Home | Reddy | Heater-30-55,000 BTU Variable | The heater runs for app...
Reddy Heater-30-55,000 BTU Variable
Problem for Reddy Heater-30-55,000 BTU Variable
The heater runs for approx. 7-10 minutes then shuts down
By sch47 on Mar 03, 2009
the nozzle is clear/new. I flushed and drained tank several times.
My best guess is the phot cell or ignition control PC board.
Sponsored Links
Same Problem
Mar 06, 2009
-   Same problem and I cleaned the air filter. what next? -   Guest
Solution #1
posted on Mar 17, 2009
Not Rated)
steve_lima
Rank: Guru
Rating: 92%, 115 votes
very rarely it's the circut board.most likely it will be the photo cell.does you photo cell have one blue wire and one white wire????or is it two blue wires,they are two differant photo cells.if it's two blue wires you nee to check the air pressure.it's very important.if the pressure is wrong it will not work properly.you need a gauge to check it.
Was this helpful?
Yes
No
Popular Solutions for Reddy Heater-30-55,000 BTU
Questions and Unsolved Problems for Reddy Heater-30-55,000 BTU
Do you recommend Reddy Heater-30-55,000 BTU Variable?
Answer
Answer
my heater will fire up and run then if i unplug it and plug it back in the motor spins slow and the... (More)
Answer
55000 btu kerosene heater I ran great until i moved the heater to another room, plugged it back in... (More)
Answer
I have a 55,000 btu heater it wont fire off. sounds like it wants too then just dies. kerosene... (More)
Answer
reddy heater 5500 runs for about 10 min and flame shuts down but fan still runs
Answer
I need a manual for a reddy heater r55 55000 btu heater
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Reddy Heater-30-55,000 BTU...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
