Question about Thermasol Steamshower Generator AF Series - for 140 Cu. Ft. - SSA-140
Unit not working - don't know how to remove
We moved into this house about 8 yrs ago and it has a Thermasol steam bath generator in the basement and it is not working. I want to know how it is hooked into our plumbing system and what it does. It takes us a very long time to get hot water in our bathroom. Could this unit be the problem? Is it difficult to remove?
  • 105 Answers
This unit is hooked into your plumbing system via a water line from either the hot or cold,...there will (should) be a shut-off valve to this steam unit that is either on or off,..it doesn't have to be off because the water doesn't run through it unless it is turned on. How it works is water runs into it, gets turned into steam and sent up to (i presume) your shower module. The reason for the long wait for hot water is that your hot water maker is a longway from your bathroom,...that water is traveling a long way to get to your bath,...common problem,....you can get whats called a "recirculating hot water line" installed,..simply another water pipe gets installed parallel to your existing hot water line, connect it into the existing hot line as close as you can get to your bathroom, put a little pump in line, and wah lah you have hot water circulating in that now "loop" so when you turn on tap, the hot water is closer,....removing the steem unit is easy but have a pro-electrician do it because these units are usually 220 volts and thats the one that'll kill ya if you touch it wrong, whereas 115 volts just makes ya jump.
Posted on Jan 06, 2010
    Problem Solver:
  • 11 Answers
The unit willnot effect any water delivery anywhere in your house.
Posted on Apr 21, 2009
Light flashing no steam
Please call Thermasol tech support at 800-776-0711 and our techs will gladly help you out.
Jul 06, 2010 | Thermasol Steam Bath Generators - Ambiance...
TIML light is on and nothing works
Please contact Thermasol tech support at 800-776-0711 and our techs can help you get your unit running if you call will model and serial number will be very helpful.
May 21, 2010 | Thermasol Steam Bath Generators - Ambiance...
I have an old thermasol steam unit 84 salvaged from a bath reno. there is a check valve on one pipe and a union fitting on the other. unfamiliar territory, how do i hook it up and what potential problems...
Check valve is the cold water inlet---valve keeps water from siphoning back out causing unit to boil dry. Probably is quite a bit of lime inside from "hard" water
Feb 06, 2010 | Thermasol Steam Bath Generators - Ambiance...
The steam shower reads ttmpl
This is a temp sensor low or disconnected contact Thermasol at 800-776-0711 and our tech support team can help you out.
Feb 02, 2010 | Thermasol Steam Bath Generators - Ambiance...
TTMPL code showing on my Signature series control panel. ???
I have a Thermasol steam generator which had the error code TTMPL and it had to be replaced by the manufacturer. From memory, the error code might stand for "tank temperature monitor pressure low" or something similar. As an aside, the replacement generator just started to show the same error message -- so now I'm two for two -- and not entirely happy.
Jan 16, 2010 | Thermasol Steam Bath Generators - Ambiance...
Hi, i have a new pro from thermasol steam gen.
Hello. Your thermasol pro is an excellent product. I am going to give you a link to the Thermasol Troubleshooters guide which will allow you to go step by step through all of the possible issues. And then, if you are still having problems with your Thermasol it will give you a direct phone number to call Thermasol.
http://www.thermasol.com/images/pdfs/81110.pdf
Regards, and Happy New Year. Enjoy your steam bath! Joe
Dec 31, 2009 | Hammering
Power flush problems Pro 240 -locked out at 1000hrs
This is a communication error please contact Thermasol tech support at 800-776-0711 and we can help you out.
Dec 19, 2009 | Thermasol Steam Bath Generators - Ambiance...
Water flows thu steam outlet consant
Please contact Thermasol tech support and we can help you out at 800-776-0711
Oct 21, 2009 | Thermasol Steam Bath Generators - Ambiance...
Steam generator will not activate- thermasol model ASD300A
how do you know the unit has power?
what control do you have?
does it light up.
Mar 15, 2009 | Thermasol Steamshower Generator AF Series...
Thermasol Pro 150 - 25094. Doesn't work. I have a very simple controller. Just a gib gray button and four other led lights near the 15 , 30, 45, and 60 lights to set the time. I think I need to do the auto...
yes thats correct or if you have manuel flush at the genrator there is a ball valve. open for minutes then close and run generator for thirty minutes without anyone in the shower.
Mar 12, 2009 | Thermasol Steam Bath Generators - Ambiance...
Thermasol Steamshower Generator AF Series - for 140 Cu. Ft. - SSA-140 Logo
429 people viewed this question
Top Thermasol Electrical Supplies Experts
woodzowl307
Jim Goldsmith
Jim Goldsmith
Are you a Thermasol Electrical Supply Expert? Answer questions, earn points and help others
