Question about OKIPAGE 14ex Led Printer
Unable to install oki 14ex with xp via USB port
Hi
I downloaded the latest driver for the Oki 14ex printer then add printer it seems to install ok - however I am unable to print - gives a message that the hardware driver did not install properly. Does that mean it is not compatable with xp
Many thanks
  • dglave Mar 03, 2009
    Hi
    Thanks for the prompt reply - the driver I downloaded is 252w2kGB - if this is not correct is there - another and where? - apologies for my ineptedness....
    Thankyou - the link you gave was the one I used to download the driver that seems to be giving me the problem - Thanks again
    Genius:
  • 1,605 Answers
No it means you have a wrong software for the operting system, not the printer. the latest driver may not be the correct one.
Posted on Mar 03, 2009
Hi, i had this microline 390 turbo for quite some years and today, it's been a little weird. It keep printing for no absolute reason and what it's pringing are characters that seem to be encoding...
disconnect the LPT cable, and try a usb cable, the wierd printing should stop while the cable is disconnected. I'll be willing to bet there is something trying to print or poll the printer from the computer. that is causing the random characters. check to see that there are no other printers configured g to print/connect to same LPT1 port, from an old printer installation. (thus switching to the USB cable). Be also sure to download the latest drivers for your operating system for the OKI, from OKI's website
Aug 27, 2010 | OKI MICROLINE 390 Turbo Matrix Printer
Unable to load windows got an error 0x80070057.plz help
What causes Error 0x80070057
# Windows Update simply has an issue with your "SoftwareDistribution" folder.
# This appears to be an issue with the program Netop which enters a driver entry into the enum\root\unknown key in the registry.
# You have old versions of OKI drivers installed.
To resolve this error, use one of the following methods:
Resolution Suggestion One:
# Try renaming the SoftwareDistribution folder:
Click Start, Choose Run.
In the Run box, type: services.msc
Click OK.
Right-click the Automatic Updates service.
Click Stop.
Stopping the service will take a moment.
Now rename the "SoftwareDistribution" folder:
a) Click Start, click Run, type
%systemroot%
...and then click OK.
b) Right-click the SoftwareDistribution folder, and then click Rename.
c) Type SoftwareDistribution.old and then press ENTER to rename this folder.
Now click Start, and choose Run.
Click OK.
Click Start.
Starting the service will take a moment.
NB - You will lose your update download history but this is not that important compared to not being anle to download the updates!
Now Try WU website again.
Resolution Suggestion Two:
# Customer will see error 0x800A138F when scanning for updates, but the Windows Update.log file will show error 0x80070057:
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\
{63C35530-D3DF-11D3-8F5D-0060B0A3612B}\0000]
"ProviderName"="Danware Data A/S"
"DriverDesc"="NetOp Driver 3 ver. 7.00 (2002014)"
"DriverDate"="Jan 14 2002"
"DriverVer"="7.00 (2002014)"
"MatchingDeviceId"="danware_netop_driver3"
Both the DriverDate and DriverVer are not formatted properly
Visit http://www.netop.com/tech/download/fix/fixwinup.exe
and run this executable If you are running the Netop software.
(NB - Sadly this file has now been removed from their website.)
Resolution Suggestion Three:
# Update drivers for your OKI device:
Typically folk complain of problems with OKI B4300 drivers and OKI Page 14ex drivers installed...
Visit http://www.oki.com and update your device drivers.
Jul 17, 2010 | Toshiba Satellite A215-S4747 Notebook
Windows xp printer driver for Oki 320
Install an IBM Proprinter III driver. This driver is built into your Windows system and can be found in the Add Printer Wizard.
the computer will install that driver and it will make this unit compatible with windows xp
Oct 07, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
MacBook Pro will not recognize drivers for OKI C3200N
Sir,
Go to (Start > Control Panel > Hardware and Sound > Add a device) Check for connected devices. You can also go to (Start > Control Panel > Hardware and Sound > Add Printer > Local) check the USB1, 2, 3 options is available for using an existing port. The options are LPT1, 2, 3 (Printer Port) | COM1, 2, 3, 4 (Serial Port) | FILE (Print to File) | TPVM (Thin Print) | XPSPort. Select the appropriate port and try it…..
Thanks
good luck
Aug 07, 2009 | OKI C3200n Led Printer
OKI C5650n USB port not working
Yes, well I can´t help you to solve that problem and in fact i´m hoping that you´ve already solven it, cuz right now i got the same problem with my c3450... It worked just fine under vista x64 but now on windows 7 x64 i have the same problem as you have/had!
Cheers
Jun 02, 2009 | OKI Office Equipment & Supplies
OKI 3200CN with Vista Laptop
make sure when you install you opt for USB port driver.
if already installed, uninstall, then reinstall
OKI do not support this printer very well for vista
Sep 29, 2008 | OKI C3200n Led Printer
Only printing tasks from some computers
Print the Menu Setting out on printer and menu setting out on pc. Match sure emulation matcheds on both sides. If using serial make sure serial settings match on both sides. If parallel, check the bois on the PC, change parallel port type to EPP instead of ECP or SPP.
Feb 13, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI C5200 laser printer
Delete driver, download latest from oki, reinstall, is this networked or USB?
Is printer free from error lights, check page settings.
more I think about it, it seems to be a network/driver issue.
If printer can stand alone print ok ie menu map, then it is either the cable but more often the driver.
Check IP config if network.
Fixya or post back
Jan 02, 2008 | OKI C5200n Laser Printer
OKIPAGE 14ex Led Printer Logo
576 people viewed this question
Top OKI Office Equipment & Supplies Experts
Soulvisitor
Soulvisitor
WTF Chuck.....
WTF Chuck.....
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
