Question about Kenmore 62622 Electric Dryer
I need to change the dyer cord from a 4prong cord to a 3prong cord. Is it possible? It is model number M90825760.
  • Kenmore Master
  • 5,568 Answers
If you have a digital camera, you could take a picture of the plug (several different angles) and your outlet then go to one of the large chain hardware stores, camera in hand, and ask for an adaptor between the dryer's plug and your outlet. It may not be necessary to rewire the dryer at all. If they don't have one, keep reading.
The change probably is possible since dryers generally use a 2-phase connection at the most but I wouldn't recommend that you DIY. You are dealing with a line voltage whcih could be 220 and a circuit capable of supply fairly high (20) amperage.
This combination could make toast out of you if improperly wired. Any competent electrician can determine how to do the conversion with a few measurements.
There is an exception; some mfr.s have pasted a large label either inside or out on the larger panel that contains the electrical diagram of the machine.
With some care, most laymen could determine how to make the change.
Posted on Mar 03, 2009
How to change from 3prong to 4prong on model FLSE60RGSI
I Am going to replace the control board to discart the possibility that I might have a brand new defective board on my hands
Feb 20, 2014 | Frigidaire FEX831CS Top Load Stacked...
Can't plug 400watt ballast into a digital timer,bulb won't light.
How did you connect the 2 cords if they don't match up ? Usually the cord configuration on just about anything electrical is for a reason . It is to keep from plugging inthe wrong things ! It is possible that your digital ballst won't run your fixture due to miss matched intternal parts . One may be magnetic and one digital electronic .
Aug 23, 2012 | Garden
Can I go from a 3prong outlet to a 4-prong outlet? If so, how can I wire it. Thanks
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Jan 27, 2011 | Amana Dryers
I have a used dryer that 4prong electrical cord and my old unit only uses 3
you can change the cords it is easy, take the back plate off both machines and wire the three the same as the old one. Hope this helps tim
Aug 28, 2010 | Whirlpool Dryers
Trying to replace a 3prong plug with a 4prong plug
Ok, so you currently have a three prong cord on your dryer? Your house has a 4 prong receptacle? Ok so now you've purchased a 4 prong dryer pigtail? Be sure cord is unplugged. Remove cover of junction in back of dryer. You will see three terminals. They should be labeled something like L1,L2,N . ON one terminal you well see a small ground strip This is currently connecting the neutral terminal to ground. On the new cord connect the outside two conductors to L1 +L2 connect the white conductor to the N terminal. Connect the green (ground) conductor to the frame where the copper bonding was. This seperates the neutral conductor from the equipement grounding conductor.
Jul 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Prongs on dryer
Take old cord off. Remove wire or ground strap connecting dyer frame to center (nutral) terminal. White wire goes to center terminal. Green wire to frame (ground) Red and Black wires go to two remaining terminal, order really won't matter.
Sep 28, 2008 | Whirlpool LER5636P Electric Dryer
II HAVE A DRYER 4PRONG POWER CORD \. HOUSE OUTLET THREE PRONG NEDD TO CHANGE POWER CORD.DRYER INSTRUCTION CONNECT 4 TERMMINAL.WHAT HAPPEN WHEN CONNECT THREEN TERMINAL.
Your issue is as follows;
"iI HAVE A DRYER 4PRONG POWER CORD \. HOUSE OUTLET THREE PRONG NEDD TO CHANGE POWER CORD.DRYER INSTRUCTION CONNECT 4 TERMMINAL.WHAT HAPPEN WHEN CONNECT THREEN TERMINAL."
A 3 prong cord should be wired as follows:
1. 1 end of cord connects to 1 outside terminal.
2. The other end of the cord connects to the remaiing outside terminal.
3. The center wire connects to the center terminal.
4. A separate ground wire should be attached from the dryer chassis, then to a metal cold water line, or an exterior grounding rod.
In an effort to improve the quality of my answers, please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 17, 2008 | Whirlpool Dryers
Kenmore 62622 Electric Dryer Logo
109 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
