I want to use a Compaq 14-pin ATX power supply from a Deskpro 4000EN
on a normal 20-pin ATX motherboard (I know this sounds silly, but I
have two other 4000en's running Linux and Solaris, and this 90W PSU is
extremely quiet, so this case/PSU would make i nice home for my
mini-ITX allways-on system, which only needs 50Wor so)
So if this isn't a totally rediculous idea, then how would I wire the
14-pin PSU to 20-pin mobo?
PSU System board
1 +3.3Vdc 1 +3.3Vdc
2 +3.3V Sense 2 +3.3Vdc
3 Signal GND 3 Signal GND
4 +5Vdc 4 +5Vdc
5 Signal GND 5 Signal GND
6 +5Vdc 6 +5Vdc
7 Signal GND 7 Signal GND
8 +3.3Vdc 8 PWR-OK
9 -12Vdc 9 +5VSB
10 Fan Off 10 +12Vdc
11 On/STBY 11 +3.3Vdc / 3.3V Sense
12 +5V Aux 12 -12Vdc
13 +3.3V Sense 13 Signal GND
14 +12Vdc 14 PS-ON
15 Signal GND
16 Signal GND
17 Signal GND
18 -5Vdc
19 +5Vdc
20 +5Vdc
Thanks
Rating: 0%, 0 votes
The uATX spec never did have it. Whether or not *you* need it depends
on the MB you are using.
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
Ahhh, I missed that I didn't have a -5v source on the psu. Oh well.
thanx
-jaz-
(Please excuse the 'burp' when replying)
Rating: 0%, 0 votes
-5 & -12V source ; IMHO not worth the trouble & problems realising
that; these days even small & quiet PSU are available @ reasonable
prices
-- Regards, SPAJKY
& visit site - #
Celly-III OC-ed,"Tualatin on BX-Slot1-MoBo!"
E-mail AntiSpam: remove ##
Rating: 0%, 0 votes
on the wires of the good supply. It doesn't matter which supply is
which, just that you jet the proper wire function on the proper wire.
Rating: 0%, 0 votes
Actually, it's the 14-pin PSU that I want to use -- it's not that this
power supply is blown, but that it's integrated into the case. So I'd
like to try to use it with a new 20-pin motherboard. I even have an
older standard 20-pin mobo that I can use as a test bed to make sure
the conversion isn't going to fry the new mobo (not right off the bat
anyway)
-jaz-
Post a New problem for Compaq 90W Power Supply IPAQ PC /
Email this problem
Can you Help with these System Power Supplies problems?
Power Adaptor for 500GB LaCie...
Lanier VoiceWrite EX won't come...
