Question about Sony DCR-PC108E Mini DV Digital Camcorder
Incompatible i have a sony DCR PC108E, im trying to capture the videos from the dv tape to my laptop, which operates a window vista, but it doesnt seem to run on it, is there anything that i can do?
  • bizzared Mar 03, 2009
    yes, im trying to transfer all of the videos from that tape to my laptop, using the sony handycam i have. i want to move the entire video and watch it later. is there anyway?
  • Rob
    Rob May 11, 2010
    Ok, so your trying to transfer the videos from your camcorder to your pc running windows vista? Correct?
    Do you want to play them in the camcorder and see them on your pc, or do you want to move the entire video at one time, then watch it on your pc? Let me know
  • 423 Answers
Ok, this is one way to do it. You can play a tape in your camcorder and with a memory stick in the camcorder, and you can record you video to the memory stick. Your manual shows you how to do this on page 95. If you don't have the manual, you can download it here http://www.nodevice.com/user_manual/sony/home_video/dcr-pc108e.html
All you have to do then is get a windows vista compatible card reader and move it from the stick to the computer.
Note: After it's in the computer, you may need an MPEG codec to play it, it depends on what program your going to use.
Good luck,
Rob
Posted on Mar 03, 2009
I cannot seem to upload video from my sony handycam model DCR-HC36. My home operating system is Windows Vista basic 32 bit. I've tried downloading things but it never seems to locate the needed...
You should not need additional drivers if you have Windows Movie Maker on your machine, it's standard kit for Vista.
Connect with a firewire cable and open WMM and capture from the tape. Firewire is also known as iLink or IEEE1394a.
May 22, 2011 | Sony Handycam DCR-HC36 Mini DV Digital...
Cant instal drivers
usb streaming function is not readily supported by windows vista. this would depend on the software that came supplied with the camcorder. unfortunately, the software being incompatible and the funtion (usb streaming) not supported by driver included in the supplied cd-rom, usb connection will not work (although you can use it for still picture transfer). for tape transfer you would need to go another route which is ieee1394 (ilink or firewire) connection. it should be a plug-and-play connection. your computer should support and have a working ieee1394 (ilink or firewire) card installed. a compatible ilink cable for both devices and a video capturing software like windows moviemaker and having all the needed hardware and software then your good to go. hope this helps.thanks:)
May 29, 2010 | Sony Handycam DCR-PC330E Mini DV Digital...
Video transfer
If you're using a Windows Vista Operating System it'snot possible to transfer the videos from the Camcorder to the Computer using the USB connection. The videos from the tape camcorders cannot be transferred to Windows Vista Operating System as there is no USB Streaming ooption available on the Windows Vista Operating System. The Camcorder uses the USB Streaming function to transfer the videos to the Computer. You may wish to purchase a i.LINK/Firewire cable to connect the Camcorder to the Computer in order to transfer the videos from the Camcorder to the Computer.
or
There is an update for driver on the Sony website to transfer the videos from the Camcorder to the Computer using the USB cable.
http://support.sony-europe.com/dime/downloads/downloads.aspx?site=odw_en_GB&m=DCR-HC42E&f=usbdrven_vista
You may also try installing the driver update for the Camcorder. The i.LINK cable gives a better video transfer qulaity than the USB transfer. The i.LINK cable used to connect the Camcorder to the computer depends on the number of pins available on the i.LINK/FIREWIRE port on the Computer. The i.LINK port on the Computer is a D shaped port which is labelled as i, DV, IEEE1394 and Firewire.
Jun 07, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
SONY HANDY CAM DCR-HC18E PAL Need download for usb driver windows vista
http://support.sony-europe.com/dime/tutorials/videotransfer/vtransfer.aspx?site=odw_en_GB&m=DCR-HC18E&sec=DV
Only load the driver and install in XP compatability mode then use another video capture programme Sony does not support Vista for you cam.
FX vid capture will work
http://www.jhepple.com/video_capture_software.htm
If you get stuck you can reach me on marshall.c@sky.com
May 27, 2009 | Sony DCR-HC18E Mini DV Digital Camcorder
How to upload my home movies to Vista
Vista isn't supported download the driver from here
http://support.sony-europe.com/dime/tutorials/videotransfer/vtransfer.aspx?site=odw_en_GB&m=DCR-TRV22E&sec=DV
install using XP compatability mode and run as administrator then use another video capture programme, FX works on vista
if you get stuck you can reach me on marshall.c@sky.com
May 26, 2009 | Sony Video Cameras
Driver for windows vista
first download the driver from this link..
http://www.sony.com.vn/support/download/180037/product/dcr-hc26e?site=hp_en_VN_i
the go the following link and download the vista patch and install it
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/OTHER-SCANNERS/Sony-DCR-HC26E-TWAIN-Patch.shtml
May 23, 2009 | Sony DCR-HC26E PAL Mini DV Camcorder
Problem with compatibilty between windows vista
since you're using vista you can connect camcorder to pc uding ilink or firewire cable. usb conection would not work. no dirvers or sofwtare needed, you can use windows movie maker to capture videos. check your computer for any ilink port. it is a different connection from usb. go to www.sonystyle.com and type this model number, vmcil4615, for you to have an idea what firewire cable looks like.
Mar 22, 2009 | Sony Handycam DCR-HC14E Mini DV Digital...
Compatibility with Windows Vista
you cannot use usb connection on vista with this camcorder if you want to transfer videos from tape. use a firewire or an ilink cable and windows movie maker to capture videos. no drivers needed.
Mar 14, 2009 | Sony DCR-HC42E Mini DV Digital Camcorder
Capture to windows vista
Download Picture Motion browser update for Vista from Sony Support.
Dec 11, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
Sony DCR-PC108E Mini DV Digital Camcorder Logo
95 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
