Question about MySpace Social Network
Can't get on my page
It says to verify but it won't let me
Well if your blocked try secure88.com
or toptunnel.com
it has worked for me
Posted on Mar 03, 2009
Toshiba satellite l25-s119 internet won't work.
Wired or Wireless? Try a Ethernet Cable to verify the ISP is sending a signal. Try another broswer.
May 04, 2013 | Computers & Internet
Changed cartridge and now won't print a document
Verify the data cable or the PC printer setting,perform the test page,if you make a copy not problem the cartridge change.
Feb 25, 2013 | Canon Pixma MX410 All-In-One Printer
My 2000 honda civic wont turn over and has no spark but the ignition coil and modual are both fine
Won't turn over? Do you mean the starter won't crank the engine over?
Or the engine cranks over and won't start, and you have tested for spark when cranking and have no spark? And then you have tested the coil and ignition module, and they tested out good? Am I on the right page here? If so, maybe the next thing to check would be the crank position sensor. The ecu (computer) signals the ignitor (ignition module) when to initiate spark after it digests the signals from the crank position sensor and the cam position sensor.
Nov 04, 2012 | 2000 Honda Civic
Some faxes won't send. Recipient will recieve a partial page and then blank pages. Then my machine will tell me there is a "remote fax error". All other functions work great. I use the phone...
The problem could be to the transmission signal. Try to set your Fax Send Speed to 9600 bps. On your printer operator panel, press Setup > Fax Setup > Dialing and Sending > Max Send Speed > select 9600. Hit Ok to save the setting.
Try to send a fax again to verify that the problem is fixed.
Sep 13, 2011 | Lexmark Prospect Pro205 Wireless...
X4270 won't copy after replacing black cartridge. It did run an alignment page, however.
Try this approach:
  1. On the printer operator panel, on Copy mode, press Options.
  2. Select Maintenance.
  3. Select Clean Cartridges
Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that Copying is properly functioning now.
Aug 08, 2011 | Lexmark X4270 All-In-One InkJet Printer
Iam trying to get my account verified won't accept my bank name or mybank router no what I put doen is right
Hi
What specific message does it give you when you input your bank name and routing number? Make sure the numbers you enter are indeed correct. Sometimes, people will think the bank acct number and routing number is on the check but in some cases, this is not the case. The routing number will be a different number. Please verify with your bank.
If you are still having trouble I would recommend you reach out to PayPal directly and they can provide additional assistance.
PayPal support page Click here
Regards,
G33k
Jun 03, 2011 | PayPal Accounts
My yahho account is locked. it won't verify one of my security questions about the pets name
Email yahoo administration. I had the same problem with one of my accounts. Most of the time, you're one of THOUSANDS having the same problem. They can open your account back up, or at least let you know how long it will take and what the problem is. On the login page, hit the link that says I can't log into my account. You'll find an email address there. Or, you can always hit the "help" link at the top right of the page. It will take you to their FAQ and their contact emails as well. Good luck!
May 21, 2011 | Health & Beauty
My nokia E63 was stolen and a similar one has been retrieved but i suspect the plate with the imei number has been tampered with, How do i verify that the imei number on the phone is the original one?
have you check with this code *#06#, by this trick the imei won't change because it is the mobile identity and will be different in each hand phone
hope it helps you
please rate this page if it helps you
thank you
May 13, 2011 | Cell Phones
Ebay are not taking my bids. they say i have used my limit but i dont know what that is. they say it will be increased if i verify my card and identification but i have tried to do this on several...
Hi there!
If you have reached your buying limit, you will need to add your credit card in your eBay account. It's like creating a seller account on eBay. That way, eBay will be able to verify your identity by charign your account with the authorization $1 charge but don't worry, it will be refunded back to your card after 7-10 days. It's just to check if your card has sufficient amount. Also, contact your card issuer or bank first to check if eBay is allowed to charge your card.
Once you placed your card on eBay as your payment method on file, your buying limit will increase. You can also do the ID verify but there's a $5.00 charge to it and you won't get it back.
Please check eBay's help page for more details about ID verify and creating a seller account on eBay.
Hope this helps. Have a good day! Please rate! Thanks!
Apr 30, 2011 | eBay Auctions
Hi my name is deirdre marino i have some items on ebay to pay for but i am unable to pay for them as i am unable to verify my account as the verify number has not come through to my account as yet . The...
mcdevito75 here, Hello Deirdre, the first thing to do is to let the ebay seller you won these items from know your haveing a problem with any money owed due to a non-verify number, this way the seller who you won the items from knows you intend to pay for them. You can contact the seller whom you won the items from by clicking on my ebay at the top of any ebay page then with the drop down menu click on won, once at the page of items you won, next to the item you won click the option on the far right sde of the item title, in the drop down menu click on contact seller. Once you have contacted the seller with your problem, then call ebay at 1-800-701-3229 you can also call paypal at 1-877-672-9725 or 1-402-935-7733 or 1-888-221-1161 and see about fixing any problems with your account.
Oct 23, 2010 | Watches
MySpace Social Network Logo
109 people viewed this question
Top MySpace Computers & Internet Experts
Nicholas Bannister
Zachary Reed
Tom Del
Level 1 Expert
Are you a MySpace Computer and Internet Expert? Answer questions, earn points and help others
