Question about Bang and Olufsen Beosound 2000 Shelf System
Wire has come off my beocenter 2300
Can anybody help in where i can get a manual to enable me to re fit the wire / cable that opens the doors on my Bang and Olufsen Beocenter 2300. Thanks
  • 122 Answers
Good luck one of those jobs that can take 20 mins or 2 hours. clean and lube the door guide rails.
Posted on Dec 14, 2009
    Problem Solver:
  • 10 Answers
Hi, www.beomanuals.com, free beocenter manual download . . .
Posted on Jun 02, 2009
Beocenter 7007 lights but no power
It is likely the audio output ic has failed, check the speaker wires for shorts, if okay! you will need a professional to take care of this.
Mar 21, 2012 | Bang and Olufsen Beocenter 9300 Shelf...
Our beocenter 9300 will only play at a low volume (of about 4 bars). You can increase the volume a bit, to about 8 bars, but not for long. The volume drops to about 4 bars in just a few seconds. What is...
TRY REMOVING THE SPEAKER CABLES AND LISTEN ON HEADPHONES,IF THIS WORKS THEN SUSPECT SP WIRING BUT MAY STILL BE AN INTERNAL FAULT IN UNIT EITHER OUTPUT OR P SUPPLY.
Sep 09, 2010 | Bang and Olufsen Beocenter 9300 Shelf...
How do I change the light bulb(s) on a BeoSound / overture
Remove glass doors,black panels 8 screws lift up cd clamper and detatch from drive bar at top l/h corner.Lift operating panel to gain access to cable connector behind keypad,this should provide enough room to work on lamps.
May 06, 2010 | Bang and Olufsen Beosound 2000 Shelf...
The sliding cover for the tape player sometimes gets stuck when opening.
if we are talking beocenter 9000/8000/9300/8500/9500 replace belt,clean and lube door guide rails
Oct 19, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
On our Bang and Olufsen Beocenter 9000,
if sticking is only your issues, then replace all belts. Cleaning has nothing to do with the sticking of doors.
Apr 06, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Beocenter 9300 - doors don't full open
no,motor drive on timeout.usual cause friction between door and guide rails,only way to check is to remove doors and clean/lube door guide pins.this is not an easy job,very fiddly as involves detaching doors from cord drives.you may also have low motor cct supply voltage.
Mar 28, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Broken cd player
The motor is last thing to gone before you go to service check the rubber belt which connect the motor to the door gears.Your set is 20 years old and this should be the problem and easy to fix
Feb 07, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
818 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
