Question about Intel Motherboard
SATA Raid card on PCI unable to detect eSATA Hard Drive
I have installed a VIA VT6421 Raid controller card on my PCI Motherboard running XP Pro. I do not want to run my main drive off of the Raid Card with the XP pro installed, but only want it to connect an external Hard Drive with a USB and an eSATA port to enable faster transfer to and from my external Hard drive. The card is shown as being enabled under hardware profiles, but when i connect my external drive, it does not show up under my computer or hardware profiles. It operates ok via USB I just cannot get the eSATA to work or display my external drive using eSATA only. Any ideas as I have not had any experience of RAID cards or SATA before. Thanks.
  • 2 more comments
  • pioneer8500 Mar 03, 2009
    Thanks for the reply, the enclosure is a 3.5 eSATA 2 APEX PLUS, it has it's own power supply. I really do not know anything about BIOS, I have not had to alter any BIOS configurations before, I have installed the driver and XP states the card is enabled, the card has 1 IDE port 2 sata and 1 eSATA. I have not tested the IDE or the SATA ports yet only the eSATA. But as my drive morks fine via USB it should be OK on the eSATA port also? Any suggestions would be much appreciated, especially if I have to alter BIOS settings, Thanks.
    This is the first time I have tried to use this or any RAID controller card, I just wanted to add some extra ports onto my PC with the faster eSATA connection. The computer management section of XP shows no Hard drives other than that connected by IDE or USB, no external drives show up by connection through eSATA hardware configuration states that the RAID card is enabled. Any ideas, Thanks.
  • Aenim4 May 11, 2010
    did you connect any other hard drive to the eSata port before? if so,did it work?
    You won't have to alter any BIOS setting, but the RAID card itself might have (I'm trying to speak as "easy" as I can) some sort of independent BIOS, where a few settings can be made, like the set up of a RAID configuration, which is what the card has been designed to(even though you maybe bought it just to have a few extra connection for hard drives on your pc.).
    What drive or enclosure are you using? does the drive have power?
    Does the VIA RAID card have some low level configuration utility(BIOS like)?
    Scholar:
  • 157 Answers
If you install the raid controller drive,it means it will shown the drives..but it not shown? is this what you mean? did you try to see in the computer management? if you dont know, check this out..right click my computer-manage-select disk management and check if your drive is there......this is only what i know about what you mean.
Posted on Mar 03, 2009
I have an Intek DG45ID motherboard, installed a Fasttrak TX4650 RAID card in the PCI-X x1 slot. The motherboard does not get past the BIOS post in the boot process, just after showing the boot options a...
It seems that the card might be faulty. If there were incompatibility problems, they would normally show up under the operating system (Windows, Linux, etc), not during the booting process.
From your description, I suspect that the card's BIOS is corrupt. Try getting a replacement under warranty and see if the new card works normally (it should).
Mar 13, 2011 | Promise FastTrak TX4650 4 Port SAS RAID...
After installing the card my PC won't boot. Went into the BIOS and disabled booting on this card but still won't boot. Running Windows XP 32 bit system. I believe it has something to do with the RAID...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
dont forget to vote
hope this helps
Feb 02, 2011 | Vantec UGTST310R PCI Host Card 6 Port 4...
Problem using VT6421 card as extra IDE port. I
First, you have to know if all driver components is installed in your computer, I'm talking about your motherboard make sure that all the drivers is installed.
View the status of your device driver.
If you are using Windows base Operating system like Windows XP open this menu:
Start Menu > Control Panel > System icon > go to Hardware tab > click Device Manager
Look for the question mark, it indicates a not working device.
VT6421 is a Serial Raid Controller
http://www.via.com.tw/en/products/peripherals/serial-ata_raid/vt6421/
Refer to the product specification of your motherboard, view this site:
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2314
Download and install the Device driver for The Raid Controller of your Motherboard
Jan 13, 2010 | Intel Motherboard
Can't connect SATA Hard Drive to MSI PT8 Neo-V Mother Board
You tell where in the System or in the BIOS. In BIOS on the SATA Mode or RAID Mode while in the System you install RAID Software to recognize and detect any SATA or RAID Hardware.
Sep 29, 2009 | MSI PT8 Neo-V Motherboard
NO INTTALEDWIN XP IN SATA HDD
you need your windows xp disc preferably slip streamed with SP 2 or SP 3 and then you should be able to install it onto your sata hard drive.
If you are having issues then you may need to extract the sata drivers onto a memory stick or floppy disk and press F6 before windows xp loads and specify to use the sata drivers which you can download from the motherboards manufacturers website generally as a zip file which you will first need to extract into a folder.
If that does not work using the memory stick you can use nlite to slipstream the drivers with your windows xp disc :
Nlite download
if you need more help post back
Apr 11, 2009 | Mercury KVM800M Motherboard
Harddrive is not detecting bios
get a hard drive kit that will connect it via usb or get a PCI card that will allow you to install the PCI card into a PCI slot and then attach the hard drive to the PCI card ( ensuring you select the correct PCI card ) ie if its a sata drive then get a sata PCI controller card and if its IDE then get an IDE PCI controller card.
Also check for motherboard updates for your computers motherboard and also check in the bios to ensure LBA is enabled and that its detecting the hard drive.
Apr 10, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Pci ide controller for third hard disk
You need to enter into scsi bios first, then do an autodetect for hard drive, this will set the IDE/SCSI hard drive on raid controller.
To enter SCSI control you need to press the same key stated on screen on startup (F6 I assume) I think F3 is just boot settings.
If the card do not enter regularly in CMOS settings for the raid then this card is defective.
Mar 28, 2009 | Sabrent SBT-RDIT PCI IDE Silicon Image...
SATA RAID Controller Card Problem?
You are almost there. Go into your BIOS and enable RAID. Then your raid bios should show up on next boot.
Feb 15, 2009 | Intel Motherboard
Intel Motherboard Logo
625 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
