Question about Milwaukee Tool Milwaukee 1/4 Sheet Orbital Palm Sander - 6016 - 6
Cannot disassemble Milwaukee 6016 to replace brushes
I have removed the screws and partially separated the body. After it separates about 1/4 inch there is a catch that prevents complete separation. The catch seems to be somewhere in the lower part of the body. What is the trick/technique to get it open?
Thanks, Giles
  • 2,176 Answers
Exactly what screws did you remove. you have to remove the bottom platen first (pad) then remove the housing screws. you need to remove the fan also and then might need to apply some pressure to split the housing halves.
Posted on Mar 03, 2009
Milwaukee 5370 armature removal
probably need to remove the brushes from the other end as the rear bearing is bigger than the commutator section and the brushes fall in to the section and hit the bearing preventing what you want to do
Sep 06, 2016 | Milwaukee Electric Tool 5370 - 6 1/2"...
Disassemble
I am guessing this is the same one that has the clogging issue. Normally the screws for dismantling are in recessed holes ( they are a few inches deep) and fastened with Phillips head. You will be able to see them with a flashlight. Take off the bag container door and remove the bag or dirt collection bin. There will be screws behind that as well. On the bottom there will be screws that hold a cover over the beater brush. when that is removed you should see the belt and the slots that the beater brush seats into. That just pulls out. Once inside there are separate screws holding the 90 degree turns for the hose path. Prob 2 of these. Make sure you go through the ENTIRE hose path. I guarantee there is a big clog of hair, paper, pencils and small animals in there. If not confident in remembering how to put back together take pictures.
Jan 29, 2014 | Vacuums
I have a 1999 3,8L ford mustang my tester indecates the alt is overcharging,but the batt light is coming on but it goes off! is there anything i can do to besides replace the alt?
Your alternator-mounted voltage regulator has failed. Luckily, your voltage regulator is
replaceable separately from the alternator (most voltage regulators are integral to the alternator,
and cannot be separately serviced).
Note: this works for 3.8L cobra alternators/voltage regulators only - in the 4.6L model, the
voltage regulator is an integral component of the alternator.
1999 Ford Mustang Cobra -3.8L engine
3.8L Engines
1. Disconnect the negative battery cable.
2. Remove 4 Torx® head screws holding the voltage regulator to the alternator rear housing. Remove the regulator, with the brush and terminal holder attached.
Fig. 1. The regulator and brush/terminal holder are mounted on the backside of the alternator
Fig. 2. The regulator and brush/terminal holder are secured by 4 Torx® head machine screws
Fig. 3. Hold the regulator while removing the screws to prevent the regulator from dropping out and damaging the brushes
3. Hold the regulator in one hand and pry off the cap covering the A terminal screw head with a small prybar.
4. Remove 2 Torx® head screws retaining the regulator to the brush holder. Separate the regulator from the brush holder.
Fig. 4. Slide the regulator out-the brushes will move out of the holder
Fig. 5. The brush and terminal holder can be separated from the regulator once it is removed from the alternator
To install:
1. Install the brush holder on the regulator with 2 retaining screws. Tighten the screws to 25-35 inch lbs. (2.8-4.0 Nm).
2. Install the cap on the head of the A terminal screw.
3. Depress the brushes into the holder and hold the brushes in position by inserting a standard size paper clip, or equivalent tool, through both the location hole in the regulator and through the holes in the brushes.
Fig. 6. When installing the regulator, press the brushes back into the housing
Fig. 7. Use a thin piece of soft material, like this plastic wire tie, to hold the brushes in position while replacing the regulator, or use a paper clip inserted in the hole
4. Install the regulator/brush holder assembly and remove the paper clip. Install the attaching screws and tighten to 20-30 inch lbs. (2.3-3.4 Nm).
5. Connect the negative battery cable.
Jul 07, 2011 | 1999 Ford Mustang Cobra
How do I remove the back panel of the Ben Q fp222w in order to replace the power supply board. I have tried removing all the screws including the ones under the rubber grommets at the top of the rear of...
