Question about Kenmore 23822 Top Load Washer
Kenmore 70 series washer model 82870120 will not stop filling
This washer is 18 years old and has never had a problem now it will fill but when the washer starts washing it will not stop filling. I can fill it manually with a hose and the washer works just fine everywhere else just will not stop filling by itself. any suggestions?
  • 367 Answers
You need to replace the water valve. This is a common problem and a very easy fix. You can order the part at sears.com via model number and also see a breakdown of the machine and how to put it in.
Posted on Mar 03, 2009
  • 188 Answers
Check the pressure switch and the pressure switch hose.
Remove the 2 screws that hold down the console. Pull slightly from the bottom of the console and flip it up. On the left side you should see the pressure switch (water level switch) with a few wires and a small hose connected to it. The hose should be connected between the pressure switch and the tub. In most cases the pressure switch hose sometimes falls off over time due to vibration.
Check the function of the pressure switch by attaching a small hose to it and blowing lightly into the pressure switch while the machine is filling. You should hear a click and the inlet water valve should turn off. If you don't hear a click or the water doesn't shut off, replace the pressure switch. Replace the pressure switch hose if it is damaged. If there are no visible holes or cracks in the hose, try trimming 1/4" off each end of the hose (pressure switch side and tub side) and reconnect them making sure to push hose ends securely onto connections. This is done because the hose sometimes stretches at the connection points and you will lose air pressure inside the switch, therefore the water will never shut off.
Alternatively you can use small clamps on each end.
If the machine fills even when it's in the off position replace the inlet water valve.
70 series top loading washer
probably no parts for a machine that old
consider getting a new unit that is more power and water efficient
Jun 25, 2017 | Kenmore 24032\24036 Top Load Washer
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
My Kenmore 70 series is 18 years old. It will not
Hello. Since your machine is 18 years old and the agitation/spin is costly to repair I would definitely recommend a replacement washer.
Jul 06, 2009 | Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer doesn't fill
check your incoming water supply, the buzzing sound is coming fromthe waterinlet valve , soundslikke its trying to fill. possible that the valve is no good as well,
Nov 23, 2008 | Kenmore 22422 Top Load Washer
Series 70 Washer Won't stop filling
yes and also make sure fill tube is not clogged or debreed
Jul 05, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Kenmore 23822 Top Load Washer Logo
613 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
