other side.
Cut to the right length, and with the correct bend, the two pieces of coat hanger, put even pressure down on the finned Heatsink.
Problem is they twisted. The pressure on the bent part against the Heatsink, made them want to spin up away, from the Heatsink.
So I added a piece of coat hanger on each side, to keep the side coat hanger pieces from twisting.
Hard to explain, and looked like something from Dr.Frankenstein's laboratory.
Worked though.
(Too much pressure, and it will break the plastic retention bracket on the motherboard.
Not even pressure on both sides, and Heatsink will not sit flat on Processor. This = No.
You just have to 'dial it in', (Coat hanger pieces), or use the correct part/s)
Regards,
joecoolvette
May 06, 2013 | AOpen AX4SPE-UN Motherboard
I opened the door before the self cleaning cycle was finished? It was blowing and I thought my husband left it on when he left. I came home and walked past it and felt the air, so I pushed oven off and...
You have most likely caused one or more fuse relays to blow.
The self-clean operation can not be interrupted before the cycle is complete without causing issues.
There is the main fuse inside the control panel and 2 fuse relays on rear of the oven.
In order to access these fuses you must open the door,then remove the mounting screws to remove the oven from its cabinet..
Use a wire coat hanger bent into a "U" shape on one end.
The door latch is in the center of the door on the top oven.
Slide the bent wire coat hanger between the door and the oven opening.
The "U" of the coat hanger will be right center of the door latch.
Slowly pull the "U" to the left until it catches the latch.
Then pull steady and forcefully to pull the latch mechanism to the left while putting pressure on the door to open it.
Once the door is open you can begin to access the parts for diagnosis and repair.
Nov 28, 2010 | Whirlpool RBD305PD Electric Double Oven
The washing machine does not run unless we put weight on the lid
Your lid switch will have to be replaced.
Paste the video link below to see how to access the cabinet to change the part.
http://appliancejunk.com/forums/index.php?topic=5191.0
Nov 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My smeg dishwasher is flooded .The water is not draiining
You could have a clogged drain hose or your drain pump is not working. Find the end of the drain hose, try carefully sticking something like a coat hanger down it. If it's clear, your pump may be bad and need to be replaced.
Aug 10, 2009 | Dishwashers
I think the issue might be the lid switch, but not too sure. The washing machine will fill with water and agitaite but then it stops and the water does not drain or go to spinning cycle mode. I have to...
If you put hanger in hole and push down then it works it is the lid switch. To remove take top off to get to it. From the front take a putty knife and push on each side about an inch from the side to release the clips that hold the top down. Putty knife between the top & the cabinet. Lift up and you can get to the switch. Also it could be the plastic piece that pushes the switch down is broken off and not long enought to push the switch down.
Jun 09, 2009 | Roper RAS6233KQ Top Load Washer
A lighter fell down the lint trap door
i take it that its door on the top of the dryer ? if so that means u will have to pull the rear pannel off the dryer unless u can get lucky n " fish " it out with a coat hanger
Jan 02, 2009 | Whirlpool LER4634J Electric Dryer
Removing finished bread from pan
Before the baking cycle begins,remove the bread pan ,shake out the batter onto a piece of waxed paper,remove the paddle from the bread pan,place batter back into the pan,close lid.This way you only have a small hole in the finished loaf. I prefer the 1.5 pound rye bread,and set a kitchen timer for 2 hours 5 minutes-when the "shape" cycle finishes,we remove the paddle.
This is listed in my manual on page 76,item # 7;heading is METHOD.
Front of the manual lists the times for the cycles,just add them up.
(When you dump the batter back into the pan,try to pat down the rough edges,it looks better).
Nov 04, 2007 | Breadman TR2500BC Bread Maker
Whirlpool LSR6232J Top Load Washer Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal De
