Question about Cuisinart Thermal DGB-600 Grinder
Coffee Machine Brewing Water
When attempting to brew a fresh pot of coffee, the machine brews, but all that is left in the pot is hot water! Please help!
  • Anonymous Mar 22, 2014
    coffee pot leaks water from the bottom
  • 8,596 Answers
Try an experiment - brew a test cup, but use only a small amount of grounds in the brew basket (use a paper filter) [or else, put the grounds in the gold tone filter basket]. See if the machine makes coffee (albeit weak coffee). If it does not make coffee, see if the water is draining properly from the brew basket, or if it is leaking over the sides of the brew basket. Also, make sure the lid to the brew basket is completely open and in the correct position.
If you still get water only in the caraffe, replace the brew basket. The part costs about $11.95 with shipping - or even call Cuisinart to see if your 3-year warranty will cover the issue.
-Tha Mp3 Doctor
Posted on Mar 05, 2009
Why does my mr. Coffee decanter leak?
First I'm not a Mr. Coffee tech but I have worked on similar machines.
* Most decanters are made of tempered glass and unless cracked it should not leak.
* Most overflowing pots are caused by over filling brewing tank. This can be caused by re-pouring additional water into the brew tank. (automatic brewers may have a leaking water valve - call your vendor for service)
* Partial brewing (taking coffee from a brewing pot) and then putting in more water.
* Removing the pot BEFORE it stops dripping. It leaves a puddle of coffee on the warmer plate
*Over filling the water tank. Most times the extra water will spill out the back. But some may overflow into the basket area then the warmer plate.
* Follow the MFR brewing instructions for filling.
* All brewers should stop water drips after brewing. If you get a constant drip AFTER brewing then have the brewer checked or replaced. Call your vendor.
Aloha, ukeboy57
Jan 15, 2018 | Mr. Coffee Coffee Makers & Espresso...
Why does my machine brew coffee very slowly almost dripping instead of brewing at regular cycle?
it might need cleaning solution to use is vinegar pour vinegar in it and turn it on let it fill the pot up hope this works good luck
Feb 26, 2015 | Cuisinart SS-700 - Single Serve Brewing...
Doesn't always brew all the water, stops early
All coffee makers do this over time from calcium, lime, and mineral deposits building up inside the tubes and heating coil. Fill the reservoir with a 50/50 mixture of water and white vinegar and run a normal brew cycle, turning it off and on if necessary to completely empty the reservoir. Repeat this 2 or 3 times with fresh mixture of vinegar and water until it brews the reservoir empty without the need to cycle the power. Follow this procedure with plain water 2 or 3 times to clean the vinegar out. This should get it working like new again. It's best to use distilled water for brewing coffee as distilled water does not have the minerals that regular tap water has and therefore will not clog up the machine.
Mar 02, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
I have a bunn coffee maker that when it brews the first pot is hot after that the next one is not. It is the coffee maker that has two warmers on top. i didnt know if would be the heating element or...
While this brewer does have a reservoir that keeps a couple of pots worth of water hot for brewing you can get a cooler second pot if you brew directly after. You should hear the brewer heating up after brewing. Try waiting until it is back to temperature before re-brewing. If that heating takes more than a few (3-4) minutes then you probably have a problem with the heating element and the water is only being heated by the "keep warm" heater.
Sep 13, 2010 | Bunn VPR Coffee Maker
No water coming out makes noise and slite water and its not hot
Use vinegar as water and soak over night. Use the same vinegar as water the next day as if brewing coffee. Then use fresh vinegar as if brewing coffee. Next use water several times until you don't smell the vinegar. Now try brewing a pot of coffee. good luck.
May 12, 2010 | Keurig Elite B40 Coffee Maker
My tim hortons coffee maker is not brewing as quickly..s there a wayto clean it
Make a 1/2 pot 50/50 mixture of cold water and white vinegar then run it through the machine in normal brewing fashion. Place a clean filter in the brewing cup to catch the white deposits that are removed. Allow the mixture to cool, then repeat the process several times while using the same filter. Finally, run several pots of fresh water through to work out the taste of the vinegar. Repeat whenever the brewing time seems to be excessive.
Feb 02, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
KeurigB50 Coffee Maker will not brew. Gets to the
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Jan 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
How do I make coffee with a Grindmaster Pourover Coffee maker?
1) Place filter into brew basket.
2) Put the proper amount of coffee into the filter.
3) Slide the brew basket into holder.
4) Place empty decanter on warmer located directly under the brew basket and turn corresponding warmer switch ON.
5) Pour decanter of fresh water through pour-in opening at top of brewer.
6) Hot water will be delivered through the sprayhead. This distributes the hot water evenly over the coffee bed within the brew basket. The coffee will drain from brew basket into the container below.
7) Red light indicates warmer is ON.
8) Before brewing next pot, remove brew basket from brew rails and dump filter into waste basket.
Please rate this a fixya
Feb 08, 2009 | Grindmaster Pourover Brewer - 18
Braun Flavor Select will not brew coffee.
I assume You are talking about the water-brewing heater thereare two, the second is the heater that warms the coffee pot (I think!). When the water-heater is encrusted with calcium deposits it "thinks" that the water reservoir is emptyand ceases the brew cycle. water boils at 212 degF and the heater will go to a much higher temperature. I will leave you with the same solution as was posted to another problem that may have similar cause:
I have the same machine, Braun KF180 12 Cup Coffee Maker. In normal operation the brew cycle is stopped when the water reservoir is empty. The only way the coffee maker knows if that is true is when the water-brewing heater gets too hot. Your brewing heater is probably encrusted with calcium deposits if you have been heavily using the coffee maker. Vinegar will work but it is weak and you will have to cycle this solution through many many times. You should instead use "Lime Away" or "CLR" and let it sit there in a brew cycle or multiple brew cycles for a while. NOTE: Remove the filter when cleaning this way and when the brew cycle is complete, rinse thoroughly -- your taste buds will let you know if the machine is not rinsed thoroughly. -- Good Luck!!
Nov 16, 2008 | Braun FlavorSelect KF 180 Coffee Maker
Cuisinart Thermal DGB-600 Grinder Logo
251 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
