Question about HP OfficeJet 6110 All-In-One InkJet Printer
I get the a carriage jam message and when I print I get a god awful grinding noise form the printer.All cartridges are secure and no paper is jammed. What do I do?
  • 1 more comment
  • Anonymous Mar 05, 2009
    yes please help now!!!!
  • Anonymous Mar 17, 2009
    my 6110 will print fine but when the cartridge goes back to the resting position it will make a loud grinding noise and the cartridge jam will display telling you to lift the up the top to open the printer and remove the jammed cartridge.do that and will do the same thing again.any solutions!!!
    I have exactly the same problems. Do I really have to completely replace it!
    Genius:
  • 2,120 Answers
Replace the printer
Posted on Mar 05, 2009
Pump motor stalls in my HP printer
When an inkjet printer is making "awful noises" it means that there is either a paper jam or the carriage can't move properly. Remove all paper and check for a paper jam - if this is not the problem, turn off the printer and see if you can move the print cartridge carrier by hand. If it is hard to move, clean the shiny carriage rod with a cloth and put just a drop of light oil on it. Move the carriage back and forth and clean it again - repeat until it moves easily and add a final drop of oil to the rod.
Oct 14, 2014 | HP Photosmart C7280 All-in-One Printer
The power light is flashing and the printer makes a grinding noise and won't print. There was a paper jam that i had to pull out prior to this issue.
Hello According to HP, follow these steps for resolving the issue
Remove the rear access door, or the automatic two-sided printing accessory, and check for any paper jams or paper obstructions. Remove any obstructions. Check to make certain the carriage is on the right side of the printer. Rotate the rear paper guide rollers upwards five times, then downwards four times. If the rollers will not move, open the top cover and slide the carriage to the right (if it is not already there and if carriage can move). Try to roll the rollers again while pushing the clutch in. If the rollers do not move, continue on to the next step. Figure Location of the clutch c00040832.gif Replace the rear access door accessory, or the automatic two-sided printing accessory. Close the top cover. Plug the power cable back in. Turn the printer on, and replace the cartridges if possible. If the carriage moves, but there is still a grinding noise, there may be a paper feed issue. If the carriage will not move, then it is a carriage stall issue. After installing the cartridge, if the printer has a solid power light, perform a self-test on the printer. Hope this helps, if so do rate the solution
Jan 02, 2011 | HP DeskJet 3650 InkJet Printer
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
My hp deskjet f4140 keeps showing a paper jam and won't print the page I need, there isn't a paper jam.
There is probably a problem with the position of the cartridge carriage. Try reinstalling the cartridge and make sure that the carriage is in the center of the cartridge access area and the center of the cartridge assembly bar. If it is not try moving the cartridge assembly in either direction and restore the printer for printing. Note any sounds as the cartridge attempts to go to its home position. Any grinding noise may indicate that the position of the cartridge needs to be adjusted. Be patient and adjust the cartridge position again until no grinding sounds are heard. It may help to unplug the printer for 30 seconds between adjustments. Good Luck!
Nov 05, 2009 | HP Deskjet F340 All-In-One Printer
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
Jun 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Constant yellow blinking light, no paper jam
I found this on the HP support site:
The power light is on, and the resume light is blinking.
c00109831.gifc01272271.gifc00109834.gif The printer might be waiting to complete a print job or to receive data from your computer.
Solution
Wait for the printer to finish the current task. The printer is waiting for the ink to dry on freshly printed paper.
Solution
  1. Remove the paper with fresh ink.
  2. Press the resume button.
The printer might be out of paper.
Solution
  1. Load paper in the paper tray.
The printer might have a paper jam.
Solution
Clear the paper jam. If the resume light continues to blink after the paper jam is cleared,
OR
if the print carriage is stuck or making a grinding noise, then follow these steps.
Solution
  1. Lift the top cover of the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts. Unplug the power cable from the wall outlet.
  4. Movethe print carriage toward the middle of the printer (this proceduremight take a couple of tries to get the timing correct).
  5. Remove the print cartridges and close the top cover.
  6. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover.
The printer may be ready to eject banner paper.
Solution
Press the resume button to eject the banner paper.
Mar 14, 2009 | HP DeskJet 5550 InkJet Printer
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Stalled printer cartridges
Sounds like an issue with the print carriage. When it's out of alignment and tries to print, it can make awful noises. HP.com has a web page that describes a number of troubleshooting steps when you have print carriage issues:
Carriage Jam Errors
There's also a related web page having to do with the noise coming from the printer:
Noisy Print Carriage
Hope this helps. Good luck.
Oct 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
147 people viewed this question
Seeker5211
Seeker5211
