Question about Kitchen Ranges
I have a mew6630baw maytag advanced cooking double oven. after using the cleaning mode the display shows F2 and a beeping sound is comming from the display. the control panel lights up but will not respond to turning oven on. if i press the cancel button the panel clears and stops beeping for about 3 seconds and then the beep returns and F2 comes back.
    Genius:
  • 1,550 Answers
The F2 error code on this model of range indicates that the electronic oven control board detected an over temperature condition in the oven. If the oven actually overheated, then you could have a welded contact on the electronic oven control board. If the oven did not overheat, then you could have a bad oven temperature sensor or high resistance (wiring problem) in the oven temperature sensor circuit.
Posted on Mar 03, 2009
    Brigadier General:
  • 5,158 Answers
Unplug the fuse from the fuse panel for about ten minutes to see if resetting it cures it
  • 19,396 Answers
Unplug the oven and let the oven cool down, then plug back, keep the clear button pressed for ten seconds to reset , and the door should unlock.
If the door does not unlock, then you have a fault.
I tried to reset the time on my stove and it started beeping and flashing F2. why
The error code "F2" will be displayed along with a beeping sound if the ERC (Electronic Range Control) or "clock" senses a runaway heat condition during the "cook" or the "clean" modes. It could be caused by the oven temperature sensor, by the ERC or by the wire harness between the oven temperature sensor and the ERC. If the error code "F2" is displayed in the "cook" or "clean" modes only, then the problem is a bad oven temperature sensor or its wire harness. If the error code "F2" is displayed in the time of the day mode also, then most likely a problem is the bad ERC.To get the right replacement part just click on the link AppliancePartsPros,
Aug 03, 2016 | Optics
F2 &F3 error codes, oven keeps beeping, I already tried turning off circuit breaker did not solve problem
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
2. Press CANCEL. If error code
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven,
if double oven) Replace Oven temperature
sensor (RTD)
Note: Applies to all F3-E...
codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode) F3 - E3 Oven temperature is too high (Clean
mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven,
if double oven) F3 - E5 Oven temperature sensor (RTD) shorted (lower
oven, if double oven) F3 - E6 Warming drawer sensor open F3 - E7 Warming drawer sensor
shorted
Dec 20, 2010 | Whirlpool Accubake RF362LXTT Electric...
Maytag double oven is locked and won't open
Hi. Has a fault code been displayed and a continuous beeps? press and hold the cancel & cook & hold buttons together for about 3seconds then door should open.
Hope this helps.
David
Sep 13, 2017 | Maytag MEW6630D Stainless Steel Electric...
My oven comes on and reaches the right temperature but then it starts beeping and shows F-2 or an F-4 in the display window. Then it stopps cooking.
Your temperature sensor is inside the oven in the top rear section. It is metal about 3 inches long. You can remove it from inside the oven. The F2 and F4 codes is a bad temp sensor.
Nov 24, 2009 | Maytag CWG3100A Gas Single Oven
F2 displayed when using self cleaning
REPLACE THE OVEN TERMISTER PROB IT WILL FIX YOUR PROBLEM. CALL 800-614-2700 TO GET PRICE ON IT AND HAVE MODLE # REDAY
Jan 25, 2009 | GE JKP15 Electric Single Oven
Maytag Model # MES5770AAB F1 error
Hi was using the oven and as soon as it reached the tempurture i set it to the F1 went on and beeped. I hit cancel and resumed it to see if it would finish cooking and it did. I just dont know what f1-1 means and its almost Thanksgiving. Has anyone found out what F1-1 means??
Setauket mom
Jul 28, 2008 | Maytag MER5770 Electric Kitchen Range
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Oven turns off and displayes F2,F3,and sometimes F4.
5550 The error code ?F2? will be displayed along with a beeping sound if the ERC (Electronic Range Control) or ?clock? senses a runaway heat condition during the ?cook? or the ?clean? modes. It could be caused by the oven temperature sensor, by the ERC or by the wire harness between the oven temperature sensor and the ERC. If the error code ?F2? is displayed in the ?cook? or ?clean? modes only, then the problem is a bad oven temperature sensor or its wire harness. If the error code ?F2? is displayed in the time of the day mode also, then most likely a problem is the bad ERC. The access to the oven temperature sensor plug and the wires is from the back only. You have to pull the oven out of the wall (if it?s free standing) or remove it from the cabinet (if it?s built in). Disconnect the power and remove the rear cover. Check the resistance across the oven temperature sensor. It is supposed to be about 1100 Ohms at room temperature. If the resistance is incorrect, the oven temperature sensor is bad and needs to be replaced. If not, check all the wires from the oven temperature sensor to the ERC. Replace all wire nuts if any. If it is not the sensor and wires, you have to replace the ERC. To get the right replacement part just click on the link http://tinyurl.com/34ujtl , then type the model number of your oven in the search box, click on the ?search? button and in the new window type the word ?sensor? or the word ?clock? in the ?search by keyword? box and click the ?search? button. Gendos post back...
Jul 07, 2007 | Maytag MER5550 Electric Kitchen Range
F2 error, both ovens stopped working
F2 is a Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Nov 23, 2006 | Dacor ECD230 Epicure Electric Double Oven
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
