Question about HTC Touch P3450 Smartphone
Stuck on windows boot up screen
My htc touch elf is stuck on windows boot up screen...ive tried soft reset and hard reset doesnt work either...i did not try to flash it or anything the screen just froze and i soft reset it then it just got stuck here...
  • 2 more comments
  • pvatopsax Mar 04, 2009
    ok i will still rank you but that didnt help ofcouse because that is just another way of hard resetting the phone however the phone will not hard reset at all...if you could be so kind as to give me step by step directions on how to do a rom the way last time i checked the rom upgrade from htc was down...
    hello and thanx zohail...i will still rank you but that did not fix the problem simply because that is just another way of hard resetting the phone and the phone wont hard reset at all however if you can give me step by step direction on how to perform a rom upgrade it will be greatly the way last time i checked htc rom upgrade for htc touch elf was down...thanx in advance
  • pvatopsax Mar 07, 2009
    ok any one with a solution other than a hard reset pleeeeease i have stated in original post that the phone is unable to do a hard reset for whatever reason it wont do it @ all nothing happens...i know various ways of hard resetting the phone however its not hard resetting at all.
    ok again thanx in advance was manufactured for marketing in canada...i hope that helps.
Regarding with your HTC Viva / Elf
Try hard reset with phone in "OFF" state following this instructions if it will do;
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button under the battery cover at the top
of the device.
2. Release the stylus, but continue pressing the TALK and END buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have
been backed up before a hard reset is performed.
3. Release the TALK and END buttons, and then press ENTER on your device.
Posted on Mar 17, 2009
1.Remove Sime,Memory Card
2.PowerOff your Mobile
3.Power On.
4.Press and Hold Bothe the Buttons (Left & Right)
5.Reset the Mobile Using Stylus
6.Press the Centre Button
7.Wrning Message will be poped up
8.Click ok.
Posted on Mar 06, 2009
  • 1,223 Answers
Just try this
when ur pda is switched off press Call and end key together and then press power button for like 5 sec a screen will appear asking u to format the pda pls confirm the action by pressing center button of the 4 way keys and then ur pda will be factory reset to the default OS , if it helps ur problem then tell me
other wise go and upgrade ur ROM from it will help u for sure basically it is a software issue
pls rate me FIXYA if i have fixed ur problem
Posted on Mar 04, 2009
  • Shoaib Rais
    Shoaib Rais Mar 07, 2009
    pls tell me from where u got this pda i mean which region u bought it from so i can give u rom update link kindly reply to get help in this ,
HTC Pro2 stuck on Touchpro2 screen with B04 in red letters on bottom right corner. Tried soft reset no luck. What should I do
try a battery pull ........if that doesnt work do a hard reset (power button /answer and hang up button all at once) this will reset the phone back to factory settings so make sure you have a backup
May 17, 2010 | HTC Touch Pro Smartphone
My screen is stuck on the welcome screen and won't do anything el
soft reset
Jul 04, 2009 | HTC Touch HD Smartphone
HTC Touch lost the WiFi ability
I think phone needs software reset. Below is the link about performing soft reset and hard reset on HTC touch. Try soft reset first. if it doesn't work, try hard reset. If after hard reset still no success, try to flash firmware. But I think hard reset can resolve the problem. Note, that hard reset will delete the storage entirely, so backup any data befor performing those manipulations.
Mar 18, 2017 | HTC Touch P3450 Smartphone
It gets stuck on the windows mobile screen
You have to execute a "hard reset". The exact method depends on the exact type of HTC phone you have. You should Google for "HTC Touch <your exact phone type> hard reset" and follow those instructions.
Looking at the picture you have a HTC Touch P3450, in which case you can instructions at:
Make sure you follow the instructions properly. When it still doesn't boot up, you can always perform a firmware upgrade/reset, that's almost guaranteed to work, but is complicated and might break your warranty (depending on wether you bought the device yourself or got it as part of a package deal from your provider).
Mar 22, 2009 | HTC Touch Cellular Phone
HTC Touch was stucked up after an error while upgrading to WM 6.1
i think u have tried to upgrade thru custom rom bcoz this pda came with WM 6 only so u tried to upgrade to 6.1 thru custom rom procedure and it seems like something went wrong and u get a boot loader screen tri color with code written SPL 1.XXX on it dont worry i can help u in this go step by step as soon as ur problem is resolved leave other step
first try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if ur pda boot normally after reset procedure it will take some time to boot dont panic if it is ok then good luck
if it doesnt help then try this
download Hard SPL 3.1 from here
install it as described in the instructions inside the zip file
and then Rom Lite version for ELF from here
first install hard spl 3.1 as directed on ur pda and then update to custom rom from the the file downloaded
pls rate me FIXYA if it helps
Mar 14, 2009 | HTC Touch P3450 Smartphone
Htc touch camera doesnt work... did soft and hard reset n tried to start camera app. from windows folder but no needed !
Among the many issues with the Touch, the camera is another. If a hard reset doesnt work, your device will need a new camera. If you have Sprint, this can be replaced at any service center for no charge if you have insurance and there is a part for immediate repair.
Just to confirm, when you do a hard reset make sure that you press and hold both of the softkeys while sticking the stylus in the reset hole until it asks to reset.
Dec 17, 2008 | HTC Touch P3450 Smartphone
Toch screen is not working
the screen is locked. when i press any button it says press cancel first and then unlock. touch screen is not functioning, how do i do that
I try the soft & hard boot. but same prob how to unloke the phone
Jul 15, 2008 | HTC Touch P3450 Smartphone
Upgrade Problem
i am unble to install dictionary in htc 3400.
Feb 23, 2008 | HTC Touch P3450 Smartphone
Blank screen
Try soft reseting your phone. If that doesnt work then try hard reseting.  To soft reset take the stylus pen and push in the little hole on the bottom of the phone. You should feel a little click and then your phone will restart. Wait until your phone  starts up again and if it still isnt working then do a hard reset.
 To hard reset, hold down the green send button and the red end call button at the same time and continue to hold them down as you then push your stylus pen into the hole on the bottom of the phone untill you feel the little click. Your phone should start to reset.  Be warned you will loose any information saved to the phones memory ie: phone numbers, pictures, personal settings. Anything saved to your memory card should be ok.
If your screen remains blank after trying both resets I would suggest taking it back to where you got it and and have them fix it or replace it.
Hope this is helpful.
Feb 12, 2008 | HTC Touch P3450 Smartphone
HTC Touch P3450 Smartphone Logo
1,434 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
