Turn on dvd
My signa dvd doesn't switch from red (off) to green (on) =merrick ny
  • 583 Answers
Its the power supply fuse problem.the fuse controls the on /off in the unit.that fuse needs replacement.
Posted on Mar 03, 2009
My remote control want work
1) change the batteries by new ones
2) clean the contacts batteries with contacts cleaners
3) retight the springs contacts with pliers for good contact
4) open the remote control for clean the keypads switch, from oxide, corrosion, etc for to send good signa infrared to the microcontroller devices(DVD player)
if this not work you must go to the repair shop TV for fix it.
God bless you
Jul 15, 2012 | Vizio VBR120 Player
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
When I turn on my set, light turns green, then after 30 seconds turns red won't come on
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
When I switch to the DVD player on my Samsung Big screen TV, the pictures turns green. Tom
If the DVD player is hooked up with a Component Input connection on the TV. A red, blue, and green wire for video, one of them is backwards and needs to be switched and plugged in correctly.
Dec 24, 2009 | Samsung DLP HL-P5663W 56" TV
Left turn signa on 1999 malibu does not work when
I need more detail, but look in to the turn signal switch. it controls head lights turn signals ect.
Sep 04, 2009 | 1999 Chevrolet Malibu
After descaling stuck in infinite loop
How old are your machine?
How often do you descale the machine?
I think it can be the flowmeter in the machine that needs to be replaced.
Try to descale the machine to see if it help.
Best regards
Sep 07, 2008 | Saeco Caffe Charisma Espresso Machine
Green light is flashing on my garage door opener on the inside of my house/craftsman opener
Hi. The green light was flashing and ny transmitter in the car would no longer operate the door. On the back of the liftmaster, just below wker the small wires go in, there is a small, flat, green button. I pressed that with a stick and it solved the problem.
Jun 27, 2008 | Sears Craftsman LiftMaster Chamberlain...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
