Question about Goodman GMS90703BXA Heater
Where is the heat sensor on a goodman furnace
  • Farley Redfield
    Farley Redfield May 11, 2010
    Modern furnaces have more than 1 sensor. And it depends on how it is installed on some models. Can you be specific as to why you need to know this?
  • Gregg Rene May 11, 2010
    Can you clarify please?
    Most furnaces have what is called "rollover" thermistors, in case the exchanger or the flue becomes plugged and the flame rolls over (or out) of the flamebox. The thermistor is designed to open thus cut off power to the gas valve which shuts off gas flow so you don't have a fire.
    Most furnaces themselves do not sense heat, they only generate it until a control tells them to stop - the control is the thermostat.
    Thermostats are usually located remotely to the furnace... so I need to know which you speak of?
  • 189 Answers
Heat sensor....Or a flame sensor. Flame sensor is connected to a "single" wire under the buners usually found on the left side. Heat sensors (or flame rollout switches) are found surrounding the burner box. The most common bad one will be located just above the burners. it "should" have a small reset button in the middle just between the two wires. If the furnace does light even for a short time the rollout switch is not bad.
Posted on Mar 08, 2009
My goodman GMVC95 furnace circuit board is flashing On 6 I replaced the flame sensor but it's still flashing. Does it have to be manually reset?
Alright, have you checked the low voltage fuse on the circuit board in the blower compartment? Make sure you check the roll out switches as well. If all of these issue appear to be fine then you may have a bad circuit board. There has been a bad batch of circuit boards going around many of the popular furnace brands this winter. Trane Gas Furnaces and Goodman Gas Furnaces have been effected. We sell both brands and have had to replace many circuit boards on new furnaces. Trane Gas Furnaces Installed Goodman Gas Furnace Installation Gaithersburg
Feb 03, 2018 | Goodman Heating & Cooling
Goodman dependable 92 light for 6 sec out reignights after 45 sec it does it about 4 times then nothing i turn the pwr on and of thought might be the thermocoupler or flm sensors storm knocked out air
be carefull
only found these
DF]Service Instructions - HVACPartsShop
Goodman Dependable 92 Furnace Manual - PDF documents Goodman dependable 92 furnace manual shop for goodman gas furnace repair parts for model gmpn1004 at sears partsdirect. find parts, manuals & diagrams ...
Oct 10, 2016 | Goodman Heating & Cooling
Goodman furnace furnace starts,flames start and shuts off after 10 sec. Replaced flame sensor still have same problem
if flame sensor is new, the board may not be properly recieving currrent from flame sensor to keep burners on
Feb 05, 2014 | Goodman Heating & Cooling
What's your problem? goodman furnace lights, burns 10 secs goes out
Hello,sounds like you have a dirty flame sensor. This is a metal rod on the oppositenside of the hot surface ignitor. turn off power to the furnace and remove the flame sensor, then use steel wool and clean the flame sensor and reinstall. Next turn back power to Furnace.
Nov 18, 2011 | Goodman Heating & Cooling
Goodman Model C16-28 1FF is not able to heat my basement. The burners igniting but only fire for approximately 5 seconds. This cycle continues about every 60 seconds. At times the burners only stay on for...
Sounds as though your issue lies within the flame sensor.
The flame sensor senses that there is flame present once there is a call for heat. It sends its signal back the board or ICM and the furnace operates as normal. If no signal is sent, then the furnace automatically shuts down as a safety procedure. The furnace will attempt to light several times before shutting down on a fault code or lockout.
The number 1 reason for flame sensors to fail is they are dirty. Check the sensor for dirt build-up. Clean the sensor with a damp rag or a scratch pad. Inspect the grommets for crackings. Also check and clean all grounds. If this doesn't work, you will need to replace the sensor or call for a service technician to ensure the sensor is the only issue at hand.
Jan 08, 2010 | Goodman Heating & Cooling
Goodman furnace
you should not need the owners manual. most likely you will find a chart listing the diagnostic codes on the inside of the door to the blower compartment. diagnostics are printed next to the wiring schematic. the most common problem on this style furnace is just a dirty flame sensor. a small piece of fine grit sandpaper and a 1/4" nutdriver is needed. the sensor is located in front of the burner on either the far left or right. be carefull....(do not remove the hot surface ignitor that has two wires). you want the part that has only one wire connected to the sensor under the buner. pull it out and sand the dirt off of the metal rod. reinstall and enjoy your heat
Mar 22, 2009 | Goodman GMS90703BXA Heater
Is a patriot heater comparable to a goodman heater
The Patriot 80 is an oil furnace made by heat controller, To my knowledge Goodman (aka AMANA) does not make an oil furnace.
Feb 23, 2009 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
717 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
