Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I can't work out how to use the scanner
I want to scan some A4 documents on to my Mac using my Epson Stylus photo RX520.  I'm evidently being a bit dim but I can't work out how to do it.
    New Friend:
Instead of people just posting links to websites and instruction manuals or general drivers, it it more helpful to answer the question.
The resolution to the issue of not being able to scan A4 directly from the RX520 is that you can't do it from the printers control panel. You need the software, Epson Scan. The one I needed for my mac is here.. http://esupport.epson-europe.com/FileDetails.aspx?lng=en-GB&data=vRaxNXeC8zjpwXneB3wC0JM+3mL8GgugSyPaKr4sHqEU003D&id=325981
For other machines/OS versions you may need to navigate around this part of Epson's site. You can also use their free chat facility to speak with an agent. It's very good
Posted on May 17, 2013
    President:
  • 2,692 Answers
Posted on Mar 07, 2009
How do you scan a document using a pc?
The printer can be used for scanning without a computer in sense of the scanner offering a copying facility - in B+W or Colour just by pressing the appropriate button on the printer. However, for scanning via the computer, if you are using a Photo programme (like say Adobe Photoshop or virtually all such programmes) normally you will find under the FILE menu (when programme is open) that you should see a menu item on the drop down menu when you click on FILE something like IMPORT - and the Epson printer will be seen listed in the menu that pops up. If you click on that, the Epson scanner programme will start. Normally there is a simple mode but you can change that to the PRO (or may be called Advanced mode) when you can do things like PREVIEW - which will then scan the document or photo in the scanner - and you can in the PRO mode change such as the resolution, what type of documents and so forth. When the Preview runs, you will see the document appear after the quick scan in the main RH panel. You can use a select tool to select the bit you want to scan if not the whole - most into on this will be in their manual - which you should have on the CD that came with the printer. Anyway - always worth ensuring you have the latest drivers, etc. so go to this link on the Epson website, click on Scanner Driver and Scanner Utility and download and install. Whilst on the Epson website, download the manual for that model as it will answer many queries for you as regards printing and scanning. All such info and software for downloading is under SUPPORT area - you select the region in the World where you live, then search for your printer model. The Epson website will normally auto-detect your computer's operating system to ensure you get the right version of Printer Drivers, other software and so forth. If you have no Photo Programme as yet - get Faststone Image Viewer (free) as an excellent programme. http://www.faststone.org/FSViewerDownload.htm
Jun 25, 2014 | Epson Stylus Multifunction Inkjet Printer/...
Hi, my stylus photo rx520 scanner is not working correctly. printout looks like a tartan pattern. the scan operates but with this odd result. I have deleted the printer driver and reloaded it twice now but...
try to download epson scan from the website www.epson.com and then look for the updated version of epson scan. read the details and add ons that will greatly help you with your desired scanning operation
Sep 11, 2009 | Epson Stylus RX500 All-In-One InkJet...
Hi, my stylus photo rx520 scanner is not working correctly. printout looks like a tartan pattern. the scan operates but with this odd result. many thanks. Brian.
Check nozzle. Do head cleaning procedure from epson status monitor. wait for 15 minutes. Check nozzle again. Compare results from first and second nozzle check. Print out will perfect if the result of nozzle check as good as display pattern in nozzle check dialog box.
Aug 30, 2009 | Epson Stylus RX500 All-In-One InkJet...
I'm trying to enlarge a scanned photo, then print it on my Epson
Hi, scan at around 350dpi, save the image file as a jped and then import it into word or other program that will accept jpegs and you can make the image as big as you want up to A4 or letter size (depending on the paper size you use
Jan 27, 2009 | Epson Stylus Multifunction Inkjet Printer/...
My computor does not recognise my scanner
Hi
Pls check for updated driver for scanner on support.epson.com, because i believe that this printer doesn't have a wireless scanner server so the scanner will not work wirelessly.
Hope this helps
Nov 28, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson RX520- Does not scan the complete image.
Have lost my manual How do i install new ink cartridge Its my first time of doing this function
Oct 29, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Scan problem
try copying a page and see if that works
that will prove the unit is not faulty
if that works unplug the printer uninstall the printer software restart the computer reinstall the printer software and plug the printer in when asked.
if copy doesnt work the unit is most likely faulty
Oct 29, 2008 | Epson Printer
Epson RX520 feed problem when using glossy photo paper
clean the rubber rollers that pull the paper. hoping it 2 work fine....
Jan 13, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus Photo RX520
My epson rx520 has also the same problem.
Cant find a solution anywhere.
Jan 06, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
237 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
