Question about DCS Large Appliances Built-In Ovens Warming Drawers Single
Gas furnace short cycling. checked by experts no solution
Short cycling. checked by experts who cannot come up with solution to problem. also loud vibrating noise on start up which diminishes to a degree as furnace runs
re Lennox gas furnace G24M3-75A-10
    Problem Solver:
  • 10 Answers
This is tough one. If you have an older mercury type thermostat, behind the cover theirs a small copper pointer that points to some numbers. This is your heat anticapator. This setting has to match your milliamp draw of all the controls on your furnace. If set to low it over heats and fools the thermostat into thinking its satisfied. Move the point to a higher setting in little increments. Hope this works for you. Can't help with the vibration without hearing it.
Posted on May 05, 2009
Rotating Rack. How do I replace flame sensor?
How To change a flame sensor on a furnace and what to ...
? 17:13
www.youtube.com/watch?v=iDnkdKsZhc0
Dec 8, 2011 - Uploaded by kevin miller How To change a flame sensor on a furnace and what to look for. ... The gas flame heats the electrode, allowing electrons to be emitted as from the ... I found a Honeywell "universal"replacement unit for my furnace on eBay for ...
Aug 19, 2015 | Baxter Ovens
Arcoaire furnace ran out of propane and now wont ignite
Check along the gas supply line to the furnace and make sure there isn't a valve that is shut off. If you have a gas oven see if the ranges light and have gas. I'm assuming you've also turned on the gas supply at the furnace itself as well. Check that the furnace has electricity it won't be able to open the automatic valve let alone fire the igniter. My brand new furnace had a safety switch that went out 3 days after installation preventing it from lighting. You might contact Arcoaire about that. http://www.arcoaire.com/
Dec 23, 2013 | Ovens
Ran out of lp gas -now furnace and water heater will not light
yes you will have air in it you will neede to pruge the line near to the heater
Sep 18, 2009 | Bakers Pride Y-600 Gas Single Oven
Gas Line reconnected and now oven does not start up, pilot on
Check the hot surface ignitor if its not working valve will not open, It is located at the back bottom of oven. Sometimes they will appear to be work but if there isnt enough back emf the valve will not open.
Mar 15, 2009 | Magic Chef 9122 Gas Single Oven
Maytag gas oven cycles every 20 seconds
yes it is normal . but i know your not the first to think its not , todays ovens are so tight , it only takes 10 seconds of heat to keep them at proper temp . it used to be that ovens where kept at a 3 degree sweep that is set at 350 turn on and up to 353 then off ,cool down to 350 and back on . this was a longer time off and a longer time on topday we keep to 1 degree ! 350 on to 351 off to 350 on and so on ....... so short berst of heat make for a more even oven ........ but i know i hate it too ! good luck
Jan 18, 2009 | Maytag CWG3100A Gas Single Oven
Where is the reset button
Hi.
thanks for request re your gas oven,unfortunately ,I have no experience of gas ovens, and am therefore unable to help solve your prob.
Check the experts, and see if there is one who is conversent with gas ovens.. Once again , sorry.
Jan 10, 2009 | Electrolux EOG7330WN Gas Double Oven
Gas Furnace doesn't come back on after giving heat for a while.
This is an erratic operation of the thermostat you can reset the thermostat. Please check the reset operation procedure of the installation manual
Nov 18, 2008 | Tappan 30IN ELEC IGNa Oven
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Oven won't heat
please read this page
http://forum.doityourself.com/showthread.php?t=220859
It may solve the problem. if not please request more assistance from other experts.
Jun 18, 2008 | GE JGRS14 Gas Single Oven
Starter
Sounds like one of the control knobs got stuck or shorted in the start cycle. Can you get access to the inside where you can see each of the control knobs? Look for wiring and unplug one at a time. This may help you figure which one is shorted.
Mar 21, 2008 | GE JGRP17 Gas Single Oven
DCS Large Appliances Built-In Ovens Warming Drawers Single Logo
423 people viewed this question
Top DCS Ovens Experts
ashburton
Sal De
Joyce Nokleby
Are you a DCS Oven Expert? Answer questions, earn points and help others
