Please can anyone help me i have recently upgraded my monitor from a xerox 19'' to a samsung 23'' syncmaster now with the monitor in standby i turn on my acer t180 and the green light in the on button dosent light up an the monitor wont detect a signal if i turn off both pc and monitor then turn the pc and then the monitor everything works fine in this pc i am running a xfx 9500 gt graphics card and have the latest drivers for the card and monitor so why should this be. i know its only a little problem but it is buggin me rotton so i would be grateful for any help thanks
  • pete616 Mar 03, 2009
    thanks for the advice techguru2009
    but now the problem is that the system wont recognise the graphics card and keeps reverting back to the old on board card any advise???
  • pete616 Mar 07, 2009
    thanks this has sorted both problems out you have been a great help
  • 51 Answers
I assume you are running windows. First off you need to boot into safe mode by pressing F5 repeatedly as soon as you start your computer. Select the option for safe mode. Once you are in then you need to go to the device manager. Click on the run option on your start button then type compmgmt.msc. Click on device manager on the left side. Then click on display adapters, select your graphics card by double clicking on it. Select the driver tab and uninstall the device. Once you do this reboot with the new monitor plugged in. The operating system should install plug and play hardware automatically. Then you can install the software afterwards once you logon on. Special note: you might have to do this with the old monitor first. Once you uninstall the display driver turn your machine off and connect the new monitor. I hope this helps.
Posted on Mar 03, 2009
  • Edgar Roman Mar 05, 2009
    In the BIOS setup you must set the PCI card as the default video
    display. Search your settings until you can find it. It is usually
    under the advance settings. Depending on your computer, the Techguru2009: BIOS is
    accessed when you start your computer by pressing either F2 or Delete
    key, sometimes its F1 or F12. Try this then Delete all display adapters
    in safe mode, repeat the steps above.In the BIOS setup you must set the PCI card as the default video
    under the advance settings. Depending on your computer, the BIOS is
Samsung syncmaster 930b 19inch: blinking green light on startup screen does not respond turn off or on after a random time period it usually works once screen goes from black to windows it stays...
<P>If you try new cable, try with another PC and still have the same problem, then you need to inspect the inside for bad caps first just like all the SAMSUNG as shown.</P><P style="tab-stops: center 3.25in left 255.75pt"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A href="http://s807.photobucket.com/home/budm/allalbums"><FONT color=#800080>http://s807.photobucket.com/home/budm/allalbums</FONT></A><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</A><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <A href="http://lcdalternatives.auctivacommerce.com/Viewsonic-C196320.aspx"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>http://lcdalternatives.auctivacommerce.com/</A><SPAN style="mso-spacerun: yes">&nbsp; </SPAN>he can make you a set of caps for you.<o:p></o:p></SPAN></P><P>&nbsp;</P>
Aug 25, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
My Samsung 913t says "Check Signal Cable." HELP PLEASE!!!
Cheap CRT monitors can be picked up at Thrift Stores, quick and cheap way to test your computer output.
Sep 22, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Samsung LCD 19" monitor problem
Does the monitor plug into a card or the motherboard socket?
Mar 25, 2009 | Samsung SyncMaster 920N 19" LCD Flat Panel...
My Samsung SyncMaster 215TW Monitor only flashes on for a second when I hit the standby button, and wiggle the mouse. I can't get the monitor display to stay on. Can you help?
If it is not still covered under warranty, start by opening the case. Once you remove the power board, you will probably notice several capacitors (the round, can shaped parts) that have tops that are not flat. If you see any that have bubbled tops instead of being completely flat, they need replaced. Once they are replaced, the monitor should turn right back on. Hope this helps.
Nov 28, 2008 | Samsung SyncMaster 931B 19" LCD Monitor
My 19 samsung computer lcd monitor problem
Hi
I repair quite a few models of monitors and in MOST cases when a monitor goes to sleep, the light becomes a steady dim amber color.
If they flash that is usually an indication the the powerboard is not putting out enough power to run the unit or there is a problem with the inverter board.
It will more than likely have to be opened up to determine the problem.
ebaypowerseller
bammbammfran
Oct 14, 2008 | Computers & Internet
My samsung Syncmaster 940mw wont turn on when the pc is turned on
Your needs internal servicing by experienced person. Capacitor or ERT may be malfunctioning
May 25, 2008 | Samsung SyncMaster 940MW 19" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
