Question about HP - HP Photosmart 8250 printer
Printing is very, very slow
Printer started printing extrmemly slow even with simple black & white documents. I don't think I touched anything, just seemed to happen on its own. I read somewhere to adjust quality to lower which i did and still no improvement
    Problem Solver:
  • 11 Answers
Issue The printer is printing slow. Solution Follow the instructions below to manually select the paper type and print speed.
  1. In the application you are printing from, click File , Print , and then Properties . The Printer Properties screen opens.
  2. Click the Paper/Quality tab.
  3. Change the Print Quality from Automatic to the desired setting.
  4. Change the Type is selection from Automatic to the appropriate paper type that you are printing on.
  5. Click OK .
Posted on Mar 04, 2009
  • Lynn Willis
    Lynn Willis Apr 18, 2012
    Thanks. My printer had been printing documents as though it was printing photos. I didn't see the problem (the print screen was set for photo paper instead of standard) until I began to follow your instructions. Figured it out, made the adjustments, and we're back to normal. Thanks a million. L R Willis
I have to print a word document in black. Because I have no yellow ink, the printer won't print anything. I have tried everything and just want to print a simple one page document and I have plenty of...
here's a solution i came across when dealing with the same problem. apparently the printer expects all of the cartridges to be full and has a sensor to make sure they are even when only printing black. hope this helps!
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Jul 13, 2011 | Brother MFC 490cw Color Inkjet...
Want to print only black and white
Printing with only black and white as the primary color would be easy.
First, we would need to know what software are you using for printing.
It can be a black and white picture and/or just a simple word document.
Usually, when you print, there would the "Printer Options" first.
Once there, you would have options to change it to your liking.
If you have some problems. Don't hesitate to leave a comment and I'll get back to you.
Please leave a comment and ratings to help me improve my way of helping people here in fixya.
Have a good one...
Oliver
Jul 01, 2011 | Epson CX8400 All-In-One InkJet Printer
My cannon mp258 cannot print, message show that ink to slow,and the ink indicator appear the Colored ink is almost empty .and also i try to photo copy black and white document but i cannot photo copy even...
Yes. You cannot use the printer even in black and white, until the color cartridge is replaced. They are designed to check the levels of the both black and color cartridges.
Oct 18, 2017 | Computers & Internet
Will PIXMA MP640 print with an empty cartridge
No, it will not. I have this printer and last week I ran out of cyan. Even though i only wanted to print black and white documents the printer would not print anything until I replaced the cyan cartridge.
Jun 25, 2010 | Canon Office Equipment & Supplies
Canon MX700 multi-function printer error 5100, double-lines
You can Try
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All best: Pineworks
Jan 02, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
My samsung monochrome laser mfp printer has colour ink in it and it will not print anything in colour. My comp is windows 7. It will only print black and white and I want to print a coloured document....
The printer you have got is a monochrome printer i.e. it can only print in black. If you require colored outputs you would require to go in for colored printer.
Thank you,
Have a good day.
Nov 25, 2009 | Samsung SCX-4216F All-In-One Laser Printer
Black ink won't print
check printer preferences and settings.
May 31, 2009 | HP PSC 1350v All-In-One InkJet Printer
Color ink cartridge out. Won't let me print in black only?
Do this, press and hold the "Stop" button on the printer for 10 seconds that should clear the fault set by the empty ink cartridge.
Jul 21, 2017 | Canon PIXMA iP1800 InkJet Photo Printer
The black, print quality when printing a document on white paper, is not 100%
Few questions, are you running true Canon Inks and refills are always a off black not a true canon black!
Have you tried doing nozzel check, does the top black squares all come out ok? if so it could be down to the paper and the inks!
if you use 80gsm paper does it print ok?
Hope this helps
Sep 30, 2008 | Canon MP610 Photo All-In-One Printer
1,359 people viewed this question
Seeker5211
Seeker5211
