Question about Video Game Consoles & Games
Ps3 cd spin, screen said no media or server found
  • 5 more comments
  • dickwood Mar 03, 2009
    I try dvd works ok, game do not work
    I replace the lens.same problem
    replace lens,I try lens cleaner same problem
    rainbowsix vagas2 also I try 5 more games
    I have verizon wireless,when eject game disc have marks on it,like like streek
    when eject game have marks on it
    thank you I will try that
  • 916 Answers
This is a common issue with the ps3 call sony and they will fix it for you.
Posted on Mar 03, 2009
  • 408 Answers
Sounds to me like a faulty Blu-ray drive.  More than likely you will have to replace the drive.  I am not to sure if Sony will cover it even if it is under warranty.  It is best to call their tech support.
    President:
  • 1,952 Answers
It's your blu-ray drive. You've got the number one problem facing PS3 owners.
It's a Sony defect.
Check out my guide here:
http://rescuetechla.blogspot.com/
  • 5 more comments
  • mohammed marika thambi
    mohammed marika thambi Mar 03, 2009
    It's a Sony
    defect with the blu-ray lasers. They only last 1-3 years with average
    use. If your PS3 is less than a year old and you still have the
    original receipt Sony will repair the problem for free. Otherwise
    they're going to charge you $150 for the repair. You can reach them at:
    1-800-345-SONY
    Unless you have a technical background in
    electronics there's nothing I would suggest doing. A firmware update
    and or CD /DVD cleaner disk will do nothing for your problem. I've
    fixed more than 100 PS3's with this exact problem so I know exactly
    what I'm talking about.
    problems with the video
    compression would reveal themselves
    I would suggest getting a disc cleaning kit, there might be some dust
    inside there and could be causing the laser to not work properly. I'd
    also check your NHL 09 disc and any other discs for that matter for any
    scratches or marks because sometimes when a disc reader plays up it can
    mark your discs. Good luck with it all and I hope it gets sorted soon!
    Try reformatting the system. If that dosn;t work your drive is done
    Hook it back up to with the component cables and the press the power
    button on the PS3 and hold it for about 5 sec, it should beep then
    restart, this will reset the video settings and should detect the new
    hook up.
    The PS3's Ethernet port works without any setup, aside from maybe popping in an IP address if you need to. Wireless
    is a different issue, however. WiFi isn't automatically detected, and while you can go and manually add a wireless adapter,
    the OS doesn't try to help and choose which brand it is. So if you
    aren't all that savvy, it's going to end up a guessing game.
  • 6,784 Answers
This is a core issue that will need the attention of a qualified Sony technician. i would call Sony for this repair.
    Sergeant:
    Novelist:
  • 277 Answers
The internal lens is gone faulty or dust collected on it it needs cleaning or replacement.
  • 19,396 Answers
That means that the lens pickup is not reading the cd.
Often this happens because of dirty lens.
Try first using a dvd lens cleaner , like the ones here.
If that does not work contact Sony calling the numbel listed on the PS3 user manual.
  • Ginko
    Ginko Mar 04, 2009
    If the game has marks on it, then the CD can be dirty.
    Try cleaning the game CD surface under tap water (yes tap water, CD is plastic, just be careful that cd has no paper sticker cover).
    After cleaning the CD, dry carefully with a soft cloth, taking care not to let residual water on CD.
    Let us know how it goes.
  • 10,594 Answers
Does PS3 plays DVD?
Are you playing blu-ray and getting error message?
  • Shahid Electronics
    Shahid Electronics Mar 03, 2009
    Please hook PS3 to Broadband Internet connection (eathernet port at rear) and let it update firmware from Sony PS3 website automatically and then check.
    Still no joy, optical block seems in problem and best way is to call Sony Support for fix.
  • 13,433 Answers
Try another disc, do dvds or blueray work is this problem with a spesific game or cd?
  • Ekse Mar 03, 2009
    Can you tell me what game it is, is this problem with only one game which game is it? Thanks
  • Ekse Mar 03, 2009
    Ok the problem is not with lense. This seems to be a problem with your internet connection. For start. Try pluging the ps3 directly to your dsl modem. and see if that helps.
