Question about Kenmore 22422 Top Load Washer
My kenmore washer does everything but turn off the water when the tub is at the leavel that is should be at. I can fill it manually and it will start the wash cycle but when I let the washer fill itself it will continue to fill even though it is washing. any suggestions? Thanks Robyn
  • Anonymous Mar 07, 2009
    kenmore washing machine fills up does not spin
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
Water is over filling the tub, and spilling all over the laudry room floor.
this sounds like a ge ? if so you need to remove front cover between the top and the front cover you will see a small gap on both sides you will have to put a putty knife in about 2" from the ends and push in
once removed on the left side of tube you will find a small rudder hose pull the hose of clean in side of hose with small screw driver also fill washer with water with hose of untill water leavel is to the center of the box now use a turky baster to force air in to tub by placeing baster over the stem wher the hose was force air in to tub fill washer a lititle more untill water shots out of stem stop washer and drain all the water out cut about 1"off hose reinstall stop useing liqid soap
Jan 30, 2010 | Washing Machines
My washer didn't stop filling and overflowed. Is
un plug washer and turn hot and cold water on,if water come's in than you have a bad water inlet valve.if water doe's not come in than you nead to check the line from the water leavel switch to the outer tub.if line is conected on both end's and ther are no hole's in it,than you have a bad water level switch.
Nov 24, 2009 | Washing Machines
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Water filling tub
You need a new cold inlet valve fitting.
Dec 08, 2008 | Kenmore 44042 Front Load Washer
Kenmore 22422 Top Load Washer Logo
47 people viewed this question
Sal De
fordexpert
Robert Rankin
