Question about GE JVM1870 Microwave Oven
Ge jvm1870 it won't heat anything, all other items work
It quit working when baking a potato
  • William Miller
    William Miller May 11, 2010
    Sorry
    but your subject line was too long and got cut off.
    When you hit Start to
    cook, do the inside light and turntable come on?
    Any unusual noises? Is
    it louder or quieter than usual?
    We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
    What is the full model number with suffix, such as JVM187-WH001?
    These answers will help
    me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
  • William Miller
    Sorry
  • 6,784 Answers
Ok, if this unit has stopped heating, this will confirm a major fault within the Magnetron. this device is responsible for the heating affect and, you will need to replace this damaged part in order to restore proper heating functions in you microwave oven.
Posted on Jun 01, 2009
While baking a sweet potato, the potato exploded and caught on fire. The microwave no longer works.a fire bro
I haven't heard of such a thing. You must have cooked it until there was no moisture left in the potato. That would also account for the failure of the oven. It would be the same as no load in the oven.
A thermal protect part is your current problem.
Apr 02, 2014 | GE SpaceMaker Microwave Ovens
Panasonic microwave problem help needed
Dan, That unit has an inverter, that is the power source for the part that puts out the Microwave energy called the Magnetron. The inverters are expensive and I stopped doing warranty work for Panasonic beacuse of them. Some pencil pusher somewhere though it was a great idea to replace 3 common fairly inexpensive parts. with that dang inverter. Microwaves have come down a lot in cost, I would buy a new one without an inverter. Sorry, wish I had better suggestions, I DO NOT LIKE THEM. LOL Sorry! Panasonic and their distributors are always out of them and there so expensive no one wants to stock them. I have had new ones sent to me that were already bad.
Aug 20, 2017 | Microwave Ovens
Microwave won't restart after baking potatoes.
If your microwave is not a convection then the moisture most probably is somehow getting to the controls as potatoes has quite a bit.
Oct 27, 2017 | Emerson MWG9111SL Microwave Oven With...
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
I baked a potato for 10 minutes, burnt it, and microwave oven quit working. Nothing works. Any suggestions for a reset button?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Jul 03, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Heating the cup more than coffee
make sure the stirrer motor located under the outer cover that distributes the microwaves is turning otherwise you will get hot and cold spots in the oven cavity
Apr 30, 2010 | GE JVM1870 Microwave Oven
BAked Potato caught on fire in GE Microwave
Fuse is behind the control panel. Has cavity sensors and a magnatron thermal disc also. Start with the fuse and then pull it down if not the problem. Eric
Aug 27, 2009 | GE Profile Spacemaker II PEM31 Microwave...
Runs but won't heat
Does the turn table and interior light come on?
Nov 25, 2008 | GE JVM1870 Microwave Oven
I bought a ge microwave 5/20/08. I have used it several times and it has worked well. Today I was cooking baked potatoes. I usually do them 1 by 1 and then put them in the oven for a crip skin. After...
It should default to the high power level without your having to select that.
But if you think it may have a problem, you could unplug it for a few minutes then plug it back in and try again.
After that, if it's not acting as it should according to the owner's manual, it may need service.
If so, since it's under warranty, I would let GE fix it.GE Customer Service is online here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 25, 2008 | GE Microwave Ovens
GE JVM1870 Microwave Oven Logo
384 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
