Sometimes the furnace doesn't come on when it should
When I turn up the thermostat I can hear clicking but the furnace doesn't come on. After I flip the breaker switches at my home electrical panel and pull out the connect switch and put it back it in the furnace will come on. I also have trouble with it cutting on during normal use just on occasion. It doesn't always do it. What could be wrong?
  • 1 more comment
  • number1candl Mar 03, 2009
    It is an electric Intertherm furnace. It says Nordyne also so I don't know if that will help. I can't tell where the ticking is coming from. When I turn up the wall thermo. it clicks somewhere in the furnace. Can't pinpoint.
  • number1candl Mar 04, 2009
    The strange thing is......it doesn't happen all the time. When it does happen it smells as if there 's heat (burning) but the fan doesn't come on, I haven't tried the on vs the auto switch, I'll try that and see if it works or not. It also on occasion will run on and on even after its passed the temp that it's set on. Does that help with diagnosising?
  • Farley Redfield
    Farley Redfield May 11, 2010
    Is this a gas or electrical heating unit? And what brand is it? Can you tell what it is clicking? Is it a spark ignition type furnace on Gas and or LP?
    Guru:
  • 462 Answers
OK so its an all electric furnace no gas? I cant think of anything clicking on an electric furnace except the sequencers or the safety switches.
If this is whats your hearing then the fan should definitely be running.
Feel carefully around the fan motor (I assume this is in a mobile home). See if you detect any heat coming around the blower area close to the fan motor. If so the fan motor may be at fault or one sequencer may be out (the main one of course...) the thing is can you get the fan to come on by turning the auto switch on the thermostat (or if older model the Auto On switch on the furnace) to ON? If so you can "limp by and have heat til someone either checks it or you can go on deeper into it. but to go deeper you'll have to let me know you know where the elements are and that you have a volt meter. and feel comfortable using it especially on HOT wires.
Posted on Mar 04, 2009
  • Farley Redfield
    Farley Redfield Mar 05, 2009
    Sorry it took so long gettteng back, YES. I believe now your problem is a defective "sequencer switch".You have the problem by the throat - find a sequencer - wholesaler of  parts for furnaces and you can replace wire by wire, especially if you get one just like the old one. If this isnt the problem Im not understanding your symptom correctly. Infact when I have removed the switch, like this, it has came on apart when removing several times in the past.
    Sequencers can be vareious geometric configurations. These are usually a black "stack" set of switches. Look at your elements. 1 side of these elements goes to this stack or sequencers. the other side goes directly to the breakers.  Now there are also safety switches usually mounted in the face of the element base and these are not sequencers they only have 2 wires sequencer stacks have 2 wires for each element and at least 1 more wire for the fan motor and at least 2 more wires going to the 24 v transformer/thermostat circut.. (Sequencers used to be all different types but in the last 3 years this type Im discribing has been all Ive seen except for OEM manufacturer parts. Nordyne doesnt have OEM parts in this area to my knowledge).
    The problem should have reared its head by now and Im betting you havent had the problem return assuming the motor ran 100% of the time.
Furnace
make sure LP on make sure LP detector on some have a lock out turn on thermostat you should hear a click if not bad thermostat if click but nothing goes on see if 12 volts to furnace also see if hi limits are tripped they are resetable
Nov 13, 2013 | RVs
Why does my Colman EB10C electric heater start & run for a few seconds,stop, then restart & run?
check your high limit switch find blower motor and unplug white wire let furnace run it should shut off when hot enough if same problem replace high limit switch
Jan 04, 2013 | Coleman Mobile Modular Home Electric...
Furnace doesn't turn on.
When I experienced the symptoms you describe the problem turned out to be the igniter.
Dec 29, 2012 | Heating & Cooling
How can you tell iff your thermostat is faulty
the best way to tell is, attach a wire from R-terminal and W-terminal. at thermostat furnace terminals. if furnace then runs ok! its most likely the thermostat is bad. or
If the vents do not come on, have a friend stand by the furnace. Turn off the heater, then turn it on again. Your friend should hear a loud click from the relay after you turn the thermostat on. If there is no sound of a relay clicking, the thermostat is probably broken. good-day !
Jan 13, 2012 | Heating & Cooling
While lowering the thermostat the screen went blank. The a/c turned off and now nothing works. Please advise
You may have the furnace running the power to the thermostat. To check, you can see a terminal on the back of the thermostat that is marked ''C''. If it has a wire ran to that terminal, it usually means the furnace provides the power to the thermostat. If this is the case, you may have flipped a breaker or blew a fuse inside the furnace (depending on the model). You might try checking the breaker first since that is a common thing, then check the furnace and see if it has power, you might try flipping the switch ( if available) or flipping the breaker to reset it, it sometimes works depending on the problem. If it is a fuse, they are usually 4 amp fuses. The only other way to troubleshoot to see if it's the thermostat, you can take the Red wire and the Green wire off of the terminals on the back of the thermostat and carefully touch them together and see if the fan comes on, it's basically hard wiring the furnace fan motor to have power, if it doesn't come on, then the problem persist in the furnace. Hope this helps or at least sets you in the right direction. Good luck!
Mar 13, 2010 | Heating & Cooling
Thermostat seems to be working, furnace does not always turn on
Joss sounds like the anticipator setting on thermostat i would replace it with a digital it will be more actturat . The furnace has to go over temp setting to turn off
Jan 15, 2009 | Honeywell Electronic Programmable...
Honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Mar 07, 2008 | Honeywell Programmable Thermostat Heater
Heater won't shut off.
you say you hear a click. this indicates the relay is opening and closing, BUT the contacts may have welded itself shut. try replacing the relay - contactor.
Nov 09, 2007 | Heating & Cooling
Heating & Cooling Logo
395 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
