Question about HP LaserJet 2100 Printer
JUST BOUGHT THIS PRINTER HP 2100 C4170A,CANT SEE A USB PORT,OR PRINTER LEAD PORT NO INSTRUCTIONS,NO DRIVERS NEW TO THIS CAN YOU HELP,OR SHOULD I BIN IT.I DONT EVEN KNOW IF IT IS COLOUR AND IS IT ANY GOOD FOR PRINTING PHOTOS ETC
  • 14 Answers
This is a mono laserjet, not colour. You will find a parallel port behind the right side cover. the rear half of the cover unclips from the back of the printer. you can download a driver from here
Posted on Mar 03, 2009
    Problem Solver:
  • 5 Answers
If you want install your printer, login in hp.com and download the driver you need it.. and usb port is located back right side...litle port... TY
I cant install printer usb port is damage
Which USB port Damage because there are two USB port available.
One is Printer USB port or Sec is PC USB port.
If you are say PC USB port not working first you check it USB driver installed or not, or USB connect to motherboard or not. PC there are two side USB available one is front side and sec is back side. You connect only back side, because this USB connect to main board. So you connect only back side. If not working removed driver or installed driver.
Or if you are say printer USB then change cable or port or not solved only change option.
Read More Help.. If you have USB or Network Printer and are having trouble printing and HP Tech Support
Jun 27, 2014 | HP PSC 1315 All-In-One InkJet Printer
Trying to connect HP Laserjet 2100 (works fine with XP) to Pavilion dv7 with Win7 64 bit Professional. I downloaded the PCL5 driver from HP but it will not print. I am using a Manhattan parallel to USB...
Did you download the Win 7 64 bit drivers for this printer. If not i suggest try downloading the drivers from the following link
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=14914&pr...
Check the USB connection
The icon on the USB cable (c01424575.gif ) faces up when the cable connects to the product correctly. Check the back of your product and the back of your computer to make sure the USB cable connects correctly and securely.
After you make sure the USB cable connects correctly and securely, review the following guidelines to check other potential USB-related problems:
  • USB ports on the keyboard. USB ports on the keyboard and in the front of some computers might not be powerful enough to support the product. If the USB cable connects to the USB port on the keyboard, try connecting it to another available USB port on the computer.
  • USB cable length. HP supports USB cables less than 5 m (16 feet, 5 inches) long. However, a USB cable that is 5 m (16 feet 5 inches) long must be of high quality. Otherwise, HP recommends using a USB cable that is less than 2 m (3 feet, 3 inches). Do not use patch cables to increase the length of an existing cable. Use a powered USB hub if you need more length.
  • Alternate USB ports. Connect the USB cable to another port on the computer to make sure that the USB port on the computer is not the cause of the problem.
  • Defective USB cable. Replace the USB cable to make sure that the existing cable is not defective.
  • Conflicting USB ports. Disconnect any other USB printers, USB scanners, USB cameras, and any other USB connected peripherals. Start reconnecting these devices one at a time to determine if one of the devices is using too much power. Consider purchasing and installing a powered USB hub if necessary. NOTE: A USB-powered hub is a device that increases the number of available USB ports on a computer and facilitates communication between the USB devices and the computer. A powered USB hub can resolve communication failures between some, but not all, USB chipsets and HP products.
Jun 23, 2011 | HP LaserJet 2100 Printer
Lost cd for laserjet 1320 cl6 printer. installed
either the usb wire is getting loose in the new laptop port.or the port is faulty.press the usb wire tightly and then try printing keeping it pressed at the laptop side and printer side too.with some bodies help. check out.
Jul 12, 2009 | HP LaserJet 1320 Printer
New printer not recognized?
Here two causes are possible first your driver that you installed is not insralled properly so turn off your computer, reboot, delete HP Photosmart C4480... driver from the printer list icon and install again properly.(if you will not get the right solution of your problem then try the next step)
Second your U.S.B. cable maybe faulty so change your U.S.B. cable.(if you will not get the right solution of your problem then try the next step)
Third your U.S.B. port of computer is faulty so cahnge the port(many computer have more then one U.S.B. port if you have so try one(if you will not get the right solution of your problem then try the next step)
and
after this all you try your installation on other machine.
I hope you will get your problem solution.
thanks
TTYAGI
Apr 04, 2009 | HP Photosmart C4480 All-In-One InkJet...
Hewlett packard laser jet 2100 model c4170a
Try removing the toner cartridge and re-install it again then recycle the power.
Jan 11, 2009 | HP LaserJet 2100 Printer
Printer head wobble
Dear it seems a simple printer driver problem. I suggest you that if you have printer driver cd-rom than uninstall printer driver from add & remove program in control panel and than restart the system and unplug the printer from the usb port. Than insert the printer cd-rom and follow the instruction. And when it ask to connect printer to usb port at that time connect the printer to usb port and power it on. and let it get installed properly as per the instruction ok. This might get resolve your problem. if not kindly revert it to me.
Nov 12, 2008 | HP DeskJet 3745 Printer
Connecting a new computer to an older printer
Does this Laptop have a docking station? If so then on the back of the docking station should be a parallel port.
Is you laptop connected to a router/firewall/switch? Then you can get a device that will make the printer become networkable and connect to you firewall switch...this unit is called HP jetdirect. It will make your parralel printer become more useful and connected to the network.
Problem is the printer is "old school" and the laptop is "new school", the JetDirect will bridge this...
Jul 07, 2008 | Computers & Internet
New computer with Windows Vista
I have my HP OfficeJet T45xi working with Vista Ultimate. I used a cable coverter to switch to USB. I must install the printer with the USB cord unattached. Install as T40xi whose driver comes with Vista. Set to USB port 1 or 2. Plug USB into USB port 1 or 2 (only ones of six USB ports that worked for me). When Windows discovers the printer do not let it install the printer and tell it to not try again.
Works for me. Hope it helps you!
Feb 03, 2008 | HP OfficeJet T45xi All-In-One InkJet...
HP LaserJet 2100 Printer Logo
293 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
