Question about Microsoft Basic Optical Mouse USB
Microsoft basic optical mouse v2.0(black ), installation problem
My computer (VISTA HOME)is not supporting the USB optical mouse
  • 1 more comment
  • elza3eem Apr 17, 2009
    i have microsoft basic optical mouse v2.0 ,
    when i connect mouse cable in usb , appare message "usb device not recognized
    one of the USB devices attached to this computer has malfunctioned and windows does not recognize it.
    Fot assistance in solving this problem, click this message.
    i downloaded driver from Microsoft website for this mouse , but the proplem still found ....
    when i try open the mouse programe , appare to me this message : "some mouse settings might not work until you connect a microsoft mouse to a usb port on your computer or set up a microsoft mouse that uses Bluetooth technology"
    it's worked with me a week ago, but i can't understand what's upĀ
  • Anonymous May 09, 2009
    same problem as described plug in my old optical mouse all works fine ??
  • Barry Parks May 11, 2010
    More information, please. What do you mean by "not supporting" tje USB optical mouse?
5 Suggested Answers
SOURCE: Microsoft Wireless Notebook Optical Mouse 1023 Need Driver
i wanna know about Microsoft Wireless Notebook Mouse model 1023, is there any driver software need to that mouse, please tell me sir
need a driver, mouse works but USB doesn't light up
Posted on Sep 03, 2008
Benimur
  • 6966 Answers
SOURCE: Microsoft Optical 1.1A Wheel Mouse Optical - USB, PS/2 (D66-00034)
Hi again,
Appreciate the direct "Ask Me" and the repeat use of FixYa.
Interesting concern, should be pretty straightforward. Anyways, pls try to:
  • update/re-install the driver from Microsoft Download page;
  • alternately, disable the "Allow the computer to turn off..." in the Power Management tab of the USB Root Hub Properties in your Device Manager.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you again for using FixYa.
Posted on Oct 10, 2008
SOURCE: Laptop Does not detect my USB OPTICAL MOUSE and USB keyboard
I have a presario 2500 and was having trouble with my Genius Traveler 600 cordless mouse. The problem was eventually fixed by choosing a different USB port. For further discussion (since I don't come here often) you may write to me.
Cheers.
Posted on Oct 11, 2008
SOURCE: Microsoft Wireless Notebook Optical Mouse 3000 help
I had the same problem.
Press the button on the underside of the USB, the green light will flash. Now press the reset button on the underside of the mouse. Your mouse should now work.
Posted on Apr 09, 2009
SOURCE: Microsoft Optical Wireless Mouse 3000 MSK 1056 does not work !
Press down the usb while in the port then on the mouse works gr8 cheers
Posted on Oct 21, 2009
It is taking about 30 minutes, no joke, to print one page. There are long delays and then it seems to do a line and then another delay. This just started today which is a surprise as the printer has been...
Try HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP DeskJet F380 All-In-One Printer
My printer will not print black ink i just changed 3 cartridges
Oct 27, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Black lines on scans and prints HP 2727nf
Oct 27, 2010 | HP Laserjet M2727nf Multifunction Printer
HOW CAN I RECOVER MY MICROSOFT WINDOWS VISTA HOME BASIC EDITION OPERATING SYSTEM?
If you purchased a computer with an installation of Microsoft Vista you would normally have a recovery partition. On restart continually press F8 to go to the advanced boot options menu and choose Repair your computer. If it would ask for language preference choose it. Then if it would ask for administrative access go ahead and login. On the next menu choose the image restore for your system. If you have a dell it would be Dell Factory Image Restore. It would depend on the brand.
If you installed vista separately. You would need to boot up your Vista Home Basic Disc. Place the disc in the drive and restart. It would normally load your disc if it is set as primary boot. If it did not enter the BIOS then change your boot sequence to start with the Optical Drive first or you could press the key for boot selection. some would press F10 or F11 for that, but you can find it when you boot up your computer. It would be stated on the starting sequence or the bios splash. Press that key and choose your Optical drive/CD/DVD drive. Then follow the instructions on reinstalling your Vista Home Basic.
Apr 29, 2010 | Microsoft Windows Vista Home Basic Edition
I want to install a Microsoft wireless optical mouse but not sure how to do it.
With the wireless mouse you also have a wireless adapter that is connected via usb to your computer. Insert the usb adapter in an available usb port on your computer. Wait for a few seconds until windows verfies and installs the new device. Then press the sync button located under the wireless adapter and at the same time press the sync button under your mouse.
The mouse will be ready to use.
Regards,
nicolasiac
Feb 09, 2010 | Microsoft Basic Optical Mouse PS 2/USB...
Can I make this work with Windows Vista?
  1. remove the battery and try to reset.
  2. enable legacy support for usb from bios settings
Oct 06, 2009 | Microsoft Wireless Optical Desktop 5000...
Optical mouse 3000
This mouse was not supported in windows 95 os .
so you can change the mouse .And install a supported mouse in your os .
jems ....
Mar 07, 2009 | Microsoft Comfort Optical Mouse 3000...
Burner does not finalize discs
Microsoft has confirmed that this is a problem in the Microsoft products that are listed in the "Applies to" section.
APPLIES TO
  • Windows Vista Ultimate
  • Windows Vista Starter
  • Windows Vista Home Premium
  • Windows Vista Home Basic
  • Windows Vista Enterprise
  • Windows Vista Business 64-bit Edition
  • Windows Vista Ultimate 64-bit Edition
  • Windows Vista Home Premium 64-bit Edition
  • Windows Vista Home Basic 64-bit Edition
  • Windows Vista Enterprise 64-bit Edition
After you install Windows Vista on a computer that uses an SiI Parallel Advanced Technology Attachment (PATA) chip from Silicon Image, the computer does not recognize an attached optical drive as a drive that supports recording. Therefore, you cannot use the computer to burn CDs or DVDs.
This problem occurs because the SCSIport driver does not populate the correct number of bytes for an IOCTL_STORAGE_QUERY_PROPERTY Request Packet (IRP) when the device does not return a correct serial number.
Service pack information loadTOCNode(2, 'resolution'); To resolve this problem, obtain the latest service pack for Windows Vista or download the following Hotfix.
Microsoft Hotfix http://www.microsoft.com/downloads/details.aspx?FamilyId=2E692102-D483-44B0-BBFF-FA87AE019CBE&displaylang=en
Please rate this a fixya
Feb 01, 2009 | Microsoft Windows Media Player
Open Questions:
Microsoft Basic Optical Mouse USB Logo
2,060 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
