Svetoslav Nikolaev Posted on Mar 29, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What will be the reason for blowing-up fuses F502 and F504 of NAD S200?
Right speaker is not working and the there is a loud nois from the left speaker when cutting-off the power from the power switch.
Grubhead
Level 3:
  • Audio Player... Master 5,755 Answers
  • Posted on Apr 02, 2013
 Grubhead
Level 3:
Answers
5755
Questions
Helped
1660011
Points
11417
Fuses blow when there's an overload. The cause of this is short circuited semiconductors. I rather suspect that the main power amp device(s) - located on the big heat sink - have all gone!
5 Related Answers
Anonymous
  • 1512 Answers
  • Posted on Feb 06, 2008
SOURCE: nad s200
It is most probably a dirty speaker protection relay. gently tap the relay(the one that engages shortly after turning the amp on) when the fault is occurring and see audio returns. This should ascertain the problem. Replace it if it is a sealed type, or if it has a "lid" you can get off, burnish the contacts with a white business card, and give it a spray with contact cleaner/lubricant. Good luck and a "fixYa" rating would be great for my profile :)
Anonymous
  • 3587 Answers
  • Posted on Mar 10, 2008
SOURCE: NAD 272 Channel drop out
well..this is one for the books. Can you tell me what the ratings are between the 252 and the 752 impedance matching wise? even though it might work sometimes, impedance matching can wreak havoc between mismatched amps.
what are you driving from the 752 into the 252?
Anonymous
  • 682 Answers
  • Posted on Jul 15, 2008
SOURCE: The right channel on my NAD intergrated amplifier C320Bee no longer works.
if you did test for your cable and speaker and you find it fine-your problem will be in output stage of your amp and needs aid of service center.
Grubhead
Grubhead
  • 5755 Answers
  • Posted on Feb 16, 2009
SOURCE: NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Grubhead
Grubhead
  • 5755 Answers
  • Posted on Mar 25, 2009
SOURCE: Bryston 4b amp, left channel blows the back panel
I would check out whatever drives the left channel first. If it is a transistor, you can put a ohm meter on the terminals and see if it shows a short (amp turned off). If there are two transistors for the left channel, and you find a short on one only, replace the other to be on the safe side.
10 years and first problem to repair. When you turn on and select DVD or any other selection a very loud cracking noise comes through right speaker only. So loud (with volume tuned off too) that I fear...
I think your receiver is damaged.
Try this.
Mark the speaker wires on the back of the receiver. label the speaker connected to the left channel "Left" and the speaker connected the the right channel "Right"
Also pay attention to the polarity (positive an negative) making some type of marking on your speaker wire so you can reconnect them correctly.
Disconnect both left and right speakers.
Connect the speaker wire that is labeled "Right" to the receiver's left speaker connections only then turn your receiver on.
IF the loud noise comes back, this speaker is damaged. I am guessing that the speaker is fine.
Now connect the speaker that was labeled "Left" to the receiver's right speaker connections and turn the receiver on.
IF the loud noise comes back like it did before but now playing through the "good" speaker there is a problem with your receiver.
If so, your receiver is 10 years old. Isn't it time for an upgrade? Try ebay for good used equipment deals.
I run a sub and two sets of speakers on speaker B of my NAD C740 through a speaker selector. I think there has been a short circuit caused by the + and - wires touching. The left channel no longer works on...
Check that both left and right channels work on A speakers. If they do, the amplifier is probably good and your problem may be outside the amplifier. Try swapping the left and right speaker connections at the back of the amp to see if the problem changes from left to right. this would tell you if the problem is in the amp or out to the speakers. Hope this helps
2helpful
2answers
Nad c372 problem with left speaker output
Hiya, did you try to swop the inputs as well and see if the problem swops. Try that as the input could also be low. If so try change the cable.
If not there try cleaning out the balance pot with switch cleaner (have to open to that and only you are comfortable).
If thats not there then likely an internal problem and will have to send it in.
Best of luck
4helpful
Need user manual for setup of the amplifier.
It should say next to the speaker terminals what impedance of speaker the amplifier is rated for. You can drive any speaker within reason with just about any amplifier as long as you are not trying to attain loud levels. Here is a link to the service manual for your amplfier. It states in the schematic power ratings for 2,4, and 8 ohm speakers so you can assume that this amplifier is compatible with those impedance speakers. NAD is generally known for their beefy amplifier sections. http://www.scribd.com/doc/7234868/NAD-3020-Service-Manual
Blown Mains Fuse
You should repleace the old transformer with the new one
1helpful
Fisher CA-273 amplifier left speaker ports
fuses will be on the inside of the amp. you will have to disconnect it from the power and open the box to get at the fuses( some fuses are accessible from the outside of the amp) also, you may have blown the input or output section of your amp. this is not easy to fix at all. you can blow it from playing your music too loud or from a loud source. while the case is open, have a look at the solder joints on everything. if anything is brown, covered in white residue bulging, melted, burned or looks disconnected, that is probably the problem.
Gemsound power speaker pxa105
First,
Disconnect any input cables from the amp. Turn down the volume controls and disconnect the speakers. Power back on. If you still blow fuses with nothing hooked up, have the amp fixed.
If the fuse holds, shut down and connect the speakers, leaving the volume controls down. Power up and see if your fuse holds. If you have hum, an output transistor is most likely shorted. If you have no noise, SLOWLY turn up the volume controls and listen for the hum. If all is quiet, turn down the volume controls and connect your input cables and turn the volume back up. Noise? check your cables!
Mister Phil
1helpful
2answers
Nad s200
 Grubhead
Grubhead
SmartAviator
SmartAviator
