Question about Toshiba 1370 Black and White Copier
Toshiba 1370 Wrench and C7 error but, 0 & 8 and 89 did not help
I have held 0 & 8 then 89 then green then 0 then green turned machine off and it has not helped. Any other suggestions. Thank you!
  • 398 Answers
Press 0 and 8 down before you turn on the machine, holding these down turn on copier, the display should say "ad" press 89 then start ( display will say 3 ) press 0 then start display goes back to "ad" turn off and on copier if wrench comes back take off red cover over hot section and in the middle there is a thermostat (1 screw) and toner build up under it needs to be removed.
Posted on Jun 19, 2009
    Scholar:
  • 136 Answers
FIRST OFF, ( YES i AM YELLING )
Who told you to go into this Service mode
THIS IS THE WRONG SERVICE MODE,
holding down the 0 and the 8 will not reset you fuser error mode, and by the way if your a tech STOP BEING LAZY,remove the fuser and check to see if your lamp is blown or your thermo-fuse popped
MAN I HATE LAZY TECHS,
btw this is not how you reset the fuser error code, you selected the wrong error
Posted on Mar 08, 2009
C7! Could someone help me on this trouble 'code' on my T1370???
i am having toshiba 1370 black & white copier it is not clear repeating the letter in paperToshiba 1370
Feb 22, 2012 | Toshiba 1370 Black and White Copier
I have a toshiba 1370 copier....the repair wrench is flashing and won't let me continue, how do i get the wrench to stop blinking?
switch on the machine, holding down 0 & 8 buttons, type in 89, press the green button, enter a 0, press green button again to accept the new value. switch off & then just switch back on as normal.
good luck.
Nov 13, 2009 | Toshiba 1370 Black and White Copier
I HAVE THE WRENCH ERROR; DO NOT KNOW WHAT TO DO FROM HERE
If you push clear and 8 does it say C7? Push 0 and 8 as you turn on the copier it should say ad on the display push 89 and start and (I bet 3 is displayed) push 0 and start this resets the "c7 counter"
Jun 18, 2009 | Toshiba 1370 Black and White Copier
Wrench light on and c7 code appear
C7 is a Fuser Error......The hot part where the paper passes through before exiting the machine is known as the Fuser or Fixing unit etc.
There are 3 parts involved and any of which when they fail will give a C7 error code. The Heating Lamp,Thermisor or Thermal Fuse.
This is a live area of the machine so you wouldnt be advised to attempt a repair without at least a restricted electrical license.
More than likely one of the parts mentioned will need to be replaced and then the C7 error count reset through "08"
May 12, 2008 | Toshiba 1370 Black and White Copier
C7 error???
Turn on the power holding 0&8, key in 89, and press print. A 3 will probably be displayed. Key in 0 and press start. Recycle power.
Feb 28, 2008 | Toshiba 1370 Black and White Copier
TROUBLESHOOTING
hi
Switch on the machine, holding down 0 & 8 buttons, type in 89, press the green button, enter a 0, press green button again to accept the new value. switch off & then just switch back on as normal.
work? reply.
Jan 17, 2008 | Toshiba 1370 Black and White Copier
C7 ERROR CODE
Your printer needs to be reseted.
Here's how to do it:
Hope it will work and solve your problem.
Toshiba 1360
You should be able to retrieve a code for a malfunction by pressing down the clear/stop and 8 keys. then let me know what you get, and we will go from there.
Oct 22, 2007 | Toshiba 1360 Black and White Copier
Red "wrench" indicator always on
Press the clear and the 8 button at the same time . This will give you a error code. I will guess that you have a "C7". If you still want to fix let me know error code.
Oct 25, 2006 | Toshiba 1370 Black and White Copier
Toshiba 1370 Black and White Copier Logo
1,007 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
