Question about Panasonic CT-27G7 27" TV
Slight crackle on left speaker if turn volume up
Technics su-610 slight crackle on left speaker if turn volume up quickly if turn up slowly does not do it, and once volume set does not miss a beat and sounds great only does this when loud button is on, if loud button is turnt off does not do it at all
    Guru:
  • 449 Answers
The speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Posted on Mar 03, 2009
On a Technic SU 610 amp, it makes a crackling noise when turning the volume pot up, if done slowly its not as bad but still makes a noise?
If it ocours only when turning your volume pot then the pot is worn or dirty inside. I f you are handy get a new pot that is EXACTLY the same and replace it It is simple if you can solder as there is usually only tree connections
Nov 28, 2012 | Audio Players & Recorders
M-audio av20 right speaker has no sound coming out of it at all...
To troubleshoot the problem start with the bit that is working - the left speaker.
  1. Unplug the input leads on the back of the left speaker and swap them round.
  2. If sound now comes out of right speaker and not the left the problem is with your sound source (computer, IPOD or whatever) or the connecting cable is faulty.
  3. If there is still no sound from the right speaker try turning the volume control knob up and down quickly several times - does this produce any sound from the right speaker? Sometimes the electrical contacts get dirty and this can help clean them.
  4. Turn the speakers off using the volume control knob. Disconnect the speaker wire for the right speaker from the OUTPUT on the left speaker (push the red and black tabs downwards and gently pull the wires out. Find a small 1.5 volt battery (an AA or AAA size will do nicely) and touch the bare ends of the speaker wire briefly on the battery terminals. If you hear a slight crackling sound the wire and the speaker are okay and the problem is in the amplifier, which will need repair or replacement - not a job for an amateur.
  5. If you don't get any sound from the battery test find another piece of speaker wire (any piece of 2 core cable with bare ends will do for testing) and repeat the battery test. If you get sound then replace the speaker wire. If not remove the speaker wire again and go to next step.
  6. Lay the speaker face downwards and carefully unscrew the back panel (don't do this if it is still under manufacturers warranty - take it back for repair or replacement). Lift the back panel off carefully and slowly taking care not to pull the connecting wires inside the cabinet, which will probably be quite short. You may have to settle for just rotating the back panel slightly so that you can see inside if the wires are too short to do otherwise.
  7. Use sticky tape to tightly attach the bare ends of the speaker wires to the terminals of the battery. Touch the loose ends of the speaker wires on the two metal terminals where the internal wires are joined onto the back of the big loudspeaker cone. If this produces a crackling sound it is the internal wiring in the cabinet that needs re-soldering. Otherwise the loudspeaker unit has failed and will need replacement.
Jan 29, 2011 | M-Audio Avid Maudio 99005226600...
I have an Technics SU-V3 amplifier when you try to adjust the sound it causes the speakers to crackle(only when your turning it) it is not the speakers as have tried it with several sets of speakers...
It sounds like the volume control itself is causing the problem. All you need do is get to it from the inside the unit and spray it with Servisol switch cleaner. That should do the trick. It's just dust in the track of the control. If there are any other rottary controls spray them too!
Dec 02, 2010 | Technics Audio Players & Recorders
Technics Integrated amplifier su-v85a speaker volume fluxuates and speaker left shuts down some times what is the problem?
test you speaker maybe there is a bad connection some where is the spk. box its self ,try changing speakers left to right .
it the spk. are ok open amp see all the connections within the amp .
if this dose not work contact me by mail: starilaz@net.hr
Oct 12, 2009 | Technics SUV500 2-Channel Amplifier
Technics su-v560 stereo amp crackling
That is a common symptom of not properly grounding of negative side of the output of power amplifier section.Just resolder all component parts joint in power amp.sectiton and double the solder all negative ground.Also clean the pots of all volume controls and selector with a lighter fluid or desame that fluid so whatever sound or crackling noise eliminated and works normal again.. Hope it may help you;;
Jun 08, 2009 | Technics Audio Players & Recorders
Crackleing
No its not EMI.- I have them too and mine are little over a year old. Have noticed the faint smell of electricial burning. Checked the sub and the amp/pwr supply in there must be slowly breaking down. I cant turn my speakers up past 25 percent volume and the crackling/hum gets very bad, We should all be looking for replacement at this point.
Nov 19, 2008 | Dell WL6000 Computer Speakers
Technics SU-g75 Amplifier. No longer any volume. Fuse is OK, display is fine, just no volume??
ALL speaker jacks must be loaded and closed for any sound to come out of this system. Missing one speaker, or one bad connection and you will get no sound or some will work and some will not. speaker wires need to go deep into speaker jack holes.
Aug 04, 2008 | Audio Players & Recorders
No audio
The internal power supply of the speaker system was busted.
Dec 11, 2007 | Bose Companion 3 Computer Speakers
Panasonic CT-27G7 27" TV Logo
348 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
