Question about GE DCVH515GF Gas Dryer
Scraping/high pitched noise in GE model DCVH515GFOWW.
This is a replacement dryer since our first dryer made this sound and was replaced within the first month. Now 3 years later, the same sound is intermittent in this dryer. What is making this noise
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sfdyjsdf
Posted on Sep 29, 2010
Dryer makes a squeaking/high pitch rubbing noise
bad drum bearing, bad drum teflon pads or both possibly
or both possibly or in combination the belt could need replacing
& if your not sure get a service tech so you dont do more damage
Apr 06, 2014 | GE DVLR223 Dryers
High pitched squeaking dryer
its just the bearing and it needs replaced. it will take about two hours to do and it will cost you about 30 dollars in parts. you can find many really goods vids on youtube that will show you how to do it and most parts manufactures now have directions on how to do it in the cluded when you buy the parts.
May 09, 2013 | Dryers
I have a GE Profile 6 cycle dryer. It is making a high pitch squeeking noise.
Replace the rear drum bearing. You do not list a model number, so can not give much more info than that.
Mar 06, 2011 | Dryers
I have a newer model GE dishwasher. About a couple of weeks ago we lost power to home. When power was returned the dishwasher was making a high pitch sound and power was not returned to the front...
Hello
High pitch sound comes when the main control also known as the electronic board goes bad and needs replacement. Please try to blow air with hair dryer on the display just to check if that'll solve the problem. Hope you understand...If it does not then replacement of part is only recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | GE 24 in. GLD5560LSS Stainless Steel...
Scraping noise when mower turns of is pulled backwards
you can take it back to the store and get it replaced with the reciept. but sounds like the belt is loose.
Aug 14, 2009 | Garden
GE GAS DRYER DDE7500G
Can you push the drum up and down. If so then the main bearing has gone bad and needs to be replaced. This is the only metal on metal rubbing you will get unless the machine is off balanced. This is caused usually by doing to heavy of loads and wearing out the bearing
May 22, 2009 | GE DPSR610GGWT Dryer
Weird noises in drive and reverse
The high pitched whine in reverse sounds normal for a honda. Ever honda I have had makes a similar noise while in reverse. The spinning, scraping noise in drive is not normal. You might want to see a mechanic about that.
Apr 30, 2009 | 2002 Honda Civic
Grinding, scraping noise when drying
Glides or roller replacement, could also be something from a pocket wedge between drum or cabinet.
Feb 01, 2009 | GE DBSR453EBWW Electric Dryer
Clothes get caught between frame and drum
Is this the dcvh515 GE? Mine began doing that and then started making a high pitched scraping noise that sounds like it's coming fron the door gasket/seal.
Dec 21, 2008 | Dryers
Squeeky noise
I own a Frigidaire Heavy Duty Dryer The Model # is FDE436RES1. It is 10 years old. When running the dryer it makes a very loud squealing noise although the heat and the dryer still work. Is this a belt or roller problem or does it sound like something else. It is very high pitched and can be heard throughout the entire home. I do not know much about dryer troubleshooting so your help would be greatly appreciated. Thank You.
Oct 17, 2007 | Frigidaire GLER642A Electric Dryer
Open Questions:
GE DCVH515GF Gas Dryer Logo
335 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
