Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow will not come back on
I was vacuming with my Rainbow, picked up some sheet rock debris from a repair. It caused the water to foam up. I changed the water, but now the vacum will not come back on.
  • Rainbow Expert
  • 324 Answers
Bad idea.... I think the foam got through the separator and into the fan system. When it dried it hardened and now it need to be taken apart and cleaned.
Turn it on for less than 1 sec and if you hear motor making humming sound - it is ALIVE and cleaning (maybe new fan blades too) may be all that it needs. If no sound at all it may be KAPUT. You must have smelled something burning when you turned on and it did not work.
for D4 and SE models - When cleaning I would recommend to replace bearings as they are not that expensive and if you took it apart - maybe a good idea to replace them. Also you probably will need a new gasket as when taking old one off (it is glued) it may rip apart.
For e-series - you will need a new HEPA filter.
(parts HERE)
For Parts see
Posted on Mar 12, 2009
Hi, each time i turn on the vacuum cleaner, the water in the tank will bubble and foam causing an overflow although the water level is just right. i will have to throw out the water and refill again....
Try changing the water before you turn it on the first time -- that will probably help you resolve the issue. It seems like there is probably some sort of soap or carpet shampoo in the system causing your foam issue. If your carpets have been shampooed or if you have spilled soap or detergent on your carpet at any point, the vacuum is probably picking up remnants of the soap when you are cleaning, and it is working its way into the water supply of the vacuum. This will continue to happen until you have completely removed the soap from your carpet -- and if you haven't cleaned out your vacuum very well. Try rinsing out the hoses and water tank really well, to make sure that the soap is not stuck in the vacuum itself and give it a try. Hopefully just rinsing out the machine will fix the problem.
May 29, 2011 | Rainbow Vacuums
Was running fine and then just shut off
You may have too much water in it. And if you add deodorizer to the water, it sometimes can cause too much foam causing the vacuum to shut off.
Jim
Sep 28, 2010 | Rainbow E series Canister Wet/Dry Vacuum
There was a foam piece above the motor of my rainbow d4c power nozzle. When I took the plate off it desintigrated and fell off. Was that supposed to be there? If so how do I find a replacement?
Hi, the only way to replace that, is go to home depot, or where ever, and buy some window seal foam, or door seal foam or what ever type, that matches your foam best, and put it on your self. You could also send it to me, and I will do it for you. I am a Rainbow seller and a Rainbow expert.
I use foam that is the soft kind, that is like the original Rainbow foam on them, and is about 1 inch wide, and about 3/8 to 1/2 inch thick.
It is self adhesive on the back side of it, that you peel off the paper cover off of it to stick it on.
If you have any more questions, let me know.
Thank you,
Ralph
May 21, 2010 | Rainbow 75th Anniversary Canister Vacuum
E series Canister Wet/Dry Vacuum: My tank foamed up into the motor and now the rainb...
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 17, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Overflow .. HELP
Thank you,
Ralph
One other thing, water sucking through your vacuum should not hurt it. It is not good though, but will not make it not run.
Thank you again,
Ralph
Apr 21, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Jhe4576. I own a Genie SV125Q, 5 gallon wet/dry
Where did you buy this unit from? Go back there and ask if they have filters for yours. Otherwise look in the Yellow Pages for vacume cleaner repair shops. Sometimes they have all kinds of filters for all kinds of vacumes. You can try places like Wal Mart. What you want to look for are filters that will work with your unit. The foam filter you refer to is called a pre-filter. It traps the bigger particles so they won't damage your paper filter or clog it up especially if it's wet stuff you're picking up. You can remove that foam filter and gently wash it out in the sink with a mild dishwashing liquid and warm water. And even sometimes if you have time you can wash a paper filter out by hosing it out from the inside, with just a gently rinsing on the outside. Don't use any solvents on it just soap and water. And don't use high pressure either, as it will destroy the paper. I have cleaned my paper filters several times before I finally had to replace them. You can also look at places like Lowe's. They carry shop vacs and a whole assortment of attachments as well.
Mar 07, 2010 | Vacuums
Vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Oct 25, 2009 | Shop Vac 84M200 Wet/Dry Vacuum
Rainbow vauccum D4C model
I think you made mistake of connections when reassembling the unit or place motor in wrong direction. Please open it again, if you opened it before, and check above said hints.
Sep 18, 2008 | Rainbow Vacuums
Loud rainbow and water leaking
If pieces are missing or broken I would try and replace the piece. You can usually get these items cheap on Ebay.
Apr 08, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow dc4 vacume
Take off the round flat water seal, carefully, you will have to glue it back on, remove those screw to take off the bottom piece.
Jan 03, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
382 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
