Question about Intel ASUSP4S533-MX S478 (MBASUSP4S533MX) Motherboard
PC Problems My PC Boost up and runs for about 15 mins before monitor shuts off.
    Scholar:
  • 157 Answers
First thing,check the settings of screen saver in the power settings maybe it is only the problem for shuts off...its only user's advice..but if the pc shutsdown,its another story....
Posted on Mar 03, 2009
Engine shuts off after driving 45 min when parking in reverse.But 15 min before this engine and slippery road icon comes on.2 hrs later car starts and drives normal then shuts off again 45 min later.
most commonly found problem relates to an electronic component heating up and shutting down. Have you checked to confirm there is fuel pressure when the vehicle shuts off. Is the check engine light on. Have you checked codes ? I suggest hooking up a fuel pressure gauge and letting vehicle run till it shuts off while monitoring the fuel pressure. If you loose fuel pressure, next step is to confirm there power going to the pump, if there is power going to the pump with no fuel pressure replace pump. Another suggestion would be to check for spark when vehicle stops running to eliminate an ignition problem. good luck
Aug 17, 2015 | 2008 Toyota Highlander
I had a power failure in my area. When power was restored my pc booted up ok but the monitor screen only stays visible as it should for about 3 seconds, then it goes black screen. I have powered...
Close windows down. Wait 15 - 20 mins, then power monitor up but NOT windows. Screeen should say "NO SIGNAL in centre. If t does not, wait five mins If still no display shut down and wait another 5 mins. Then start monitor un ANDt windows.. All should be OK now, If not shut EVERYTHING down and disconnect from mains ovrernight. (PC riouter/modem,,,, EVERYTHING . 12 hours later, re-connetc in THIS order - 1.) MONITOR 2.) PC 3) ROUTER/MODEM Should be OK now.
Aug 17, 2011 | Acer X193W LCD Monitor
My computer monitor keeps shutting off randomly for no reason. It isn't the sleep function I've already checked that and it happens when you are in the middle of using the system. I am running xp
Click Start, click Control Panel, click Performance and Maintenance, and then click Power Options.
Now you will see Power option Properties.
Now see the Settings for normal power scheme.
Under this Make sure that the options like Turn off monitor should be set on never and not on After 5 mins or 15 mins
After changing the settings hit on the apply button and then click on ok.
Check this link and you will be able to unuderstand more...!
http://www.microsoft.com/windowsxp/using/setup/tips/sleep.mspx
still you have problems let me know..!
May 10, 2010 | Computers & Internet
91 vw golf will not stay running after 15 minutes
You are losing oil pressure, this means your oil pump is probably out. Don't drive it anymore until you can get that repaired. It's shutting down because it's siezing up. You need the extra power to jump it because the piston rings and wall are sticking together, let it all cool down and the rings contract and loosens up. Allowing the engine to turn.
Apr 24, 2009 | 1991 Volkswagen Golf
Dell inspiron 9300 getting hang or restart after every 15 min
Sounds like your hardrive is starting to fail-backup all files!!!
Apr 12, 2009 | Dell Inspiron 9300 PC Notebook
After 15 -20 min my monitor goes blank
This could indicate a problem with the graphics card. Take the card out and clean it, then clean the slot that it fits into. (I normally use a small dry paintbrush).
Replace the card, making sure that you push it down gently but firmly and ensure that the plastic clip has gone back correctly that hold the card in place. Rescrew the card back to the casing correctly and reboot.
Hopefully this will resolve your problem. If it does not, to determine whether or not your graphics card is faulty. Change the monitor lead over to the onboard graphics port instead of the agp/pci port and reboot. If the monitor works properly with no problems, then you have a bad graphics card.
I hope this helps.
Nov 13, 2008 | Intel Motherboard
Slow booting & shut down
the only thing I can sugust is remove norton 360 if you have this onboard and get other firewall and spyware and antivirus software.
and disable the sidebar with the widgets, and change desktop view from aero to clasic this will boost up loading and shutting down of laptop.
you can purschase vista, then download all drivers for laptop from manufactures and re-install from scratch.
good luck with problem
Jul 03, 2008 | Microsoft Windows Vista Ultimate Edition
Shutdown
plz check the power supply
Jul 01, 2008 | E-Machines T6420 PC Desktop
Benq LCD monitor
I had same problem. No Power at the monitor. what can I do?
Jan 03, 2008 | BenQ T705 17" LCD Monitor
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
