I have a 1998 Chevy cavalier with Avital 3200 remote starter installed. When i push the remote to start the car all lights come like its gone to start, then nothing happens.Cant even turn car on with key.Is there something that needs to be reset on remote.
  • 95 Answers
It sounds like its the bypass module. When it doesnt start the car goes into security mode and wont let it start for up to 15 minutes. I would check the bypass module to see if it still has power or has been reset, if its not something you can do, bring it to a local mobile electronics shop and they should be able to take care of it for ya.
Posted on Mar 03, 2009
2002 cavalier, ignition cylinder was changed for pass lock failure now remote start cranks but wont start. avital 4103L
Hi, ur problem is a simple one. U have a factory alarm-starter kill. The key and ecm have to comunicate. Ur alarm has a digital modual to make the ecm think its seeing the key when u remote start. Since u changed the "code"u have to reprogram your alarm interphase so it all comunicates the code.
Nov 28, 2015 | 4103LX Remote Start System with Two...
Need to program additional fob to Avistart 4111
Turn ignition on, press and release valet switch then, press and hold valet switch. Press button on remote. Release valet switch, turn off ignition. Test
Feb 08, 2014 | 4111 4111L Remote Car Starter
Avital 5303 kills engine while driving 1998 honda civic
you check to see if the engine was hot or something like if the water level in the radiator was down the sensors in the security system would pick it up
Jan 27, 2014 | 5303L 2Way LCD Remote Start Security...
Avital 4103 when i push start button the ignition lights come on but doesn't start the engine
Try leaving the key in the ignition (but don't turn it) and then try. If it starts then you need to properly bypass the transponder system. If not then most likely you don't have your ignition and/or start wires hooked up properly. On many cars there is a second starter wire that needs to be connected
Feb 17, 2013 | 4103LX 4Button Remote Start System with...
Need car started with no key
To start a car without a key you will need a remote starter installed into the ignition. Push the start button on your wireless remote to start the car.
Oct 05, 2012 | 1998 Chevrolet Cavalier
Both remotes failed to either start the car or lock or unlock the car this evening.. after entering with the key the old fashioned way, the car will not start with the key,the starter turns over fine...
no reset button, sorry. If the starter is turning over, then it's more than likely not an alarm or keyless problem. if it was even connected, the starter kill feature is used to "cut" the starter wire from the ignition and the starter itself, and if you say it's turning over, that's where i get my answer for it not being the avital. of course there could be more to it, remote start added, and the type of car make a huge difference, could be a bypass module for bypassing a factory security system, so without any more info, that's all i can give you. hope this helps, dave
Nov 10, 2010 | 2101L Keyless Entry
Hello. I have an Avital 4103 system and the key light on the dash does not go out after starting the car, inserting the ignition key and turning. I can drive the car, but the key light keeps flashing and...
I have a Dodge Caravan 2001 SE. Had the Avital 4103 installed. My question is, before installation i had a Chrysler car alarm in the van. When the remote start was installed they removed the alarm.
The shut down toggle switch was not installed, also the push button valet switch was not installed also. Is this a correct installation, I was told that I did not need the last two items to be installed.
Oct 27, 2009 | 831002/4100 4100 REMOTE START SYSTEM WITH...
690 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