Ps3 says dnla problem and won't play any thing what do i do
Hi ericparvin,
Since you haven't specify what it is you are trying to do or play, I'm assuming from the error that you are getting, maybe you are trying to stream your media to your PS3. if that is the case, reboot your PC or source system then reboot your PS3 console as well.
Since PS3 has playback limitations, what I usually recommend is the PS3 Media Server, you can get it here:
code.google.com/p/ps3mediaserver/
just download the latest version then install it on your PC, run it. it will automatically search for the PS3 console on the network, once found. go to the PS3 XMB and look for PS3 Media Server Icon. it will even encode mkv files but you need a beef up system.
Hope that helps, if you still have problems post here.
Regards,
Ragoney
Mar 30, 2011 | Sony Playstation 3 (PS3) Console
Streaming videos over the LAN to PS3
I stream without any problems using the PS3 Media Server, free bit of software that you can d/load and install on your laptop (just google it, i found it within seconds).
Really simple to use, just add the folder where your videos are then you can access via the PS3 dashboard
Feb 27, 2010 | Sony Playstation 3 (PS3) Console
Ps3 found media server(linkstation) but cannot see any of the video files? can see video files thru windows xp. how do i get ps3 to see the video files?
there is no one blanket answer to this problem that could have many causes. It could be the DLNA server on the linkstation, it could be the version of the firmware on the PS3 or it could be the files that you have on the linkstation, BUT this link on the sony forum touches on some of these and offers some solutions http://boardsus.playstation.com/t5/PlayStation-3-Media/My-Buffalo-LinkStation-experience-so-far/m-p/29300220 However most people seem to install something called twonky server, which i am planning to do...... hope this gets you started. Peter
Sep 13, 2009 | Buffalo Technology Computers & Internet
PS3 no longer reads discs after 2.80 system upgrade
Send it to best buy and they will fix it for you thats what I did with mine
Hope it helps
Aug 20, 2009 | Sony Playstation 3 (PS3) Console
Can not connect to media server.
check you Upnp settings in the router and check test your connection on the ps3 if you are getting Nat 3 the upnp might not be on or functioning properly
Jul 28, 2009 | D-Link DIR-625 (790069292637) Wireless...
No media or server found
Ok do not worry this may mean two things crached hard drive or a corrupted hard drive all you have to do is turn it on but let the red ligth be on turn it on do not remove your finger from the button until it go's off again turn it on again keep your finger until it makes a sound but still do not remover your finger untill it makes two sounds after eachouther take your finger of fast nou a screen will apear say restore sestem untill your ps3 works again it take 1-4 trys and if nothing happens you must format it.HOPE I WAS USEFULL PLZZ RATE ME AND IF THERE IS ANYTHING ELS EMAIL ME TO markusmaritz@yahoo.com I DO PS1,2,3,DVD PLAYERS AND PC sorry for my spelling i am only 13 and i afrikaans BUT PLZZZ RATE ME...............................
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
My ps3 is "searching for media servers" and not letting me play any dvd's
That means you clicked the icon to search for a media server. When you enter a BluyRay disk and you go to the Video section, you should see your BluRay disk icon below the media server icon.
May 31, 2008 | Sony Playstation 3 (PS3) Console
How to get multimedia on my ps3
ok, lsn on ur pc or laptop open windows media player (((11))) add there all kind of media(Move,Music,Pics...ets) u wanna share or add to PS3, then go to library there is an arrow under it, click it and go to media sharing, now turn ur PS3 on and go lets say to Music part in the menu and click on Search for Media server it will tell u that there is 1 media server found ok, go to the pc or laptop and KEEP ur Windows Media Player Active dont close it okkk, there will be a msg from WMPlayer telling u that there is a device trying to connect with me what should i do? u should click Allow, now as soon as u Allow PS3 to connect with WMPlayer it will share everything u've added to WMPlayer with PS3 without moving it to PS3 so u will lose Space in ur PS3, PS3 will now browse ur Library and u can choose which file to run and u can choose a wallpaper for ur PS3 even when turn ur PC or laptop off, u will still be able to see ur new background picture. and thats it looooooool :)))
Mar 14, 2008 | Video Game Consoles & Games
PS3 wont play blue ray disk
press and hold down the power button on the ps3
Jan 01, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
18 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
