Question about Samsung DLP HL-P5663W 56" TV
Samsung HLN 4365 wxixaa with Light engine failure????
I have a samsung HLN 4365 w that is in a repair shop and the tech is saying that a light engine needs replacement and this will cost $650.00 to replace.
The tv when first powered on, is fantastic with fantastic picture, then as it stays on, it will black out or pixalate and freeze up. Then when we turn it off, and then turn it back on, again we have a fantastic picture. So, I would think that a light engine would be a constant picture problem rather than off and on. I wonder if it could be a heating problem and a ballast problem ..? Any information that anyone could offer would be greatly appreciated.
  • 3 Answers
When the tech said light engine what he ment was DMD board, the DMD board is the most important component on the light engine and most expensive, but still a lot cheaper then the entire light engine.
The DMD board can definetly, and often does cause intermitant errors. Your problem is absolutely not the Ballast, all the ballast is supply the power to turn on the lamp.
Your tech was right to go to the DMD board, the only other option that it could be is a digital board, you would have to see if it is doing this on all inputs.
Posted on May 24, 2009
Samsung lcd went pink as we were watching. turned it off and on, still same.
Pink picture indicates a failure of the light engine. This has to be repaired by a qualified electronic repair tech. This is a common issue on some models. Have you tried to adjust color? if the color won't adjust then the light engine is in need or repair.
Mar 24, 2011 | Televison & Video
We have a samsung HLN 5065 w projection tv.
Hi,if you hear clicking it could be the board that powers the lamp its called the ballast Was the fan
running ok? You can clean it w an air pressure
can. If you heard clicking or like wanting to turn on the problem could be with the board that powers the lamp.The board it's called the ballast.If its not able
to provide the power to the lamp it will not turn it on
and the red light will blink.Also pay attention to sounds off buzzing which could indicate a color wheel issue.
Dec 09, 2009 | Samsung HLN5065W 50" Rear Projection...
2004 Samsung DLP HLN-507W1X:Flashing lights
you either need another Lamp which is very possible or Ballast Board. Ballast board is what turns Lamp on, pull back watch to see if there is a Ark coming from spark cap on Ballast board if so Lamp if not Ballast board call Mats for lamp 1-800-628-1118 OR Go to E-Bay for Lamp and Ballast Board Look under TV Parts After rereading your Post I think Lamp! Samsung OEM Had Alot of defective Lamps and do not hold up!
Sep 21, 2009 | Samsung Televison & Video
I have a Samsung SP-55W3HF and today a blue shadow starts to appear on the TV. What is the problem with the TV. Has something get broken?
It sounds like a convergence issue. Are you able to try the convergence built into the tv? If that doesn't work you will need to have a professional come out and align the color guns. Also it is always possible there is a more serious problem with internal components. If you need help finding a qualified repair tech. in your area let me know.
Thank you,
Lee
Sep 08, 2009 | Samsung SP55W3HF 55" Television
Samsung hln 61 make loud humming
yes this is a very common issue with Samsung DLp's, and it will get louder and louder until TV will not turn ON anymore. You can replace it yourself is very simple, here is kind of a guide for that http://guides.fixyourdlp.com/samsung/bp96-01579a.php and http://guides.fixyourdlp.com/samsung/bp96-01854a.php
Jun 25, 2009 | Samsung HL-P6163W 61" TV
TV SAMSUNG HLN 567W
call a repair tech for info.
Aug 03, 2008 | Samsung Televison & Video
Samsung HLN 617w1x/xaaa When I turn
blackout this screen,but hear the sound
Mar 18, 2008 | Samsung Televison & Video
56 inch Samsung TV
This shadow is called by the light tunnel in your optical engine. You can have someone come out and try to fix the light engine. I am an authorized samsung tech and about 80 percent of the time I can rebuild the light tunnel. If the tech can not fix the light tunnel you would have to have the optical engine replaced. The light tunnel is something you would not want to attempt yourself. At least you can explain to a shop what your problem is..if they have not heard of this call a diffrent shop.
Feb 08, 2008 | Samsung HL-R6167W 61" HDTV
Lower left quadrant has shadow
By knocking into the tv you have shifted the light tunnel in the light engine. The repair for this is to replace the light engine the part number is BP96-01198B you can order it from Samsung parts.com The cost for the part is 985 dollars but if you return the one the repair man takes out you get a core credit of 350 making the light engine only 630 dollars or so...You should be able to find a repair shop to put this in for labor of less than 300 maybe even 250...our shop does a Samsung for 190 Labor. Hope this helps.
Feb 04, 2008 | Samsung HL-R5078W 50" HDTV
Samsung DLP HL-P5663W 56" TV Logo
746 people viewed this question
Henry  Thomas
Henry Thomas
