Question about Dell Inspiron 1521 Laptop
Screen goes blank when on battery power
Hi, please can someone help me...
My dell Inspiron 1521 works perfectly when plugged into the mains however as soon as the AC is disconnected and it is running of battery power the screen goes balnk. The computer still works, I simply just loss the screen and have to shut it down.
Is this a problem with the backlight? Seems strange that I don't loss power when running of the battery just the screen??..?
  • blazinwilly May 11, 2010
    You may have a bad battery...laptops typically go dimmer to save power when running on the battery. If it's still running when on the battery. try brightening it back up by holding down the fn key and then press the brightness up key. Hope that works.
  • 46 Answers
Two possibilities: The display is a power hog. It's possible that the battery is failing, and has enough power to run the PC, but not the PC AND display at the same time. You would need to replace the battery, in this case. Or, in Control Panel, in Performance and Maintenance, in Power Options, there should be settings somewhere for the display when on battery or AC power. Make sure that the one for Battery doesn';t turn the display off after 0 minutes.
Posted on Mar 04, 2009
Inspiron 1521 will not power up
I'd say that you have exhausted your options. You can try to isolate the power on problem by removing your your memory modules, hard disk drive and see if it at least stays powered on. Here is a link from Dell for your laptop's manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1521_Owner%27s%20Manual_en-us.pdf
Feb 09, 2013 | Dell Inspiron 1521 Notebook
Hi I have a dell inspiron 1545 laptop and when I use battery power the mouse pad works perfectly , but when I plug in to the mains , it sticks , is eratic and does not work properly please help.
May be your Power cable is faulty.
Tip
1- just use another cable and check .
2- Use another power socket, may be earthing will be issue here
Dec 02, 2011 | Dell Inspiron 15 Laptop
My insperon 1521 works perfectly on battery power. The battery charges ok when the laptop is connected to mains power. On mains power, though, the screen goes off after less than a minute after plugging...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
But, as you described, the power adapter is probably faulty and needs replacement.
Hope this helps.
Sep 08, 2011 | Dell Computers & Internet
My Inspiron 1521 enters standby mode randomly and without command to do so.
How about the battery backup - computer goes to stand by mode automatically if battery fails in power .
check whether computer goes in standby on battery only or when pluged in charger also
Oct 04, 2010 | Dell Inspiron 1521 Notebook
When i start up my dell inspiron 1521 it goes into startup mode then screen goes black.took the power cord out n it will start up plug it back in the screen will go blank again.it will run on battery n the...
I have a Dell Inspiron 1525 and had the same exact problem. I finally called Dell and they sent a tech out. They replaced my power cord and all the software. The reason for this is because Dell Inspirons has a default in the AC cords. Sounds like the AC power cord is the problem. You could find someone who has this cord and test your Inspiron with it or try calling Dell! It worked for me.
Jan 28, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Inspiron 1521 won't charge battery or turn on when I have the power cord plugged in. The power cord is fine and is plugged into a an outlet and not a power strip. I can start the Dell MediaDirect up using...
I see possible failure as the following:
  1. The power control strip on the Palmrest Assembly (The actual button under the hinge cover)
  2. The motherboard, even though the system partially functions under the DMD button, that is a very limited function of the system
Jan 22, 2010 | Dell Inspiron 1521 Notebook
I have a Dell Inspiron 1521 and my screen is completely black. Yesterday it was flickering a little here and there. Now all I can see is a very fade image of the desktop but it is still black. I tried...
plz concert with hardware vender coz it is not possible for u. if u can see perfect boot screen than u must re installing ur oprating system.that mean ur hardware is perfectly working. enjoy good luck
Jul 28, 2009 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
Dell laptop screen goes blank when ac adapter plugged in
I believe I have found the problem with the 1525 that I am currently working on which has the same problem that you describe. Ultimately I think it's a problem with the inverter in the LCD. When the laptop is powered by battery the brightness is lower than full. When I plug in the power adapter the brightness goes to "full" and I hear a faint sizzle and the LCD's backlight goes off. Same as if you hold the Fn key and press the up arrow to brighten it, it will do the same thing when you reach near the full brightness. So for now I have fixed this problem by going in the Power Options and clicked on Adjust the display brightness on the left. Slide the slider to the left on the "plugged in" part and now when you plug it in it shouldn't make it go blank. I do want to note that I hear a faint buzz coming from the LCD when I plug it in. That must mean the inverter is faulty. WAY TO GO DELL!!!!!!
May 23, 2009 | Dell Inspiron 1525 Laptop
Dell Inspiron 1521 Laptop Logo
99 people viewed this question
Alun Cox
