Question about Sony DCR-TRV285E Digital-8 Digital Camcorder
Power does not flow in
My Digital Camcorder SONY TRV330E has encountered with a problem of NOT ALLOWING the electric power to flow in when the power connecter is connected to camcorder's socket.
In actual, it the camcorder immediately will start functioning when power connector is connected to camcorder.
But what i have noticed is that the when connected the power flows for few seconds (say 15 seconds) and then gets disconneted or power is not drawn in.
Please help me what to do in this regard.
Thanks. Meganathan.
  • Meganathan Vedaram Mar 03, 2009
    I just now cleaned and tried, but still it is not drawing power.
    What i noticed earlier the whole day was that, if i reconnect say after 4 or 5 hours then it is drawing power for few seconds and then again it stops and does'nt start again for long and goes off.
    This is the problem.
    Regards,
    Meganathan.
  • 583 Answers
There are metal connectors in the camera that get touched to the connector that which you connect the camera.if that connectors are bent or dusty or got internally loose.this happens.it should be checked as if its bent or dirty you can manually do.but if loose internally taking it to the repair center is necessary.
Posted on Mar 03, 2009
Sony Digital Handycam error c 31.21.have tried all the posted solutions.....no luck!!! should i try brand new tape? thanks
I've a PC9 (close cousin of 101) when it first came out and have never encountered a C31 before. You've probably try putting in a new tape by now. What's the verdict?
May 20, 2010 | Sony Handycam DCR-PC101E Mini DV Digital...
You have to hold up on the power cord to make it power on. Put tension on the cord so it will work.
One of the wires in your power cord broke. When you hold the cord up or put tension on it, you are pushing the broken ends together, allowing the electric current to flow through the cord.
You need to replace that power cord. It is both a nuisance and possibly a fire hazard.
Nov 26, 2009 | Sony PlayStation 2 Slimline Console
On a sony digital handycam digital 8 TRV 250. what does the self diagnosis display c:31:32 mean?
A malfunction other than the above that you can service has occurred.
  • Eject the cassette and insert it again, then operate your camcorder.
  • Disconnect the power cord of the AC Adapter or remove the battery pack. After reconnecting the power source, operate your camcorder
Oct 21, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
I had a power surge and my sony dcr-trv350 will not trn on is it worth fixing?
Follow this procedure to troubleshoot if the camcorder will not turn on.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony eSupport Web site.
  1. Remove the battery from the camcorder.
  2. Connect the AC power adapter to the camcorder.
  3. Plug the AC power adapter into a working electrical outlet.
  4. Attempt to turn on the camcorder.
  5. Reset the camcorder back to factory settings.
  6. NOTES:
    • If the camcorder does not operate using the AC adapter, service may be required .
    • If the camcorder does operate using the AC adapter, proceed with the steps below to troubleshoot the battery.
  7. Ensure the battery has been fully charged.
  8. Ensure the battery is properly inserted into the camcorder.
  9. Remove the AC power adapter from the camcorder.
  10. Attempt to turn on the camcorder.
  11. NOTES:
    • If the camcorder does not turn on, then the battery may need to be replaced.
Aug 14, 2009 | Sony Handycam HDR-HC7 Mini DV Digital...
Transfer 8mm,hi8,digital 8 to pc
Since my request..Found i could answer my own questions. Brought firewire card with 6 pin socket.Also brought a cable with a 6 pin to fit the firewire card @ a 4 pin on the other end for the camera .Found my install cd. Loaded the USB installation. Got my connection completed between the camera @ the computer.With regard to the tape formats no problems at all.With nero 6 not sure yet.My home movies go back as far as 1989 and the quality is as good as new.Hope SONY don't stop making the dv tapes. With the external hard drives for editing @ storage need an answer for capacity James from Auckland New Zealand.
May 16, 2009 | Sony Handycam DCR-TRV330 Digital Camcorder
Tape door won't shut and message C:31:40
You need a qualifier Tech trained from Sony to repair your CAM
Your problem is that the cassette compartment it had 2 sensor and a few contact to detect what kind of tape you are insert like normal, metal or Digital 8 or Hi 8 or 8 Standar or cleaning tape so the system control would auto adjust according the tape
Those contact conducted by flexible cable now that FC may be cut or the sensor faulty when you insert the tape the CAM detected 1 side of the tape so it juded like some thing wrong with the tape then it will not load the tape in because it designed to protect the tape and protect mechanism
Without the tape no problem because the sensor or contact at the right corner of CAM did not detect any thing
If You want to know how it detect what kind of the tape, just turn the D8 tape up side down, you can see the holes on the left and right corner where is the tab for save and record
You need to replace 1 chassis LS assembly it cost about $250 to $350 if you are in AUSTRALIA
I hope that give you some ideas
Nov 25, 2008 | Sony DCR-TRV285E Digital-8 Digital...
Problem when downloading from camcorder to computer
When I download from camcorder to computer the video onCD is with bad resolution
Mar 21, 2008 | Sony DCR-TRV285E Digital-8 Digital...
Sony DCR-TRV285E Digital-8 Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
