Question about Saniflo & Saniplus& Macerator Pump
Sanishower operated for short time and then just went to a buzzing noise - first time operation - any suggestions
  • NannySarah Mar 31, 2009
    I'm researching to figure out what the problem is, my unit has been in use for a couple of years but only occasionally as it was in a guest bathroom. I'm now using the shower connected to the sanishower at least 3 times a week and its refusing to drain the water.. Then it makes the stupid buzzing noise. I'll post back if I find more info!
It needs cleaning out regularly - at least once a year! We have one fitted to a shower that is used daily. The small amount of hair - that falls out every time hair is washed under the shower - builds up and clogs up the pump. We are on our second pump, the first installed just over 10 years ago, this one is under 3 years old and it already looks like it will have to be replaced.
Posted on Jan 26, 2010
  • 37 Answers
The buzzing is due to the fact that the motor is unable to rotate so I would call a sani engineer to come and inspect it. You have a 2yr warranty so should the unit be defective you will get a new one.
Posted on Feb 26, 2010
Sort of... Refer to the saniflo website, they have a Service Engineer page with phone numbers that are area specific. http://www.saniflo.co.uk/Engineers.aspx
Posted on Mar 31, 2009
  • jka5412918 Jul 05, 2011
    Install fine mesh clean out screen in your screen shower stall drain. If you do not, hair will build up and get caught in the macerator cutter blades and/or the pump impeller/diaphragm. This will stop or restrict pump operation and eventually and burn up your pump motor. These should be available through Lowe's or Home Depot, or you purchase plastic or stainless fine mesh screen and make your own.
What causes my laptop to make short beeping/buzzing noise?
What you describe almost certainly translates into those indecipherable buzzing sounds that suggest the state when the audio hardware is getting rubbish input signals - due to the hardware crash - and thus producing rubbish noises. This does not necessarily suggest the audio hardware to be the faulty component; it can be any combination of components, unfortunately.
Also it is possible that your laptop increases temperature over normal indications..
Download speedfan software(free) at http://www.almico.com/sfdownload.php
and monitor cpu temperatures and hdd temperatures whether are in high value or not
May 26, 2014 | Compaq Computers & Internet
Buzzing noise
follow this steps and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out t
urntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Oct 23, 2013 | Panasonic Microwave Ovens
I'm not sure why but since the last cold snap of -27 degrees here in quebec my montana SV6 has both cooling fans stuck on. The car starts fine and then after about 10 seconds after the start there is a...
I'm not sure the relationship, but if you have a rear heater A/C system in the van. The rear heater core and A/C components are located in the right rear. The buzzing noise sounds like a relay shorted, the buzzing is it rapidly turning off and on. It may indicate an electrical short in the heater A/C system which has a variance on the fan operation.
Jan 30, 2011 | 2007 Pontiac Montana
All radioes in my home have a loud buzz. started buzzing two days ago. have not plugged in anything different.
I assume this is on AM as FM would typically not do this.
You have a noise generator interfering someplace. I suggest you use a battery operated radio and tune to the buzzing.
Then turn off your main breaker to your house. If the buzzing remains, the problem is external to your house. It MIGHT be a bad insulator on a power pole. See if your electric company will investigate this.
IF the noise totally went away when you killed the power to your house, turn off ALL the breakers then turn on the main and one by one turn the brealers on till the buzzing returns. When it does, analyze what is on that breaker.
Some common in house sources: Bad door bell transformer, ionizer or electrostaic air cleaner, flourescent lights and CFL bulbs, Bad connections in wiring (very dangerous), switching power supplies and "wall wart" adapters to name a few.
Mar 13, 2010 | Motorola Spirit HP 2-Way Radio
It is making a bad humming noise when turned on no heat?
Hate to say this but that bad humming is your magnetron that is buzzing and not operating correctly. A bad high voltage Diode can cause this as can a shorted Capacitor. However about 50% of the time it is the magnetron itself with an internal RF oscillator that is stuck. So you have a 50 - 50 chance of getting off with a reasonable repair cost.
Jan 17, 2010 | Maytag MMV5100A Microwave Oven
Loud buzzing noise when operating
This is most likely a shorted high voltage rectifier diode, but the magnetron may be bad as well.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
Info on ordering Sharp UK parts / spares is here.
Jul 10, 2009 | Sharp Microwave Ovens
Turn headlight arm off and buzzing sound under the hood
change the part that its not comfortable in yore buzzer
May 02, 2009 | 1993 Honda Accord
My computers hard drive makes a Buzzing noise
I would suggest you back up all your data as the hard drive appears to be failing. i presume you are certain it is coming from the hard drive and not a fan ?
Feb 21, 2009 | HP Computers & Internet
Loud humming or buzzing when set is in operation
Does the picture gets distorted in any way when you hear the buzzing noise?
I would suggest to check all the cooling fans for proper operation.
Jul 16, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Saniflo & Saniplus& Macerator Pump  Logo
1,821 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
