Question about Garden
I want to replace the pull cord on my lawnboy lawnmower which also has electric start. The pull cord broke and the battery for the electric start is no longer functional.
  • 4 more comments
  • dave_soucie Mar 04, 2009
    hello mr jerr I have a newer lawn boy with the pull start in the upper housing, it's a model A 8239 AE. The pull cord runs up through the cover that goes over the fly wheel which also contains the gas tank.
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello mr d, that lawnboy # A8239AE,is not a lawn boy number,sorry i can't help you any more than that.
  • JERRY ABELL
    HELLO
  • JERRY ABELL
    mr d im waiting for those numbers
  • JERRY ABELL
    mr d , do you have a tecumseh or a briggs engine,the model number would help a whole lot,the model # is located on the silver tag on the engine pull start housing.
  • JERRY ABELL
    hello mr d, do you have the newer lawn boy with the pull start in the upper housing or the older moaer wiyh the pull start on the side of the engine,this is important to know.
  • 86 Answers
SOURCE: what is the 2 cycle oil to gas mixture for a 2 cycle lawnboy
20:1 gas to oil is a good place to start. Some mowers thin down to 80:1. If you can tell me the model of the mower I can be more specific, but starting at 20:1 will assure you have adequate protection for the engine. If it's exhausting lots of oil smoke after it has warmed up; you can cut back a little each time until you have minor oil smoke.
at 20:1 you need to add 6.4 ounces of oil to one gallon of gas.
Here's a nifty calculator for various ratios:
http://www.csgnetwork.com/oilfuelcalc.html
Enter 1 gallon of gas, then change the ratio number and then press calculate and the number of ounces per gallon will be displayed.
Posted on Mar 29, 2009
garing
  • 998 Answers
SOURCE: My 550 series Bolens lawnmower won't start. When
keep pushing the prime button
Posted on Aug 08, 2009
SOURCE: new lawn boy mower pull cord will not pull. Worked first 2x
Actually we ended up taking it back to the store we bought it at and since it had been less than 30-days they did not even look at it or attempt to fix it, just gave us a new one.
Posted on Aug 15, 2009
  • 1129 Answers
SOURCE: lawnmower throttles up and down
locate the carberator the unscrew the 1/2' bolt under the float bowl to remove the bowl empty and clean out the bowl reinstall making sure the o-ring is centered for the bowl it acts as a sealing ring for the bowl screw the bolt back in and tighten, this should solve the surging problem.
Posted on Sep 12, 2009
harlan301
  • 205 Answers
SOURCE: How to replace the pull cord on a Scotts lawnmower
pull the starter housing off, take out the old rope, rotate the starter counter clock wise 5 to 6 times were the to holes line up stick a screw driver throw the holes to hold it in place. feed the same ty-ip rope from out side in throw then tie off. your going to need about 6 to 7 feet. let the pulley pull the rope in
Posted on Oct 13, 2009
Pull cord won't pull on Snapper 6.75 exi
HOW TO Replace a Broken Lawnmower Pull Cord - YouTube
? 5:53
www.youtube.com/watch?v=G02OobT7fII
Oct 4, 2011 - Uploaded by donyboy73 Easy to follow video tutorial on how to repair a broken lawnmower pull cord. The procedure for this lawnmower ...
Sep 21, 2015 | Snapper Garden
I have a toro self propelled 6 hp lawnmower battery and pull start it wont start with battery but will with pull cord
Try to start it using jumper cables to boost it from another battery. If it starts, your battery needs replacing.
May 21, 2015 | Toro Lawn Mower With Toro Power Tools
Fix recoil when pull cord on sanli lawnmower broke
Take the starter assembly off the mower. Unwind the spool using whatever method works (2 screwdrivers?) until you capture the remaining. cord. Pull it all the way out. Pin the spool so that it can't retract. Remove and replace the cord. Re-assemble. Back to cutting grass!
Mar 15, 2015 | Garden
My 2004 arctic cat pantera starts with the pull cord but not with the electric start. Turn the key and no response whatsoever. Any suggestions?
check all wiring connections and a switch under the seat like lawnmowers have. there may be a cutout switch under the seat.
Feb 02, 2015 | Arctic Cat 2004 Pantera 550
How do I reinstall the manual pull cord on a 20 inch lawnboy lawn mower?
I think you need to replace the whole rewind unit as the dawgs must have engaged the starter cup if it was running !
Sep 21, 2014 | Garden
How to change the pull reel
Just click on the link below and it will have videos that will show you how to change the pull reel. Good Luck and I hope this helps you out. : > )
How to replace a lawnmower pull cord - YouTube
Jul 24, 2014 | Toro Super Recycler 21" 159cc Personal...
How do you replace the pull cord that broke?
On a lawnmower, you just remove the top housing (side for tillers and other lawn equipment). Knot one end of the cord and put it in the slot in the wheel. Make sure when you wind it that the wheel will turn when you pull the cord. If it won't turn, wind the other direction. After winding feed the loose end thru the hole in the housing and replace the housing. Attach the loose end to your handle, cutting off any excess.
Sep 28, 2009 | Garden
Lawnmower Starting Pull Cord Replaement
There will be a piece of casing that holds the starter mechanism in. Usually held by 4 screws (probably torx screws unless it's an old machine).
Undo these screws and you will find the cord carrier inside.
Observe how the starter dogs are located, and how it all goes together.
You may be able to remove & replace the cord without taking the carrier off the casing, but it is probably easier if you do.
Then you simply remove the old cord, thread a new cord through the hole & tie it. Reassemble the carrier onto the casing. Thread the cord out of the casing & through the handle, tie that end.
Then wind the cord around the cord carrier until there is a slight tension on the spring.
Screw the casing back on the mower and you're away.
Sep 20, 2008 | Garden
Garden Logo
1,529 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
