Question about Casio Triple Sensor Pathfinder PRG60-1AV Wrist Watch
I need a REPLACEMENT CTL 1616 battery for my Casio PRG-60
I found one of these on ebay. Here's the item I ordered.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=310129530689
I used the instructions here to replace the battery myself:
http://forums.watchuseek.com/showthread.php?p=226461#post226461
Hope this helps.
Posted on Mar 30, 2009
  • 2,334 Answers
Any watchmakers shop will supply the battery or you can by it on eBay and replace yourself.
Posted on Mar 03, 2009
I need to buy strap only for model prg-110b
Go to your local Jewelry (watch) H samuels , HINDS bout expect to pay a lot .
Dec 24, 2015 | Casio Protrek Triple Sensor Prg 110T 7VDR...
Casio PRG-80L reads open
Have the same problem, Casio PRG-80L reads open. No hints about this in the manual. Nor did Votit's suggestion help. Note that although the watch is old there is clearly power left in the capacitor battery. Ended up accidently ito this mode when resetting the time. Assume the open mode is intended for service, but would just like to exit.
Nov 03, 2012 | Casio PRG-40T-7 Pathfinder
Battery its ctl1616 they said NO NEED FOR BATTERY CHANGE but it's not true. How many year this battery last?
The CTL 1616 is a special device.
It's not really a battery, but a "capacitor", which means, that it's mainly supplied by the energy of the light. The capacitor is designed to maintain the functions only for (short) periods of darkness.
It's NOT a "standard lithium battery", because It has a different voltage (2.3 V instead of 3 V) and consists of different materials.
Unfortunately, the capacitor loses its ability to store the energy over the time. So your watch may be able to maintain all the functions for more than 11 months of darkness in the BEGINNING, but after a few years it may only last for a few hours!
However this may be STRONGLY influenced by the use of the functions: for example the automatic reception of radio signals or using a digital compass may strain the energy seriously.
So, the use of different functions may affect the lifetime of a CTL 1616.
I also recommend to expose the watch to (bright) light as often as possible in order to maintain a HIGH level of stored energy.
I also heared that there were serious problems with the quality of this type of capacitor a few years ago. Maybe a new CTL 1616 will last for decades.
Jan 28, 2011 | Casio G-Shock GW1310
I have a gw300 and the battery is dead and i am looking for a new battery.
Ebay: http://shop.ebay.com/idiotdoc/m.html?_nkw=Casio+G-Shock+CTL1616+CTL+1616+Panasonic+Watch+Battery]&_sacat=0&_odkw=&_osacat=0&bkBtn=&_trksid=p3911.m270.l1313
May 14, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
How do I reset my Casio PRG-40 following battery replacement?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please .
Apr 08, 2010 | Casio Protrek Triple Sensor Tough Solar...
After changing the battery nothing can be changed, no function possible and"open" remains written on the display, the type of the battery is clt 1616
The battery is CTL 1616 and I had the same occurance when I opened up my model Casio model 3043. I needed to use the battery to test my model 2767 and find out if a new battery would bring it back to life (yes, it still lives). After replacing the battey back into my 3043, I jumped the (ac) to (-) and at first the watch would indicate all was well but then it would revert back to "open". I tried over and over to try and get the "open" display to clear but I was not successful. I then thought to go ahead and replace the back on the case to see if the three contact springs would change the display and sure enough, "open" no longer was in the display. The watch works perfectly as before. As for the 2767, as soon as I jumped the (ac) to (-) the "open" display went away. There is only one spring contact to the back case on the 2767 model. Unfortunately I do have an extra spring that fell out when I opened it up and I have no clue as to where it goes. I have not found anyone who can help me on the location for the shorter spring. Any advice would be most helpful.
May 20, 2009 | Casio Triple Sensor Pathfinder PRG60-1AV...
Battery replacement
You can do it yourself. Unscrew watch caseback and undo the contact on top of battery. Read the writings on battery and buy exactly the same one. Do not mind manufacturers (Casio, Maxell, e.t.c.), just make sure the numbers are the same.
Some watch casebacks can be opened only if the watch band is removed, so, remove it if needed, just don't forget to memorize where every part and screw was fitted. Memorize how the battery is fitted and do not put the new one the other way around as this can damage your watch.
Actually there is nothing difficult - only you have to put everything back exactly the same way as it was. If your watch will be left without battery for more than 3 minutes, you will need to reset your watch after replacing a new battery, but it's easy if you've got users manual.
Good luck.
Do not forget to rate, please.
Mar 11, 2009 | Casio PRG-40T-7 Pathfinder
What type of battery goes into Casio G shock MTG900, Module 2638
CTL is the designation for a rechargeable secondary battery. The CR is a primary disposable battery and is a 3 volt cell. The CTL1616 while the same size as the CR1616 function completely differently and are not interchangeable. The CTL1616 is 2.3 volts and is recharged by solar or light or kinetic movement. The CR1616 is 3 volts is not rechargeable and will not function properly in a time piece designed for a 2.3 volt circuit. There is only one manufacturer of the CTL1616, Panasonic and they sell through Casio parts distribution.
Jan 22, 2009 | Luminox 3102 (Size: ) Watch for Men
Battery replacement prg 40 model 2271
The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
Aug 20, 2008 | Casio PRG-40T-7 Pathfinder
Casio pro-trek PRG-60T Buttons no longer activate anything.
Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Feb 19, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Casio Triple Sensor Pathfinder PRG60-1AV Wrist Watch Logo
1,777 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
