Question about Whirlpool GH7145XF Microwave Oven
Replace light bulb on Whirlpool GMC305PDS07 Microwave oven without a $150 service call. (The bulb does not unscrew from inside the oven.)
  • Whirlpool Master
  • 9,098 Answers
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
On an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Mar 06, 2009
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
KitchenAid KCMC155J 1000 Watts Convection / Microwave Oven - how to change the light bulbs - can this be done without having to call a tech?
Look for a small cover on the outside of the cabinet in the place where the bulb is. They are usually secured with a single *****. It is the only part of a microwave oven that is consumer serviceable! Remove the cover and unscrew the bulb, replace and refix the cover.
your manual is here but doesn't mention the bulb
http://www.manualslib.com/manual/88077/Kitchenaid-Kcmc155j.html#manual
KitchenAid KCMC155J Use Care Manual
Mar 11, 2013 | KitchenAid KCMC155J Convection/Microwave...
How do you change the light bulb in a JVM 1440?
1 Unplug the microwave oven from the outlet. Wait 20 minutes for the capacitor that is inside the microwave to discharge.
2 Unscrew all the screws around the casing by turning them counterclockwise.
3 Remove the cover by lifting off.
4 Locate the light bulb in the microwave. This will be located on either the right or left side.
5 Unscrew the light bulb by unscrewing counterclockwise. Some light bulbs are held into the socket by two notches; for these you will need to gently push on the bulb and turn counterclockwise to unsecure the bulb, then pull out of the socket.
6 Place your new bulb in the empty socket and secure by turning clockwise until tight, or if the bulb is one with notches on both sides, then guide the notches into the slot on the socket, push gently and turn clockwise until clicked into position.
7 Replace the cover and screw back on. You are now done and may plug back in the microwave.
May 02, 2011 | GE JVM1440 Microwave Oven
Riccar microwave oven RM 700N Light no longer works - can't figure out how to get to the bulb to replace it.
5 Unscrew the light bulb by unscrewing counterclockwise. Some light bulbs are held into the socket by two notches; for these you will need to gently push on the bulb and turn counterclockwise to remove the bulb, then pull out of the socket.
May 02, 2011 | Microwave Ovens
I have a Whirlpool GMC305PDS07 Oven Microwave combo. The microwave display shows "Door" and it won't start. The door looks fine and closes properly. Is there anything I can check or do before...
Sorry to read about your problem, I hope this helps you out.
sound like you have a defective door closed switch
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | Whirlpool GH7145XF Microwave Oven
I have a Whirlpool gold accubake microwave / oven combo model number GMC305PDS07. The microwave will not turn on and will display "DOOR". I think it is thinking that the door is open?. Please help.
Press and hold the DELAY START TIME button for +5 secs and a chime will sound. The option to toggle between SND HI and SND LO will come up, pressing Delay Start Time will change it between these options.
Jul 18, 2009 | Whirlpool RMC275PD Microwave Oven
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
Light doesn't work on my over-the-range microwave oven
Absolutely. We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Mar 13, 2009 | Microwave Ovens
The light is not on in the microwave when I open the door
Depending on the model, you might NOT be able to replace the bulb yourself.
With many microwave appliances the bulbs are located in a secure area away from the cooking area of the machine. If you look inside the oven, you should see an area that looks like a grill of sorts. This is most likely where the bulb is located and might not be readily accessible for you to replace unlike a conventional oven light bulb is.
Verify first where the bulb is located. If it is located in an enclosed area of the oven, you might need to call for onsite service from Whirlpool to replace the bulb. Most likely this is the case. And you should ask yourself:
1- Is the unit in warranty still?
2- If YES, then call Whirlpool Service to have it worked on
3- If NO, then ask yourself, how much do I really need a light, because to have someone come out and service the unit will cost about $100+ USD to get it working again.
I know this is not what you wanted to read as a solution, but it might be the only thing to do. There is no listed part number for a replacement bulb therefore, it is a service installable part only.
Hope this helps you out.
Cheers,
Keith
Jan 02, 2009 | Microwave Ovens
After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
Nov 27, 2007 | Whirlpool MH7135XE Microwave Oven
Whirlpool GH7145XF Microwave Oven Logo
1,464 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
