Sharp AL 1631 Grayscale Copier
Problem for Sharp AL 1631 Grayscale Copier
AL-1631 Repalced drum, but light is still on
By sparker391 on Mar 03, 2009
I just repalce the drum unit for the first time & did it by the instructions in the manual, but the "drum replacement indicator light" is still lit. I have tried reseating both the drum & toner as well powering unit off & on. The light remains lit. Any ideas or suggestions?
Comments:
Mar 03, 2009
- Thx Marcus_25. That took care of it.
Best Solution
posted on Mar 03, 2009
Very Helpful)
marcus_25
Rank: Wiz
Rating: 93%, 31 votes
If you will replaced the drum you should reset the drum counter .
To reset follow these steps:
Step1: Press continuously Clear key then press Exposure key then Clear key then Exposure key
Step2: You are inside the simulation if the display turns off but if not do again step1
Step 3: Press 24 then press print button then press 7 then press print button
If not canceled try step4
Step4: Do step1 to step2 then Press 24 then press print button then press 6 then press print button
Was this helpful?
Yes
No
Popular Solutions for Sharp AL 1631 Grayscale Copier
Questions and Unsolved Problems for Sharp AL 1631 Grayscale Copier
Do you recommend Sharp AL 1631 Grayscale Copier?
Answer
Answer
sharp al-1631,no idiot lights showing, new cart. installed, it doesn't copy anything. unplugged,... (More)
Answer
Instruction Sheet on how to use a Philips remote control type Universal SBC RU 644/05 on a Sharp... (More)
Answer
what's the most efficient way to communicate my sharp xe-a21s with my QuickBooks data file
Describe your Copiers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copier Experts
Top Copier & Fax Repairmen
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