Have you been to YOUTUBE for "lcd monitor disassembly" and "lcd monitor repair" video clips??? Absolutly do not use sharp cutting instruments to part the rear cover from front BEZEL of unit. One careless slip and it's a trip to local hospital "ER" to stop the gushing wound you have inflected on your body. Good luck with repair to your unit. 12fixlouie
Sep 17, 2010 | BenQ FP222W LCD Monitor
Palm sander 6016... i have to replace the
you dont need a puller for the fan, remove the lower pad assembly and the torx screw holding the bearing in place. use a screwdriver to gently lift the fan. the bottom of tool has to be disassembled to open the halves. Go to Milwaukeetools.com and type in your model number under the download section for a parts/tool explosion. Let me know if you need more assistance
Aug 25, 2010 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
Kyocera fs 4000 how to replace drum, transfer roller and pickup roller
(1) Detaching and refitting the drum unit
Procedure
1. Remove the developer unit (See page P.1-5-
9).
2. Open the left side cover and then remove
the waste toner box.
3. Unlock the drum unit lock and then remove
the drum unit.
4. Check or replace the drum unit and refit all
the removed parts
(1) Detaching and refitting the transfer roller and separation charger brush unit
Procedure
9).
2. Remove the drum unit (See page P.1-5-10).
3. Slide the paper chute guide and unhook the
hooks.
4. Remove the paper chute guide.
5. Remove the shaft (transfer roller) from the
both bushes.
6. Release the four latches and then remove
the separation charger brush unit.
7. Check or replace the transfer roller and separation
charger brush unit and refit all the
removed parts.
CAUTION: Note the following, when refitting
A. The separation charger brush unit is
inserted into the two projections of the frame
and does not run on to the projections.
B. The separation charger brush unit is
firmly in contact with the separation charger
plate of the frame.
(1) Detaching and refitting the paper feed assembly (paper feed roller and pickup roller)
Procedure
1. Remove the paper cassette.
2. While pushing the lock and then slide the
paper feed roller pin.
3. While pressing the lever and then remove
the paper feed roller assembly.
4. Check or replace the paper feed assembly
and refit all the removed parts.
(2) Detaching and refitting the ****** roller
Procedure
2. Push the bottom plate down until it locks
(30/31 ppm printer [EUR/USA model] only).
3. Unlatch the two latches and then remove
the ****** guide.
4. Remove the ****** holder (roller) from the
****** guide.
5. Check or replace the ****** roller and refit all
the removed parts.
Feb 04, 2010 | Kyocera FS-4000DN Laser Printer
Slipping clutch on low switch with Milwaukee 2601-20 drill/driver. Can't separate clutch housing assy from drill. Is it pressed on? Same for chuck. I've removed the screw in chuck, still won't separate.
this tool has a 5 year limited warranty so I would try and have repaired under warranty. I looked at a breakdown and it doesn't specify how the chuck is on but I would to think it is threaded. the clutch is an assembly and there are no replacements parts other than the assembly available. Let me know if you need more assistance.
Jan 28, 2010 | Milwaukee Tool Drills
How to replace brushes on a 0234.1 1/2'' electric drill
there are two plugs with slot for screw driver. open the plug remove old brush and put new ones.
Oct 05, 2009 | Milwaukee Tool Milwaukee 1/2" Magnum...
I need to remove the fan on my black and decker pad sander but theres no way to clamp the armature to unscrew the fan
Why would you want to remove the fan? There is a good chance that the fan is molded to the shaft and can not come off.
Jul 13, 2009 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
How to replace the brushes on the milwaukee cordless drill 1/2'' # 0627?
Depending on age of tool older models did not have replaceable brushes. Change motor.
Newer models are replaceable , go to a service center and get a brush kit for this model. Or online.
Open tool with # 8 torx. Do not separate motor and gear case ,chuck remove as one unit. Brushes are solder in .De solder used brushes . Replace one side at a time. These kits come with new coil tension springs .
Jul 07, 2009 | Milwaukee 0627 24 Drill Hammer 18V T...
Milwaukee Tool Milwaukee 1/4 Sheet Orbital Palm Sander - 6016 - 6 Logo
459 people viewed this question
Top Milwaukee Tool Tools & Hardware - Others Experts
Bill Boyd
Are you a Milwaukee Tool Tool and Hardware - Other Expert? Answer questions, earn points and help others
