Question about VAX Appliances 2000 Canister Vacuum
Wiring diagram I have a replacement main switch for my vacuum cleaner. Two blue and two brown but no diagram or markings on terminals to show which wire goes to which terminal
  • 583 Answers
Polaris 9300 sport pool cleaner. the wires pulled free from the plug into the power supply. not sure which wire goes where. There are 3 red black and brown. 4 holes for them to go back into.
Without a wiring diagram it will need either model knowledge or some educated guesswork aided by a multimeter and carefully studying the internal wiring of the power supply.
Without a great deal of additional description I can't help further other than to suggest you contact the retailer who sold the appliance.
May 31, 2016 | Blue Wave Polaris 9300 Sport Robo Cleaner...
Wiring diagram
First check the cord to make sure you have continunity throw both leads, check them at the cord reel, there are 2 wires hooked up to it, if not then the cord is bad. Check the swith also, the next cause would be the speen control mounted on the motor, part #04416342, sells for around $85. If your motor checks ok, then it most likely the speed control, they go out quite often...Thank you
Regards!!!...
Jul 24, 2008 | Miele Cat & Dog 326i Bagged Canister...
Kirby ultimate g vacuum cleaner (not the shampooer) leaving white marks/trails all over brown carpet
This is not a normal occurence...maybe something the previous owner did or used the vacuum on?? A KIRBY will not normally leave any marks on Your carpet..
Lee in Australia
Oct 14, 2012 | Kirby Ultimate G Bagged Upright Vacuum
No power,fuse ok . i want to remove the casing but cannot find how,
If it's a sealed plug you won't?? cut off old plug and fit new standard plug brown to fuse blue to terminal on left yellow/green top terminal!!
most sealed plugs have fuse showing on bottom which just lift out!!
Jan 17, 2011 | Vacuums
I need diagram of replacing on/off switch for Oreck XL2600
Manual would not, they want you to pay a service tech.
Believe this model has switch in grip,
1. Unplug unit.
2. remove screws from grip.
separate the grip halves to access switch.
3. I believe the power cord, where it enters the grip, has slip on terminals that fit on the switch. Just substitute the wires and re-assemble.
Should not require any soldering. Be careful, routing of the cord in the handle is difficult as I remember, depending on the year model, sometime in late 90s they went from a molded in strain relief to a serpentine path.
Jun 19, 2009 | Oreck XL2600 Vacuum
Dyson dc05 motor cuts out
Check for either voltage to switch or if your not happy or compettant working on live mains.
Switch meter to ohms ensure vacuum is unpluged from mains follow live wire (brown) from plug to exit point on the back of cable rewinder check for continuity shold be dead short if it is check switch if this is ok move to neutral (blue) wire again check from plug to rear of cable winder.
The neutral then goes off to moter again check for dead short,
I think from experience that you will have A break in either live or neutral in the mains lead going to cable winder.
If it is its realy easy to replace winder they come with lead all ready fitted.
If you need one contact me.
http://dysonmanuals.llc.nu/index.htm
Chris...
Nov 16, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Wiring diagram
Check the cord to make sure you have continunity throw both leads, check them at the cord reel, there are 2 wires hooked up to it, if not then the cord is bad. Check the swith also, the next cause would be the speen control mounted on the motor, part #04416342, sells for around $85. If your motor checks ok, then it most likely the speed control, they go out quite often.
Jan 17, 2008 | Miele Cat & Dog 326i Bagged Canister...
VAX Appliances 2000 Canister Vacuum Logo
392 people viewed this question
Top VAX Appliances Vacuums Experts
Ryan S
Ryan S
Custom Exchange
Custom Exchange
Are you a VAX Appliances Vacuum Expert? Answer questions, earn points and help others
