Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Water turns from hot to cold
I have the single lever. When I turn the handle counterclockwise the water temp goes from hot to cold. A little turn gives off the hottest temp water and almost all the way around is coldest water. Any suggestions? Thanks so much
  • 3starrs Mar 12, 2009
    thanks for your help. I called Moen and thats exactly what they had me do. Take out the brass clip, rotate the cartridge and reassemble.
  • 374 Answers
The valve stem has been turned 180 degrees allowing the ports to be on the side opposite the display on the chrome trim. This is a simple solution. Cut the water supply off to the valve, and bleed the pressure off the valve, remove the handle,remove the chrome extension tube behind the handle, pull the brass clip out of it's slot, spint the valve 180 degrees and reassemble. If you have an issue gaing access to the valve cartridge to turn it 180 degrees put the handle back on and carefully pull the cartridge out and turn it 180 and reinsert. This will resove your issue so that the hot is on the left and the cold is on the right. There is one other possibility and that is that the supply lines were reversed when the shower was roughed in. Either way the 180 tiurn will fix the issue. Thanks fo using Fix Ya.
Posted on Mar 11, 2009
Kitchen faucet
you have to tell me more is it single lever or hot and cold hot and cold have stems with rubber washers in end they are held in place with a crown nut ( big as half dollar) FIRST AND FOREMOST TURN THE WATER OFF AT THE BASE THIS GOES FOR HOT AND COLD I if you have a single lever faucet you have to remove the handle( also true for hot and cold faucets) after the handle is removed on single lever you have some type of crown ( looks like a rocket nose cones ) usually it is screwed on and holds some type of cartridge or ball anyway you use a wrench called a channel lock or vice grip to take apart i need more info before i can tell you more
Aug 27, 2014 | Plumbing
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
How to adjust temp control for sigle lever shower control
Temp control is only accomplished by moving handle to desired position. If your asking is the hardware that in behind the single lever going to allow for adjustments, then the answer is NO. I installed the same into one of my bathrooms several years ago and I know what I am talking about. The single handle on that type on mine starts off then cold to hot. Problem is I wait for hot water to max so I can adjust it down to a comfortable temperture to prevent being burned. I refuse to buy one for other tubs. The 2 handles make temperture much easier with less wasted water used until its hot. Remember if you decide to replace with a two lever model then you will have to replumb the pipes for a two handle hardware unit (thats the stuff behind wall that your single handle goes into to which is currently plumbed for a single handle hardware unit.)
Oct 06, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Poor hot water pressure form Delta single lever faucet
it can be adjust take handle off and remove locking collar first turn water off,
it has a metal or plastic ball with a shaft for the handle it may have spun or a washer may be bad under it,
you can get a replacement at lowes or Home depot to replace it if this is the problem .
Apr 25, 2010 | Delta Model 172: Waterfall Single Handle...
Waters hot instead of cold when you turn it on
You have to remove cartridge and rotate 180 degrees then re-install. Was it removed or replace lately?
Jan 06, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I cant adjust water temp 0n a single handle kohler shower valve
4yrs isn't very long, but I do believe the mixer needs a new cartridge in it. unless you have a loose knob/handle.But I don't thnk so. The temps should change almost immediatley. Have someone change the cartridge. It may need a special tool. If you think you can, do it yourself, the tool comes with full instructions. Make sure it does, consult with the pkumbing person .
Nov 09, 2009 | Water Heaters
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
I had installed a shower mixing valve with single lever and I had only cold water running and I wanted to test and did not work. does the shower only works when you have hot and cold water running
u have to adjust your anti scold to add more hot water most shower valves are shipped with cold adjustment primary. if still have install paperwork it will tell you how to adjust anti scold if not a remove the lever and u should see a red and blue plastic washer looking tabs those are your hot and cold adjustments slid the red one out and turn it a little counterclockwise and slide it back in place do this a couple of times till u get your hot water the temp u want
Sep 24, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
219 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
