Carrier Air V roof mount with remote. Does not cool. On light blinks 5 times then repeats blink code. What does the 5 blink code mean?
  • Anonymous May 01, 2009
    Same problem--Carrier Air V doesn't work--won't turn on. Green indicator light blinks 5 times, then off.
    Any help?
  • Brian Conley
    Brian Conley Apr 29, 2013
    I had the same issue. I spoke with Camping World and was told to replace the TOP unit of my camper. Dometic told me the right unit with the right conversion kit so I could continue to use my interior AIR V portion. Installed today, very easy to do. Still having the same issue.
We have the same problem as of this morning . . . don't have the fix yet, but have located (2) manuals that I will enclose the links for. The 5 flashing green lights is mentioned in the "Service Manual" in Section 2 "Troubleshooting" with 5 possible remedies. Manual http://www.transportaircon.carrier.com/Files/Bus/Local/US-en/T298.pdf and Parts List http://www.transportaircon.carrier.com/Files/Bus/Local/US-en/T298PL.pdf We're under warranty so will take our RV in ASAP
Posted on Sep 05, 2009
  • mavis1957 Sep 05, 2009
    Additional info to my first post . . . the 5 flashing green lights (also known as priority error code 4) is "Compressor Drive Malfunction". The only allowed modes you should be able to get during this error is the FAN and the FURNACE (propane). Found that in the service manual under Self-diagnostics Function Table 2-1.
This means....
The system has locked out due to "Compressor
Circuit" being interrupted for abnormal reason
during operation. This can be caused by power interruption
or voltage drop (Brown--Out). The
electronics monitors the voltage to the unit and will
lock--out for safety. To 're--set", disconnect the 12
VDC from the electronic controls for 15 seconds and
re--connect. If the alarm comes back in, check the 115
vac with ampmeter to determine unit amp draw (with
compressor and fan running) is within specifications
according to unit model.
Posted on Feb 02, 2013
    Guru:
  • 462 Answers
Often the legend for the code is located on the indoor panel close to the power and refrigerant lines. (I'm going to say what Ive seen now) Right hand side facing the indoor unit is the general side its on but yours may be different because I believe the lines and electrical can be installed on either side depending on needs of the application. If it has a plastic cover a few Phillips screws out and the cover will come off.
Wish I had more information or a pic and or a model number although its not a sure thing, maybe I could help you out better.
If this helps you please grade me accordingly and GOOD LUCK.
Posted on Mar 03, 2009
WHAT IS WRONG WITH MITSUBISHI TV MODEL WS65819 THAT POPS ON AND OFF?
shutdown is happening= If set has been unplugged plug it back in and turn set on--when green power light goes off in a few seconds:
On front of set (not the remote) press and hold both the Menu and Input (Device) buttons at same time and hold for at least 5 seconds---then release both.
Power light will blink an error code like 2 blinks, 2 blinks pause and repeat it for a total of 5 times.
Let me know what error code is and I will tell you what it means.
SD TECH
Apr 26, 2012 | Mitsubishi WS-65819 TV
Looking for a sky remote control code for beko.
Hello
The three digit Sky remote code for Beco TV are:
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
Aug 12, 2011 | Televison & Video
After a thunder storm my roof mounted Carrier cooling/heating unit stopped working and now does nothing. Changed the time delay fuses and checked the circuit breakers and they seem fine. Is there a reset...
You may have a circuit board problem. Make sure you have power to the unit first. If you can, get on the roof take the access panel off to the electrical components. Most carrier circ boards have a flashing light display on the board itself. On the back of the panel you just took off should be a kiosk that tells you what the flashing means. If the light is dead, no color but you are sure there is power to the unit, the board is bad or there could be a fuse blown on the board. Most circ board fuses are a small 3 or 5 amp blade fuse mounted right on the circ board. I have seen many a carrier board burn out because of lightning. I hope this is not the case for you, as carrier boards are just a little expensive. Hope this helps you get some air back. Mark
Aug 01, 2011 | Heating & Cooling
Carrier spit type air conditioner 5 blinks
Hi, you should have a error chart on one of the panels of the unit that will tell you what the 5 blinks mean. It will be pasted on the unit inside some where. Let me know what you find and we will go from there. Merry Christmas,
Shastalaker7
Dec 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Gas Furnace runs fine randomly stops blowing LEDs flash
That blinking light may be the diagnostic light. Count the blinks next time it fails. Carrier units will have two different blinks depicting the error code such as one blink followed by a pause than 3 blinks giving you an error code of 13. Then look at the wiring diagram, it will have an error code chart telling you where to start with your diagnosis. You already know that if you remove the cover it erases the error code, so look thru the small window first.
Nov 30, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Fan Runs, AC Doesnt, Blinks 5 times
Need to look around and should have an error code and give more detail of what the problem is. If you post that i can maybe help you more. I need to know......
Aug 19, 2009 | Dometic Rooftop RV Air Conditioner
Indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at danielabrewster@yahoo.com
Thank you very much.
Mar 14, 2009 | Friedrich MR18Y3F Split System Air...
Thank you. there are some other signs i don't know about.
The black triangle means AUTO, means the fan speed adjust by itself from high-mid-low speed depending in room temperature but the unit is cooling for this function the same COOL mode. Plasma is in the remote control but it never mention in the manual.
If the unit dont cool check your temperature setting and mode setting it should be in cool mode and temperature setting should be 18C. But if still don't cool check some error code like blinking light at the indoor panel check how many blink appears to get the correct error code.. If the light is blinking 3 times it means that the room air or coil sensor is defective.
abc4048.jpg.
Apr 28, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
2,559 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
