Question about Whirlpool LSR6232J Top Load Washer
Washing machine will spin and drain only if I use a hanger or sdrewdriver to hold down lid switch. IS this a lid switch problem or timer problem?
    Genius:
  • 1,122 Answers
Lid switch,do you want me to show you how to bypass it?mike
Posted on Apr 20, 2009
  • Virgil Watts May 24, 2011
    Don't know what machine you have but whatever pushes the switch down when you shut the lid
    is not pushing it down for some reason. Something may be broken or the switch may be loose or out of place. If you push it down and it works it is not the timer. Do not bypass the switch I know of
    children puting their hand in it when running and tearing their hands up . Fix it right and have no problems. You may need a new switch or the plastic that pushes it down.
How do I fix a top loading washing machine that isn't spinning, agitating or draining?
if this is a top loader put a pencil into the lid switch opening if the machine spins and drains when the timer knob says it should the tab on the lid or the lid switch has failed...replace the switch or the tab that goes into the lid switch opening
Jan 26, 2016 | Amana Washing Machines
Whirlpool washer won't wash or spin or dump water
usually a broken lid switch if it fills with water and then nothing,set the timer on spin and pull out the timer,open the lid and stick a screw driver into the hole where the plastic acuator on the lid goes into the hole and push down easily and see if washer will run this is where the lid switch is and it's only a safety switch so when the lid is open the washer won't run,if not push up and down on the switch and listen for a clicking sound,no click switch is bad part number 285671,watch video
http://www.youtube.com/watch?v=Ag1eT5PrMnE
Apr 06, 2013 | Whirlpool Washing Machines
Washing machine will not drain water out or spin
set the timer on spin,open the lid and with a screw driver stick it into the hole that the strike on the lid closes down into,see if it spins and drains,if it doesn't lift the screw driver up and push it down into the hole,if you don't hear any clicking at all the switch is bad or if it does start with the screw driver the lid switch also has to be changed out.check this site out,also give the parts store the model number off of your washer to get the correct lid switch or next time send the model number and i can look up the part for you.good luck and let me know how you make out.
YouTube - Washing Machine Lid Switch Replacement (part #3949247)
Mar 27, 2011 | Whirlpool Washing Machines
It won't spin or drain. :-(
check the lid switch first - depending on the brand - some machines won't spin or drain if it thinks the lid is open. open the lid and take a small screw driver driver, press up and down on the switch. you should be able to hear it click. if it is not clicking then the lid switch is probaly bad.
some machines will drain with the lid open but not spin. if this is the case with your machine you could have other problems such as timer or motor.
May 28, 2010 | Washing Machines
Rinse problem
Sounds like a timer issue. Try this, Yes it sometimes works. Spin the timer knob vigorously six to ten complete turns. It may be that the contacts are stuck together and this frequently frees them. Timers are expensive, so this is worth a try. Good luck.
Jul 01, 2009 | Kenmore 22642 Top Load Washer
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
I think the issue might be the lid switch, but not too sure. The washing machine will fill with water and agitaite but then it stops and the water does not drain or go to spinning cycle mode. I have to...
If you put hanger in hole and push down then it works it is the lid switch. To remove take top off to get to it. From the front take a putty knife and push on each side about an inch from the side to release the clips that hold the top down. Putty knife between the top & the cabinet. Lift up and you can get to the switch. Also it could be the plastic piece that pushes the switch down is broken off and not long enought to push the switch down.
Jun 09, 2009 | Roper RAS6233KQ Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Will not drain or spin
Unless you jarred the machine it's the timer. You can check this by bypassing the lid switch and seeing if it will cycle.
Dec 13, 2007 | Washing Machines
Whirlpool LSR6232J Top Load Washer Logo
196 people viewed this question
Dan Webster
Dan Webster
Sal De
