Question about Vivitar ViviCam 35 Digital Camera
How to work it
I am trying to help somone work there camara, and they lost the booklet we put battaries in it but it still does not work.
  • Anonymous Mar 19, 2009
    My camera is`t working, I don`t know how put the batteries, because the camera not say when the batery is + or -
    President:
  • Vivitar Master
  • 1,734 Answers
  • 583 Answers
Motherboard can't display CPU fan moving fast no beep ram is ok no power supply problem keyboard LED flashing CMOS battary is new but display isn't showing anything
"no beep"... if your motherboard (mobo) has a system beeper and there is no beep on boot, the BIOS is not recognizing the keyboard so the computer will not boot. Reset the BIOS back to factory default. Unplug the computer, remove the battery for 10 minutes. Put it back in and try to boot. NOTE: be sure not to reverse the battery polarity! Usually the + side is up, but check your computer manual booklet. There is a small jumper on the mobo that you move to one side and back to original position again, which clears the CMOS settings. If you don't know where it is, see your computer manual booklet. If you still can't find it, just go with the above instructions.
Mar 05, 2014 | Intel Motherboard, 945GC, Core 2 Duo,...
When I push the button to take a picture on my camera, the camera shuts off. I have tried changing most of settings but nothing seems to work.
the battaries are overcharged or weak .PERHAPS IT is suffering from user neglegance replace them with good Mamp.according to your camera booklet.
Jul 16, 2011 | Cameras
My calculator wants me to reset my RAM, and when I press to do it nothing happens and the same screen shows up again for 3 seconds and disappears.
did you try to pull the backup batt for 1 minuth and put back it should help the backup battary is when you open the battary cover you should see a srew open it and take ou the battary out for a minuth and put back
Aug 17, 2010 | Texas Instruments TI-83 Plus Calculator
I have a big problim with mt 91 honda accord my battary wount charge i put new altanater new battary all cables are great but it wount seem to charge the battary if i charge the battary it well last up to...
With the engine running are you getting any voltage off the alternator? check with a multimeter. Check voltage at battery while running should be 13 volts or more.
May 16, 2010 | 1991 Honda Accord
I turn on the camara and all it does is beep 3x's and then turns off. What is wrong with it?
could just be the battary is a bit flat try charging them up of fitting good new ones
Oct 25, 2009 | Samsung Digimax S700 Digital Camera
Battary light would not go off
Have the battery and the alternator tested under a heavy electrical load. Some of the cheap battery testers will not indicate a bad or weak cell. Also your alternator may not put out enough amperage to keep up with the electrical demands placed upon it. A good battery tester is a carbon pyle tester. Good luck.
Feb 07, 2009 | 2005 Ford F-150
I have a Optimus 3.0 Mega-Pixel 5-1 Camera & Digital AV Camcorder & MP3 Player
tengo una camara igual, pero el problema que resolucion sale mal pixeleada, no se que ha pasado pero ala hora de pasar las imagenes a mi compu, se ve bien, pero en el visor de la cam sale mal pixeleado, no entiendo porque, si alguien sabe que me comente.
Jun 12, 2008 | Optimus DV-5040 Camcorder
CAMARA PROB
This sounds like an internal problem, and needs repair.
If you can get to the menu, try to RESET ALL.
Otherwise, repair is needed or sell for parts on a site like Ebay.
May 21, 2008 | Fuji FinePix A600 Digital Camera
Camera won't turn on with new batteries or power cord
I heard from another posting on here and the answer, that someone took fine sandpaper and cleaned off the terminal ends of both battery and camera and blew out the dust particles from that before replacing the battery, then then camera worked. I have yet to try it with my Kodak camera that is 2 years old and suddenly died too! The batteries are fine and work in other cameras.
May 07, 2008 | Kodak EasyShare C643 Digital Camera
Camara won't come on
It could be the batteries. To be sure about it, try your batteries in another appropriate appliance. Good luck!
Sep 07, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Vivitar ViviCam 35 Digital Camera Logo
81 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
